Author Topic: Modding a Keithley 197  (Read 15700 times)
Offline tookiTopic starter
« on: August 06, 2015, 05:46:47 pm »
So I scored a Keithley 197 bench DMM on the local equivalent of eBay. It's the original version with the oh-so-1970s brown case and front panel, and no backlight. The internals indicate a 1986 vintage.
(In the background you can see my DS1054Z that I just modded with a quiet fan.)
It seems to work OK, not that I have anything to test it with. But it seems to agree with my 87V to the extent possible.
So here's the question: Would it be sacrilege to mod it to put some kind of LED backlight on the LCD? (I assume something like some side-light LEDs, since the LCD panel itself is highly unlikely to lend itself to actual backlighting.)
Offline AF6LJ
Re: Modding a Keithley 197
« Reply #1 on: August 06, 2015, 05:53:23 pm »
I would say Go for It.
I have been looking for a decent way to mod my HP-3478A.
So please do and post lots of pictures.
Sue AF6LJ
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #2 on: August 06, 2015, 06:25:23 pm »
Go for it. Keithley fan here approve.
Also post teardown pics, never saw one inside well enough :)
Offline codeboy2k
« Reply #3 on: August 07, 2015, 03:14:36 am »
I also want to see inside the 197, to compare it to the 197A.  So please teardown for all to see :)
I've got a 197A which has an EL backlight already, but it was extremely dim when I bought it off eBay.
So I did a repair to replace that, but I wasn't happy with the result:
1) the new EL panel was narrower than the original, and it doesn't cover the entire LCD panel top to bottom
2) it has a light blockage in the upper left corner where the electrode is. This blocks the word "AUTO".
3) I asked for a white EL panel, but got a weird turquoise blue color instead .. ugly.. (it looks brighter and better on camera then in real life. In real life it's very, very dim.  Almost not worth having there. I have not experimented with different voltages or frequencies to try to make it brighter, but since I don't like the color anyways, I never bothered )
Now, I think I will try to get a larger orange EL, to get a look similar to the Agilent U1270 series DMM or the U8000 series PSU's (second picture below).  I don't know if the Agilent PSU's use LED backlights or EL panels.
[click for a bigger image]
I also have another Keithley 197A that is in need of repair. It doesn't take a stable reading (measurements are all over the place and won't settle down). I'll post that repair when I get to it :)
Offline retiredcaps
« Reply #4 on: August 07, 2015, 05:47:26 am »
I mentioned scullcom's channel before, but it seems not enough people know about it.  His 197 teardown video
Offline codeboy2k
« Reply #5 on: August 07, 2015, 07:41:46 am »
Re: scullcom's channel.. Nice! thanks.. I'll take a look.
Cheers!
Offline Lightages
  • Canadian po
« Reply #6 on: August 07, 2015, 08:18:38 am »
I have a 197, and the two things I wish it had, continuity and a back light. I know, I could have purchased a meter with both, but not with the aged accuracy and for the price.
I have considered adding a back light many times. Perhaps I will get to it in time. Please share any results you get as it would be very interesting.
Offline idpromnut
« Reply #7 on: August 07, 2015, 04:20:20 pm »
@codeboy2k: I did the same fix to my Keithley 175A (I have pictures but not posted. I will do that tonight!)
@tooki: I have a project on the todo list that would replace the display from this line of meters (197, 175, etc) with an OLED display. I started the reverse engineering on the display controller and was at the point of figuring the best way to approach the mod.
« Reply #8 on: August 18, 2015, 11:16:32 pm »
Have you made any progress on that?
Offline idpromnut
« Reply #9 on: August 19, 2015, 01:09:31 am »
Unfortunately not. As happens, projects tend to pile up :)  I will see if I have some time in the next couple of weeks to throw together a prototype at least.
« Reply #10 on: August 19, 2015, 01:16:01 am »
Lemme know what you figure out. I did a preliminary investigation of the 197's display, and it looks as though backlighting will not be trivial to add. So an entire replacement display could well be a better solution.
