It's always a good sensation when you prove you were wrong.
I don't want to know what went wrong the other time, something stupid, I think.
May be it's related to the old 1.52 firmware I had. I've just upgraded to the latest 1.56.
Anyway here it is the boot log for my MSO 2024B scope.
U-Boot 1.1.4 (Oct 29 2008 - 14:14:00) Tektronix, Inc. V1.01
CPU: MPC870ZPnn at 133.333 MHz: 8 kB I-Cache 8 kB D-Cache FEC present
Board: Tektronix Fusion MPC870 Main Board
Version: 4 (QUAL) 4 channel MSO
Tek0001A ChipId: 0x1400c
Tek0001A SubBlocksId: 0x0
Tek0001B ChipId: 0x1400c
Tek0001B SubBlocksId: 0x0
CPLD Version: 0x11
I2C: ready
DRAM: 64 MB
FLASH: 32 MB
In: serial
Out: serial
Err: serial
Net: FEC ETHERNET
Enter password - autobooting in 3 seconds
## Booting image at efec0000 ...
Image Name: Linux-2.4.20_mvl31-885ads
Image Type: PowerPC Linux Multi-File Image (gzip compressed)
Data Size: 1278107 Bytes = 1.2 MB
Load Address: 00000000
Entry Point: 00000000
Contents:
Image 0: 868895 Bytes = 848.5 kB
Image 1: 409199 Bytes = 399.6 kB
Verifying Checksum ... OK
Uncompressing Multi-File Image ... OK
cmdline is console=ttyS0,115200 quiet bigphysarea=10570 panic=2 root=/dev/mtdblock4 rw mem=175190k NO_option_board
Loading Ramdisk to 03e3a000, end 03e9de6f ... OK
No option module board found
Checking for firmware update...
No USB mass storage devices found to update from.
Linux 2.4.20_mvl31-885ads V 1.06 Tektronix Fusion Tue Apr 26 14:44:49 PDT 2011
Warning: loading NiDKEng-1.6 will taint the kernel: non-GPL license - Proprietary
See http://www.tux.org/lkml/#export-tainted for information about tainted modules
Warning: loading NiDUsb-1.6 will taint the kernel: non-GPL license - Proprietary
Warning: loading tek will taint the kernel: non-GPL license - Proprietary
Scope application starting (normal mode)
Running Init code
versionBuildFWVersionString(), TimestampString: 17-Jul-14 11:00
versionBuildFWVersionString(), VersionFIRMWAREVERSIONversion: v1.56
versionBuildFWVersionString(), Major ver num: 1 Minor ver num: 56
hwInit
mpc8xx GPIO open successful
Initializing Mpc8xx[0]
adg420a open successful.
adg420b open successful.
Initializing Adg420[3]
Initializing Adg420[2]
Initializing Adg420[1]
Initializing Adg420[0]
Initializing ExtTrig[0]
adc08d1020a open successful.
adc08d1020b open successful.
Initializing Adc08D1000[1]
Initializing Adc08D1000[0]
Initializing Dac121s101[1]
Initializing Dac121s101[0]
Initializing ad5160[0]
ad5305 open successful.
Initializing ad5300[0]
tek0001 detected, patching device offsets.
lm95241[0] open successful.
lm95241[1] not present.
Initializing Lm95241[1]
Initializing Lm95241[0]
Initializing ResetCpld[0]
Factory Checksum: Stored: 29892, Calculated: 29892 - OK
Spc CheckSum: stored: 64237 calculated: 64237 - OK
Starting POST diags
Finished POST diags
Fp Id response: 6 4 19
Front Panel Software Rev 19 - no update needed.
cfgGetBoardModel: modelID 6 idStr MSO2024B
hcPtpInit: Starting PictBridge PTP subsystem
fusadInit
utilInit
Running Start code
diagStart
fusionTrigStart(): calibrateTrigIf() ran 1 times and passed
fusionTrigStart(): testTrigIf() for TEK0001A returned 0
fusionTrigStart(): testTrigIf() for TEK0001B returned 0
fusadStart
Running Run code
wfmMgr OK for diags
diagRun
fusadRun
eth0: unknown interface: No such device
enetLinkPresent: ioctl failed, errno 19
Scope startup complete; duration = 22.829660 seconds
PID to Task info:
PID: 62 ThrdID: 16386 Task: tUsrRoot
PID: 63 ThrdID: 32771 Task: tExcTask
PID: 64 ThrdID: 49156 Task: errSuspendAllThread
PID: 65 ThrdID: 65541 Task: hwIntReceiver
PID: 66 ThrdID: 81926 Task: fpIntTask
PID: 67 ThrdID: 98311 Task: fpIrqMonitor
PID: 68 ThrdID: 114696 Task: usbHotplug
PID: 0 ThrdID: 131081 Task: probesSharedUnloadCmdQueueThread
PID: 70 ThrdID: 147466 Task: fusad executive
PID: 71 ThrdID: 163851 Task: UsbTmcOutputMgr
PID: 72 ThrdID: 180236 Task: piUsb
PID: 73 ThrdID: 196621 Task: piVGpib
PID: 74 ThrdID: 213006 Task: Nios A listener
PID: 75 ThrdID: 229391 Task: Nios B listener
PID: 76 ThrdID: 245776 Task: exec
PID: 77 ThrdID: 262161 Task: autoset
PID: 78 ThrdID: 278546 Task: cal
PID: 79 ThrdID: 294931 Task: diag
PID: 80 ThrdID: 311316 Task: fp
PID: 81 ThrdID: 327701 Task: hc
PID: 82 ThrdID: 344086 Task: UsbSicInputMsgMgr
PID: 83 ThrdID: 360471 Task: wfmMgrTest
PID: 84 ThrdID: 376856 Task: search
PID: 85 ThrdID: 393241 Task: periodicZoom
PID: 86 ThrdID: 409626 Task: periodicClockAnimation
PID: 87 ThrdID: 426011 Task: periodicBusyIndicAnimation
PID: 88 ThrdID: 442396 Task: math
PID: 89 ThrdID: 458781 Task: meas
PID: 90 ThrdID: 475166 Task: measImmed
PID: 91 ThrdID: 491551 Task: piCmdIntfc
PID: 92 ThrdID: 507936 Task: probes
PID: 93 ThrdID: 524321 Task: ref
PID: 94 ThrdID: 540706 Task: rtl
PID: 0 ThrdID: 557091 Task: thttpd
PID: 112 ThrdID: 573476 Task: tVxi11SRQd
PID: 0 ThrdID: 589861 Task: tVxi11Rpcd
PID: 114 ThrdID: 606246 Task: tVxi11FlushThread
PID: 0 ThrdID: 622631 Task: bus
PID: 0 ThrdID: 639016 Task: debugConsole
PID: 117 ThrdID: 655401 Task: VgpibRead
PID: 118 ThrdID: 671786 Task: VgpibWrite
PID: 119 ThrdID: 688171 Task: UsbTmcEventDispatcher
PID: 0 ThrdID: 704556 Task: probesHandleBulkPowerChangeThread
Power Up Completed at 20:28:37
Enter 'ctrl-\' twice to quit scopeApp
Received testTrigIfcMsgAck, nios = 1, payload = 10
OK to connect by: telnet MSO2024B-05NTD7 1072
Received testTrigIfcMsgAck, nios = 0, payload = 10
20:28:37 fusadSetNiosUsable
20:28:42 --- Power Up Phase Cal - PASSED
