Author Topic: What's a good complimentary Win 7 HP data logging trms dmm to the Uni-T UT139C?  (Read 5942 times)
Offline teslafanTopic starter
  • Nubie
For general purpose electronics, Uni-T Ut61E? Thanks very much!
« Last Edit: February 08, 2015, 02:45:49 am by teslafan »
Offline Lightages
  • Canadian po
How much do you want to spend?
  • Nubie
$30 - $65. Thanks
Offline Lightages
  • Canadian po
If you will keep the probes out of the wall socket, meaning no high energy circuits at all, then perhaps this one:
http://www.ebay.com/itm/Digitek-DT-4000ZC-TekPower-TP4000ZC-Data-Logging-Multimeter-with-Temperature-/200912705694
or the UT61E I guess.
Remember, these are only for bench top use!
  • Nubie
Lightages,
Statement from an ebay seller: Re.: TekPower TP4000ZC Compatible with Xp and downward, it may not work on Vista and Win7.
Not trms(Not a big deal, right?) or Win 7 compatible(A big deal 'cause that's what I have), right? OK, thanks!
« Last Edit: February 08, 2015, 04:44:36 am by teslafan »
Offline Lightages
  • Canadian po
PM iloveelectronics and ask him. He is the seller I linked to and he is a member here.
  • Nubie
Very good, appreciate it, thanks.
Offline mtdoc
Lightages,
It's true that the software that comes with that meter (at least when I bought one 3 years ago) is quite rudimentary and antiquated.
What will work with that meter is the exellent qtdmm.
I know it works under Linux and OSX - I'm not sure about the Windows version but it's worth a try.
BTW, even though the TekPower TP4000ZC is not listed as supported - I got it to work no problem.
  • Nubie
Lightages,
BTW, even though the TekPower TP4000ZC is not listed as supported. By TekPower? - I got it to work no problem. It worked with what? With this: qtdmm? Is it Linux or OS-X or works on both? Thanks
Offline mtdoc
Have a look at the link I posted. Here it is again
I have used this program with both Linux and OSX but have not tried it with Windows. Per the download page, it should work.
Also - the QtDMM page has a link to a list of meters that QtDMM is known to support. What I'm saying is that I've been able to get it to work with the tekpower meter as well.
All I can say is download the program and see if you can get it to work with Windows 7.  If not  - nothing lost - it's free. If it does work and you get the Tekpower meter and have trouble getting it going let me know, I can share the settings I used.
Offline mtdoc
OK - I just looked up the newest version of Ultra DMM which I know is Win 7 comptable - since i've used it on my Win 7 laptop.  The newest version supports the Tekpower TP4000ZC!
Ultra DMM can be downloaded HERE
  • Nubie
Xclnt, thanks very much!
Offline miguelvp
I've never used it yet but this software supports all these DMMs
http://sigrok.org/wiki/Supported_hardware#Multimeters
  • Nubie
Thanks, I will keep that in mind. Have any opinions on the next grade up in a trms dmm for same general purpose electronics use with Data Logging?
Offline mtdoc
I also have a UniT UT61D which is trms and data logs. It comes with it's own Win7 compatible software and works with UltraDMM.
It can be had for $40-50 though I scored mine on closeout for less than $30.
But like the Tekpower meter I would only use it for low power electronics. The CAT ratings are not accurate. It is also pretty slow - much slower than that Tekpower.
« Last Edit: February 08, 2015, 07:22:00 am by mtdoc »
  • Nubie
Good to know, thanks for your openness.
Offline Didix
Fluke 76 | UT61E | UT139C | UT70A | UT50E | UT132A | UT33C | UT203 | UTG9002C
  • Nubie
Thanks!
  • Nubie
Remember, these are only for bench top use! Any specific variants that are better? Appreciate your efforts on my behalf.  :)
Offline milamber
Can't the UT 139C be modded for RS232 communication?
On Kerry's page http://www.kerrywong.com/2016/03/19/hacking-dtm0660l-based-multimeters/ no one seemed to have succeeded, yet.
Offline omgfire
  • Country: ru
« Last Edit: November 25, 2016, 10:33:37 am by omgfire »
