Hello everyone, I have a B & K model 1655 (the previous version), and I think I have a problem. Setting the output voltage at a120Vac, and measuring with a multimeter the voltages in the double output connector, I get the following voltages AC; live to neutral 120Vac, live to ground 144.7Vac and nuetro to ground 37.4Vac. Is this normal, or does it correspond to an equipment fault?
Thanks..!!
