For working on low level signals, I like using 1x probes, but the BW of these probes are quite low, often limited to around 10MHz or so. Reason being the distributed R, L, C in the lossy coax cable used in scope probes.
Today I had a silly thought: If the distributed loss in the cable is attenuating the HF contents, why not just make the cable shorter? I mean most of the time the probe cables are longer than I need anyways.
So I took a x1/x10 probe that I don't use anymore, snipped half of the cable length off, and terminated the cable with a crappy screw terminal to BNC adapter (terrible, but I don't have anything better on hand), and what do you know, the rise time decreased from 32.6ns to 19.6ns, giving us roughly 66% more bandwidth.
Halving the cable length didn't quite give us double the BW, probably because of the input capacitance of the scope channel being held constant. Signal fidelity looks fine. The 10x mode doesn't work properly anymore, but I have enough dedicated 10x probes anyways, I don't really care, I'll just glue the switch to x1.
So yeah, what do you think? Am I missing something? Or is it really that easy to get a better x1 probe (besides the listed drawbacks) ?
