Author Topic: Micsig has Optic fiber AND HF current Probes?!  (Read 8435 times)
Offline scoper007Topic starter
  • Country: cn
« on: July 15, 2022, 02:17:13 am »
Optical Isolation Probe OIP Series
Bandwidth: 350M
Rise time: ≤1ns
Accuracy: 1%
Common mode voltage: 60kV peak
Common Mode Rejection Ratio: Up to 160dB
High frequency AC and DC current probe CP1003
Bandwidth: DC~100MHz
Range: 6A/30A
DC Accuracy (Typical): ±1%±10mA (6A); ±1%±50mA (30A)
The following users thanked this post: Someone, Fungus, Hydron, ch_scr, nomead
Offline gby
Re: Micsig has Optic fiber AND HF current Probes?!
« Reply #1 on: July 15, 2022, 06:07:27 am »
Color me very interested in learning more about the optically isolated probe.  More detailed specs, pricing, availability.
Could not find any details on micsig.com.  How did you find this?
Offline Hydron
« Reply #2 on: July 15, 2022, 09:34:15 am »
Also definitely interested in more details, especially the optical one (fingers crossed Dave or someone else will get sent one again and do a teardown, like with their earlier current probe). Shame that it seems that these are a Micsig exclusive probe - they've previously released a few well priced probes that are compatible with any scope.
Offline Fungus
« Reply #3 on: July 15, 2022, 11:02:34 am »
Micsig sure is aiming high with their next round of products!
Online Marco
« Reply #4 on: July 15, 2022, 11:26:08 am »
So where's the page these were linked at? Or did you stumble on the image urls?
Given the price of Tek/LeCroy solutions and the relatively low manufacturing costs it was a matter of time for a Chinese version.
« Last Edit: July 15, 2022, 11:28:50 am by Marco »
Offline nomead
« Reply #5 on: July 15, 2022, 11:34:39 am »
Nothing seems to dictate similar adapter included with previous differential probe (DP750) wouldn't be included. Illustration of the CP1003 actually shows adapter so i suppose at least this will have adapter option.
New probes are on chinese site (link in upper right corner).
Offline nomead
« Reply #6 on: July 15, 2022, 11:41:40 am »
It looks like fiber probe supports 50 ohm and 1M input impedances through BNC. Passive probes are available with 10x (P130B) and 100x (P3100) attenuation.
« Last Edit: July 15, 2022, 11:55:24 am by nomead »
The following users thanked this post: derree
Offline TopQuark
  • Country: hk
« Reply #7 on: July 15, 2022, 12:13:17 pm »
Quite interested at the new products, took a look at the product page and translated the specs table for anyone interested.
The following users thanked this post: Fgrir, JPortici, DaneLaw, ch_scr, Martin72, D Straney, zrq
Online Marco
« Reply #8 on: July 15, 2022, 12:17:44 pm »
It's a shame the optical probe isn't active too but I guess for something driving some high voltage switch those few extra pF don't really matter, which is the most common application to measure.
Offline nomead
« Reply #9 on: July 15, 2022, 12:55:50 pm »
While these don't directly compete with IsoVu-probes, i don't think price will be anywhere near 10-15k$.   ::)
Offline JPortici
« Reply #10 on: July 15, 2022, 01:02:03 pm »
Current probe power supply 12V... External adapter or battery powered?
Online Martin72
  • Testfield Technician
« Reply #11 on: July 15, 2022, 01:09:55 pm »
Would be with adapter I guess.
The probe is IMHO another from hioki*, price for it won´t be cheap.
*) All "good" current probes from Siglent, Lecroy, R&S, Rigol are the same building by hioki, only different in the connections.
Offline nomead
« Reply #12 on: July 15, 2022, 01:28:49 pm »
Chinese website claims Micsigs UPI interface provides the power. Maybe UPI provides also 12V? PA12 PSU is offered for non-Micsig scopes.
Offline Hydron
« Reply #13 on: July 15, 2022, 04:16:52 pm »
The bit about auto/manual nulling and gain adjustment makes me think that the optical probe might be based on an open loop analogue optical modulation, i.e. turn input voltage into a level-shifted current to drive a laser/LED, receive with a linear analogue-output detector. The gain and null adjustments mentioned would be needed to periodically tweak gain/offset to adjust for temperature/time/fibre movement, and reverse the level-shift needed for the optical transmitter.
