Author Topic: Most responsive UI 500Mhz scope  (Read 3814 times)
Offline EEVblog
Re: Most responsive UI 500Mhz scope
« Reply #25 on: March 04, 2021, 06:32:01 am »
My most important feature is: UI responsiveness/speed.
As others have said, Keysight is the fastest UI, and it's my preferred daily driver for that reason.
See the ad link above for the Keysight ebay store where they official sell refurbished gear.
Online nctnico
« Reply #26 on: March 04, 2021, 08:55:56 am »
No. I used to own the bigger brother (DSO7104A) which is built on the same platform. The fat traces where so annoying that I used it in high resolution mode (which comes with it's downsides) most of the time. On a smaller screen it is probably less noticable but there are way better choices nowadays to get a crisp trace.
768 vertical pixels on a 12" screen = yes, you are going to see a lot of noise.  You're penalizing them for giving you more Y resolution than other scopes in their class.
Again no. Even on a small screen the traces are very noisy. Put a modern, lower noise DSO next to it and you'll see the difference.
Offline knapik
« Reply #27 on: March 04, 2021, 10:12:43 am »
The TDS3000 series is pretty responsive actually, its surprising just how much better it is than many modern oscilloscopes. I do have issues with other aspects of the UI, but it is responsive at least.
Offline AlexDavidson
« Reply #28 on: March 04, 2021, 11:34:38 pm »
For what it’s worth, I’ve spend the last couple of weeks debugging SPI on both Keysight 3000A and Siglent SDS2104X Plus, both upgraded to 500 MHz. Even though the Keysight is a lot more responsive to the controls and was easier to setup for SPI, I actually prefer using the Siglent due to the larger more detailed display, mouse & touch control, finer traces, and much larger memory.
Offline kuonTopic starter
« Reply #29 on: March 05, 2021, 12:28:13 am »
Yeah for logic analysis, the bigger the screen the better, that's why I prefer the PC (DSLogic) for logic analyzer. It's way easier to browse 10+ logic channels on a PC.
Offline KE5FX
    • KE5FX.COM
« Reply #30 on: March 05, 2021, 12:48:42 am »
The problem you perceive is a combination of the added available resolution and the rendering algorithm they use, which takes advantage of that resolution by showing additional intensity-graded pixels that you'd normally never see at all.  It does look noisy, but the correct remedy is just turning down the intensity, rather than switching to a worse scope (i.e., everything else in the same market sector) or the high-resolution display mode (which sucks.)
The only real problem is that their default intensity setting is too high.   The DSO6054A is probably the best possible fit for the OP's original request, if they are not interested in the older HPAK scopes or the TDS700D generation from Tek.
(Actually the TDS3054A would be a good fit in the responsiveness area, but they have an absurdly-small acquisition memory.  And they aren't much newer than the TDS784D that can probably be purchased for about the same money.)
