Author Topic: Tektronix TDS3012B-NV floppy drive?  (Read 657 times)
Offline wd5jfrTopic starter
« on: August 25, 2021, 04:02:34 pm »
The floppy drive doesn't work anymore and needs to be replaced.  Is it a standard IBM floppy drive and are the connections same as a PC?
Thanks
Hank
Offline coromonadalix
Re: Tektronix TDS3012B-NV floppy drive?
« Reply #1 on: August 25, 2021, 05:31:00 pm »
seems to be the TEAC-FD-04HF-2300 floppy,  it's supposed to be wtih an fpc connector
TDS 3012 wiki,  some manuals and a service manual,  not sure it's complete
https://w140.com/tekwiki/wiki/TDS3012
https://www.ebay.com/itm/TEAC-FD-04HF-2300-OEM-Replacement-for-TEAC-FD-04HF-2300-floppy-drive-3-5-1-44-/264161251659?_ul=IL
Offline james_s
« Reply #2 on: August 25, 2021, 07:39:04 pm »
It's a laptop floppy drive, so thinner with a different connector than the ones used in desktop PCs but otherwise similar. There are at least some variations, I swapped parts between an older and newer TDS3000 a while back and found the floppy drive from one wouldn't fit in the front panel of the other but I don't recall the exact details.
