Hello everybody, I've one HP 8904A and I'm recording a random frequency shift on its output. It's more evident if you generate a square wave. I easily got the two service manuals that are available in the Keysigth web site but the "A2" board scheme is missing. The A2 board is the one where are located: the CPU, the clocks and all the digital part of the system. I'm reconstructing the scheme by using the DMM but it's quite long to do and I'd prefer to have the A2 board scheme if available.
From what I see all the clocks have a really bad waveform and the 6.7MHz, in addition, shows the frequency shift that I recorded on the output waveform.
I hope that you can help me.
Many thanks in advance.
Regards,
