Author Topic: What in the world is a 'hard copy' oscilloscope?  (Read 7428 times)
Offline dizzTopic starter
« on: December 16, 2016, 10:19:57 pm »
This ebay listing here is calling this a 'hard copy'
What is the idea here?
http://www.ebay.com/itm/Tektronix-2252-100MHz-Prog-Hard-Copy-Oscilloscope-/232169748323
Thanks in advance
Offline Gyro
Re: What in the world is a 'hard copy' oscilloscope?
« Reply #1 on: December 16, 2016, 10:26:54 pm »
I know rebadging is rife but that's ridiculous!  :-DD
(Sorry, couldn't resist)
Best Regards, Chris
Offline madires
  • A qualified hobbyist ;)
« Reply #2 on: December 16, 2016, 10:32:32 pm »
Electrical isolation to prevent you from touching the case/ground. "Grid", "Heater" and "Cathode" should tell you why ;)
Offline Gyro
« Reply #3 on: December 16, 2016, 10:35:00 pm »
Agreed, some serious high voltage isolation.
Best Regards, Chris
Offline StillTrying
  • Country: Broken Britain
« Reply #4 on: December 16, 2016, 11:03:42 pm »
Offline nctnico
« Reply #5 on: December 16, 2016, 11:18:21 pm »
This must be the ultimate floating scope!
BTW it says 'harcopy scope' on the badge and it seems to have a PC style printer port on the back. I have not seen this before so it may actually be a very rare model.
« Last Edit: December 16, 2016, 11:20:17 pm by nctnico »
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #6 on: December 16, 2016, 11:47:08 pm »
It has a digitizer to allow printouts of waveforms - see this manual :
http://exodus.poly.edu/~kurt/manuals/manuals/Tektronix/TEK%202252%20Operations.pdf
Looks like it used a low-speed ADC to digitise repetitive waveforms in sequential sampling mode, from :
http://w140.com/tekwiki/images/3/38/Tek_2252_2247A_2245A_Specs.pdf
« Last Edit: December 16, 2016, 11:51:44 pm by mikeselectricstuff »
Day Job: Mostly LEDs
Online tggzzz
« Reply #7 on: December 16, 2016, 11:49:21 pm »
When somebody falsely claims it is OK to "float a scope", you can say "it is safe in some circumstances; see this picture for what is necessary".
Offline joeqsmith
« Reply #8 on: December 17, 2016, 01:24:06 am »
I want to see whatever it was attached to.
« Reply #9 on: December 17, 2016, 06:30:38 am »
Probably the cathode of a large SEM, to monitor the  current waveform as it scanned.
Offline jonovid
    • JONOVID
« Reply #10 on: December 17, 2016, 06:38:23 am »
 :wtf: hot glue gun sticks?
Hobbyist with a basic knowledge of electronics
Online Monkeh
« Reply #11 on: December 17, 2016, 06:59:34 am »
Nylon or acetal rods.
Offline ebclr
« Reply #12 on: December 17, 2016, 08:32:21 am »
Sold for USD 64.14 it a very fair price
Offline electrolust
« Reply #13 on: December 17, 2016, 10:36:14 am »
I'm guessing the offset front is to place a camera?  Might be hard to work around the intended camera hence the extended controls.
But why a camera if it can print out a copy?  Maybe the printout doesn't have the reticle etc.
« Reply #14 on: December 17, 2016, 10:54:33 am »
And it can only print repetitive waveforms
Offline nctnico
« Reply #15 on: December 17, 2016, 11:01:24 am »
These Tektronix scopes have grooves to hold a camera so I doubt they went through all the trouble just to take a picture of the screen.
Offline Luminax
  • Country: my
    • Electronesk
« Reply #16 on: December 17, 2016, 01:22:54 pm »
What's those strange waveform on the display?
Jack of all trade - Master of some... I hope...
Offline Fungus
« Reply #17 on: December 17, 2016, 03:16:14 pm »
Maybe it had some sort of optical->paper printer in the empty space.  :popcorn:
Offline PointyOintment
  • ↑ I scanned my face
« Reply #18 on: December 17, 2016, 03:19:54 pm »
I think that's actually text. Not sure what it says, though.
I refuse to use AD's LTspice or any other "free" software whose license agreement prohibits benchmarking it (which implies it's really bad) or publicly disclosing the existence of the agreement. Fortunately, I haven't agreed to that one, and those terms are public already.
Offline David Hess
  • DavidH
« Reply #19 on: December 17, 2016, 05:02:39 pm »
Looks like it used a low-speed ADC to digitize repetitive waveforms in sequential sampling mode, from :
This is exactly it.  The 2252 uses sequential sampling to capture a repetitive waveform of 500 horizontal points or 50 points/div and 12-bit vertical resolution at full bandwidth which can then be transferred to a computer over GPIB or printed via a Centronics interface.  All 5 traces can be captured at once.
No other ability to manipulate or display captured waveforms is possible so it is literally an analog oscilloscope with digital hardcopy capability.  If the hardcopy capability is ignored, then it is a 2247A which is a great oscilloscope.
We got the story on these years ago over at TekScopes@yahoogroups.com.  Apparently Tektronix got curious and asked why they needed so many replacement front panels.  They were measuring high voltage tubes of some sort, maybe TWTs.
