Author Topic: Moderately-Priced Microscope for SMD Soldering  (Read 40229 times)
Offline JuKu
    • LitePlacer - The Low Cost DIY Pick and Place Machine
Re: Moderately-Priced Microscope for SMD Soldering
« Reply #25 on: March 07, 2013, 08:53:04 am »
< image >
Nice! I have similar setup. Here is a prediction: On the first big board that you are going to work on you are going to turn the base around and find the need for a microscope stabilizing device. I have the basic model (a rock) since it looks nicer, but I could have gone for a high-tech unit (a brick) as well.  ;)
http://www.liteplacer.com - The Low Cost DIY Pick and Place Machine
Offline SLJ
    • Steve's Antique Technology
« Reply #26 on: March 07, 2013, 12:13:56 pm »
Well, I ended up completely blowing my budget out of the water  :palm:
 http://item.mobileweb.ebay.com/viewitem?itemId=200596773862&index=1&nav=SEARCH&nid=99490970459
Good choice.  I've been looking at upgrading for a long time and that's exactly the one I'm planning on upgrading to.  Camera can come later if I need it.
Offline roli_bark
« Reply #27 on: December 30, 2013, 02:22:33 pm »
:D
Sorry for the bump,
but I'm interested to know whether the LED Power unit (the little black box with some buttons on it) is capable of handling 240v ?
Offline SLJ
« Reply #28 on: December 30, 2013, 02:32:05 pm »
Sorry for the bump,
I have the LED-144A with the buttons for the dimmer and turning sections on and off.  It states on the bottom it's for 110-240V, 50-60HZ.
http://www.amscope.com/led-144a.html
Offline Carrington
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
Offline roli_bark
« Reply #30 on: December 30, 2013, 04:52:56 pm »
Sorry for the bump,
Nice, Thanks. Looks to me that the boom-less is a better choice if handling large boards isn't required.
Hence, one may save ~50 Lbs on weight and shipping costs.
Offline Lunasix
« Reply #31 on: December 30, 2013, 06:20:04 pm »
I think a binocular is important for a 3D view when we must operate with a solder iron for example. Try to solder while closing 1 eye : not so easy. So, I'm not convinced by USB camera.
Large vision size is also important, it's better if you can see all of your tqfp as only 4 pins. Magnification around 9x is sufficient.
I have an Olympus SZ30 I really like. Time to time I use a Leica GZ4, quite similar but I prefer the Olympus : more space under the Olympus for same magnification (distance and size of lens support).
