Author Topic: Micsig Tablet Oscilloscope tBook mini TO1000  (Read 113635 times)
Offline GeorgeOfTheJungle
  • Country: tr
Re: Micsig Tablet Oscilloscope tBook mini TO1000
« Reply #350 on: August 30, 2019, 12:40:59 pm »
I don't know what they're like used in single shot modes.
In single shot it's perfect. Turn on the zoom (swipe down/up with three fingers) and then can navigate and zoom in/out the 28M stored samples. Perfect!
Offline sixtimesseven
    • Flickr
« Reply #351 on: November 08, 2019, 12:14:16 am »
I'm pretty sure I missed some basic setting or something. But with the built in memory I expected to be able to change timebase and signal level in single aquisition mode to inspect the signal. However, the traces just disapear as soon as I change eg. the timebase?
Sorry if it is obvious  :palm:
Offline exe
  • self-educated hobbyist
« Reply #352 on: November 08, 2019, 09:43:04 am »
So you captured a waveform, started to play around with it, and it disappears? I think I had the same issue. Try pressing stop button.
Offline kirill_ka
  • Country: ru
« Reply #353 on: November 08, 2019, 02:43:24 pm »
Maybe you are confusing "single" with normal trigger mode?
Offline StillTrying
  • Country: Broken Britain
« Reply #354 on: November 08, 2019, 02:51:29 pm »
Is the Trigger X position at or very near the center on the screen.
The following users thanked this post: sixtimesseven
  • Country: tr
« Reply #355 on: November 08, 2019, 03:15:35 pm »
@sixtimesseven you have got to either put it in "single seq" (== single shot) or put it in stop before touching anything else.
    • Flickr
« Reply #356 on: November 08, 2019, 11:14:08 pm »
Thank you all for replying!
Well that makes sort of sense.
I was just confused. For example on the RTB the scope does retain the trace when in normal and the trigger is lost. Not so on the Micsig apparently...
Single SEQ is basicaly a Single acuisition in Normal trigger mode then?
    • Flickr
« Reply #357 on: November 08, 2019, 11:19:22 pm »
Interesting: The user manual here: http://en.micsig.com.cn/html/list_35.html is just the datasheet  :palm:
    • Flickr
« Reply #358 on: November 08, 2019, 11:36:42 pm »
I have to say though -- Im impressed by there scopeSuite software. Connects seemlessly over wifi and is really responsive.
Interesting that they do not advertise that feature.
http://en.micsig.com.cn/html/list_64.html
"ScopeSuite_tBook mini Only support Wi-Fi no need NI-VISA Driver"
Offline maginnovision
« Reply #359 on: November 09, 2019, 12:13:06 am »
I was using one of these recently and I came up on a problem. Is there any way to do fine horizontal and vertical adjustments?
Offline exe
« Reply #360 on: November 09, 2019, 08:51:33 am »
Me too, I'd prefer the trace to stay.
Btw, any recent firmware updates? I tried to check for updates on my oscilloscope, but it was producing a confusing error, presumably meaning "connection timeout".
    • Flickr
« Reply #361 on: November 09, 2019, 09:49:54 am »
Well, I would suspect it to be here:
http://en.micsig.com.cn/html/list_60.html
But for all I know of Micsigs logic it might be burried in a random page  :-DD
  • Country: tr
« Reply #362 on: November 09, 2019, 09:54:47 am »
Offline StillTrying
« Reply #363 on: November 09, 2019, 12:09:41 pm »
Their screen graphic of the scope looks much better than the actual real scope. :)
It's mentioned in some of the other threads on here, there are no fine Y or X adjustments.
Even the firmware updater can't find its way around their site. |O
Offline obd.tech
« Reply #364 on: November 16, 2019, 12:21:47 am »
Hi folks, i've got one of these scopes coming to me and wanted to know the actual screen size and any recommendations for a non reflective screen protector i can order, as the image & video reviews seem to show a lot of reflection issues?
Whats the touch function like with a screen film fitted?
Thanks in advance for any advice  :)
Online beanflying
« Reply #365 on: November 16, 2019, 08:51:39 am »
When I got mine it came with a protector but I finished up not fitting it https://www.aliexpress.com/item/32786016337.html?spm=2114.12010612.8148356.4.6cd9b991eWp1PC
so call me interested if I should after a couple of years get around to fitting it  ;)
Offline obd.tech
« Reply #366 on: November 16, 2019, 02:17:57 pm »
Thanks for the reply, what dimensions are the working area & visible area of the screen?
I was thinking to buy a generic or other make tablet screen film to try, as you have to strip the surround off the Micsig to fit the original.
Offline tubos
« Reply #367 on: November 16, 2019, 03:02:12 pm »
I'm interested in buying the 2 channel / 150 Mhz version called the TO1152+.
I cant find a reference on the Micsig site about this model, and no firmware update that has TO1152 in it.
Are there no firmware updates for this model or is it compatible with another update for a TO1XXX model.
Can Anyone share his experience with this model?
Offline jan.didden
« Reply #368 on: March 09, 2021, 02:22:44 pm »
Hi guys, just received my TO1104+, setting it up. For some reason, it doesn't connect to my WiFi.
The WLAN setup page shows the available networks, and I entered the pass code for my home network.
Then it goes to 'Wait for connecting ...' indefinitely.
I've repeated the setup, switched it on and off, no change.
In the user guide it talks about a WLAN setup dialog for automatic or manual configuration but I don't see that on the page.
Any pointers for me?
Edit: it just connected, after another on/off cycle. Funny enough, in the setup it shows my network twice.
It's not the alternative frequency band, but the exact same it is connected to.
Ohh well, I'm not complaining!
Jan
« Last Edit: March 09, 2021, 02:51:49 pm by jan.didden »
