Author Topic: MS5308 LCR Tester Software and Serial Port  (Read 8767 times)
Offline neikaloTopic starter
« on: October 04, 2012, 06:07:47 pm »
I've lost the CD that came with my MS5308. Anyone willing to take an ISO of theirs and email it to me?
Has anyone got this device working when connected to a PC using a USB serial port and terminal software? I am not having much success. I know these sorts of things often use the handshake lines to power up the receiver in the connector that attaches to the instrument. I don't see any IR activity using trick on pointing a camera at the IR transmitter. I have pressed the "RS232" button!
Offline ryanblace
  • Los Angeles
Re: MS5308 LCR Tester Software and Serial Port
« Reply #1 on: November 09, 2012, 08:16:59 am »
USB driver: http://www.silabs.com/products/mcu/Pages/USBtoUARTBridgeVCPDrivers.aspx  (VCP Driver Kit)
Software: http://www.ietlabs.com/de5000-lcr-meter.html (DE-5000 PC Software Zip)
The DE-5000 software is way better than the junk that comes with the MS5308. :)
Let me know how it goes.
Offline Fraser
« Reply #2 on: November 09, 2012, 09:48:05 am »
Sadly IET seem to have a broken software link. Can anyone provide the DE-5000 software via a file server please ?
I own the Mastech MS5308 unit and would like to try the DE-5000 software
Kind Regards
Fraser
Offline ryanblace
  • Los Angeles
« Reply #3 on: November 09, 2012, 06:45:24 pm »
Offline ryanblace
  • Los Angeles
« Reply #4 on: November 10, 2012, 12:00:25 am »
I'm interested to what you guys see. My setup works about 60% of the time. It jumps around and displays garbage the rest of the time. Same problem on both software packages so it is either the driver (doubtful since it is directly from the mfg) or my Win7 64bit confuses it.
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #5 on: November 10, 2012, 01:35:59 am »
Software works fine on the DE-5000
Offline ryanblace
  • Los Angeles
« Reply #6 on: November 10, 2012, 03:42:06 pm »
Do you have the USB or RS232 cable?
Offline robrenz
« Reply #7 on: November 10, 2012, 08:36:34 pm »
usb
