The DP10013 should be fine for my hobby level use, and it's not as if I'm probing anything more than computer SMPS mosfets and flybacks. They are usually under 200kHz. The DP10013 is good for a few MHz. They cost $120
Where-as a quality used set of Tek probes will start around $300
I know Tektronix is a leader, but for my uses, what would be the real difference ?
