Most modern audio analyzers have a DC coupling option, why not look towards some of those options?
Rohde & Schwarz UPV
NI PXI-4461
(I guess the SRS SR1 is out of the question...)
Keysight U8903B
Audio Precision APx series
Not as likely to get a cal for it, but there's the Prism Sound dScope III as well.
Any of those will have comprehensive FFT capability to a couple hundred kHz, it's not exactly a hardware problem these days in terms of processing, and if they have a DC so dedicated FFT analyzers are a lot less common. Would it be acceptable to buy an instrument through a cal lab that could independently certify it even if the manufacturer doesn't?
Rohde & Schwarz UPV - a possibility but it is not calibrated to directly measure noise density
NI PXI-4461 - no for many reasons
(I guess the SRS SR1 is out of the question...) - maybe
Keysight U8903B - the manual makes it seem unlikely
Audio Precision APx series - definitely no for many reasons (I talked with them in December)
Ideally I want an instrument that directly measure noise density (V/Hz
½) down to 0.1 Hz.
Many of the audio analyzers do not measure this low in frequency and/or do not directly measure noise density. I understand that noise density can be calculated from a power spectrum if the exact equivalent bandwidth is known, but it is much easier to deal with an instrument that directly reads noise density directly.
Would it be acceptable to buy an instrument through a cal lab that could independently certify it even if the manufacturer doesn't?- absolutely if the vendor was ANSIZ540 or 17025 certified.