Offline idpromnut
« Reply #11 on: August 19, 2015, 01:26:31 am »
I totally spaced and forgot to do this.  Here are a few pictures of my replacement of the EL backlight in my 175A.
Offline codeboy2k
« Reply #12 on: August 19, 2015, 06:34:57 am »
Thanks for those pictures! It turned out really nice for you.
Which EL panel did you buy (if you remember) ?
Mine was too narrow and as you see in my pictures it has an electrode on the front side that blocks the light (grrrr!)
Offline AF6LJ
« Reply #13 on: August 19, 2015, 10:39:52 pm »
Looks good I really like it.
Might have to look into doing that to my HP..
Sue AF6LJ
Offline idpromnut
« Reply #14 on: August 20, 2015, 01:21:22 am »
Of course the seller is not selling them, but I got something like this: eBay auction: #271234168462  Just look for a "cuttable" EL strip and you'll be fine (and of course you don't need one with an inverter, unless you're modding a unit that didn't come with a backlight originally).
Offline codeboy2k
« Reply #15 on: August 20, 2015, 03:19:12 am »
Great! thanks, I'll get one of those wider strips next time then.
The 1.25" width is too big, I wasn't sure if I could cut them down on two edges and have it still work (both length and width). So in the past I opted for a narrow one and I only cut the length, but it was too narrow.
I'll give it a try.
Cheers!
« Reply #16 on: October 28, 2015, 02:14:08 pm »
I really need to get back into this project, after successfully adding a backlight to a cheapie DMM I had lying around.
Question though: EL strips require an inverter. Do the inverters produce noise that could affect the performance of a 197, given that they have microvolt resolution?
Offline don.r
« Reply #17 on: October 18, 2019, 03:23:41 am »
Has anyone found a source for suitable EL panels? My 175A backlight is very weak.
« Reply #18 on: October 18, 2019, 08:00:07 am »
It’s fairly easy to find suitable ones on eBay, since you can just get an oversize one and cut it to size. (My 197A has the same issue.) There are both large strips and square panels that are big enough. The thing to look for is where the power connectors are, so as to be able to match the location of the original leads. (You don’t want one where the power goes in the very corner, but rather centered so you can trim to size and still have the leads centered.)
That said, I’d love to experiment more with the diffusion films from thin edge-lit LCD panels. In particular, the film with the etched dots is very interesting, as it’s designed specifically to eject light evenly from just side lighting.)
Well, that and with making a whole replacement display PCB using an Arduino decoder to drive some nice LED, graphical LCD, or OLED display.
« Last Edit: October 18, 2019, 08:02:06 am by tooki »
The following users thanked this post: don.r
Offline don.r
« Reply #19 on: October 19, 2019, 02:14:59 am »
OK. Ordered a white one off eBay.... and now a month or two of waiting.
Offline akabek
« Reply #20 on: February 02, 2021, 10:58:49 pm »
I just received my 197A from ebay and I came across this thread.  Has any recently found a suitable EL panel for the backlight mod?
« Last Edit: February 03, 2021, 04:44:19 pm by akabek »
Offline don.r
« Reply #21 on: February 03, 2021, 05:46:53 am »
I just received my 175A from ebay and I came across this thread.  Has any recently found a suitable EL panel for the backlight mod?
 :-// The 175A already has a backlight. What mod are you referring to? My EL panel was fine but I had to get a new backlight driver off aliexpress.
« Last Edit: February 03, 2021, 05:48:37 am by don.r »
Offline akabek
« Reply #22 on: February 03, 2021, 06:25:31 am »
The 197A does have a backlight but it is dim and barely noticeable.  I was hoping the EL panel mod would be an improvement.
« Last Edit: February 03, 2021, 04:44:40 pm by akabek »
Offline akabek
« Reply #23 on: February 03, 2021, 04:17:05 pm »
Which EL panel did you order?
Offline don.r
« Reply #24 on: February 03, 2021, 04:25:28 pm »
Similar to this one. Like I said, it was my driver at fault, not the panel.
https://www.ebay.ca/itm/ABS-Plastic-Electroluminescent-El-Panel-Light-Lamp-Sheet-Backlight-2-Colours/393103760354