I've actually had a bit of a play doing this in a DIY manner (didn't get much beyond looking at the frequency response of a HFBR-2416/1414 pair), and I think there are other products out there doing it in a similar manner, but with a fair bit less bandwidth.
« Last Edit: July 15, 2022, 04:19:00 pm by Hydron »
Online PartialDischarge
« Reply #14 on: July 15, 2022, 05:37:51 pm »
This probe is probably the same as a Lecroy DL03-ISO but without the Power over Fiber and has a rechargeable battery instead. It most probably, again, works with an optical modulator, Mach Zenhder, Kerr effect, Pockels, or similar.  Someone must be making this for them. One problem is that for auto adjustment the input signal needs to be removed.
Offline gby
« Reply #15 on: July 15, 2022, 08:44:02 pm »
The current probes might be a re-brand of the new Pintech current probes.  See https://www.pintech.com.cn/en/h-col-123.html
The Pintech PT-350 has the same funky 60 Ap-p rating, is 50 MHz, 5 mm max wire diameter, and looks visually similar.  Not sure where the 100 MHz one comes from since I did not see a 100 MHz Pintech version.
« Last Edit: July 15, 2022, 08:55:06 pm by gby »
Online Marco
« Reply #16 on: July 15, 2022, 08:57:19 pm »
Why would you do that instead of just modulating the laser diode current?
Offline switchabl
« Reply #17 on: July 15, 2022, 09:58:58 pm »
The Tek IsoVu (and probably the Lecroy as well) have the laser on the scope-side, so they must have an EOM in the probe head. Of course, if you get rid of power-over-fiber anyway and have a reasonably large battery instead, you might as well go all the way and move the laser to the probe head as well. Maybe you can even use a COTS integrated transmitter (but linearity and drift might be a challenge). I would love to see a teardown.
Offline Someone
    • send complaints here
« Reply #18 on: July 16, 2022, 12:22:44 am »
Not enough other specs line up and the body/casing is completely different in the photos so probably not pintech sourced. Equally its not sharing specs or casing with any Hioki probes so this might be a new entrant to the market.
Offline Fungus
« Reply #19 on: July 16, 2022, 08:23:10 am »
350Mhz?
Offline nomead
« Reply #20 on: July 16, 2022, 10:40:03 am »
I think specs match quite well with Hioki 3276.
https://www.hioki.com/euro-en/products/current-probes/wide-band/id_6016
Micsig has added 6A range to the BNC end and omitted (is that Lemo?) power connector.
Offline Someone
« Reply #21 on: July 16, 2022, 12:16:57 pm »
When the DC accuracy improves at lower ranges (as the CP1003, and 30A to 5A range of Hioki CT6711) it suggests the amplification is at the probe end in the sensing and not just a simple after the fact gain stage.
Online Marco
« Reply #22 on: July 16, 2022, 03:01:45 pm »
350Mhz?
CATV goes to a couple GHz with cheap analogue ROSAs/TOSAs. Obviously direct modulation can go far faster than this, but this is a huge market for low cost parts.
PS. I misremembered, just over a GHz, still good enough. The FTTH ROSAs are commodity items, probably a couple bucks at most in Shenzhen. The TOSAs I don't know, transmitters can be had for under a 75$ but, it's probable the TOSAs are far cheaper still.
« Last Edit: July 16, 2022, 04:54:20 pm by Marco »
Offline BH3XON
  • Country: cn
« Reply #23 on: July 18, 2022, 10:57:14 am »
The attached picture is the price I got and I think is attractive.
The following users thanked this post: Someone, 2N3055, TopQuark, eplpwr
Offline TopQuark
  • Country: hk
« Reply #24 on: July 18, 2022, 01:28:27 pm »
Seems like you need to do a bunch of stuff through Wechat to get the VIP pricing, I got stuck at the phone number verification part (needs a mainland number), guess I'll see what they sell it at when it officially launches through taobao etc.  :P
