Background
I have hobbyist level skills, with nice lab equipment that is smarter than I am.
I am trying to make my first triggered sweep. I am using my DG822 Function Generator and my Siglent 1104X-E Scope.
I have learned that I need three things from the DG822.
1) A Source Sweep Signal
2) A Synchronization/Trigger Signal
3) Channel Settings that tie and coordinate #1 and #2.
I used Channel #1 for my Source Sweep Signal. I am working with a sweep from 20Hz to 20KHz, to test a passive, RC Bandpass Filter. I believe that I have these setting sussed out, as I can find (independently) this signal on the scope.
I used Channel #2 for my Synchronization/Trigger Signal. I used a single Burst Pulse Square Wave, being one second in duration. (Do not be tempted to use a Pulsed Continuous Wave. The FG will complain that a Burst is required.) I believe that I have these setting sussed out, as I can find (independently) this signal on the scope.
The Source Sweep Signal outputs the lowest value of the sweep range, continuously. I believe the 822 is operating correctly, in making this behavior (but, I am not sure of what benefit it is.) It does create a problem, though. It trips the scope trigger, at the wrong time. I can see the sweep go by, but I can't capture it. So, the Synchronization Signal is used, instead, to trigger the scope. I get this far along the learning curve, but I have yet to capture an appropriate single sweep.
The Channel Settings are what ties the two together. They are also what is the most in question. The Channel Settings chapter begins at page 111 of the manual. The Channel Settings menu is accessed by tapping the Channel Tabs, in the lower, left corner of the FG screen, twice. The manual makes some unclear statement about the output being sent out through the connectors on the back of the FG. But, I continued to work using the front connectors. The most misunderstood, and likely important, of these settings is SyncSet State. I could not discern if the two channels should both be set to off, on, or some combination.
I have provided my notes for the 822 Settings, as I had them set. Warning; they were scribbled down, during testing.
I find the DG822 user manual to be so abbreviated as to be of little use. So, I could use some help with detailed instructions of how to set all of the settings, with emphasis on the Channel Settings. If you have a link, that would be great, too.
Please and thank you, for your gracious help.
