And you seem to not really understand "how much it cost" to do anything when designing and manufacturing a product..
To people with no practical experience doing that job it all seems easy. It's not, and it is most complicated at low end.
I've seen people buying inexpensive scopes for 350 € (because it was as much as they can afford) and then putting in a 65€ fans, complaining that such fan should have been inside in a first place..... Because how much would it cost in a first place... Well, 65€, that much... But they wouldn't buy that scope at 415€ because it would be too expensive...
This topic of acoustic noise comes up every now and then. Some people have very quiet environments and have acoustic sensitivities. That happens. Most of the people don't care, or have background noise that makes it non issue.
But be sure that no scope with a fan will be completely quiet (except mentioned SDS2000X HD and some R&S scopes from lower end). Worst are more expensive, more powerful models that have lots of heat to dissipate...
As I said above, I try and build my computers with silence in mind, and that's not only because I don't like noise, but also because I do audio stuff with them.
Before that, I tried numerous desktop PCs and even some professional workstations. They were all considerably loud.
With *less* money than it's required to buy a 2nd rate brand desktop PC, I managed to build a totally silent (idle) or quiet (under stress) workstation. It was sufficient to buy the right fans (which cost not much more than crappy ones, and certainly not 65 eur apiece), being careful about the airflow, selecting the correct power supply, etc... I neither made strange, exotic things, nor I had to resort to liquid cooling.
In the hindsight, all these pre-built workstations would have required very modest investments in order to be quiet. It's not that they leave them loud because otherwise they wouldn't be competitively priced. It's just that either they don't care, or they hire incompetent engineers. Probably both.
The SDS2000X Plus is much more noisier than the comparably-sized RTB2000 (that can be barely heard according to the reviewer) and even noisier than the little keysight (which has less room for airflow and fan size, as tautech noted..), indicates just bad engineering. If they managed to spare some 50 bucks by leaving it so loud, that was a bad call, period. That scope starts at 1400 eur vat included, and people who buy it wouldn't have been discouraged by a 50 bucks difference if they released a quieter revision. The same stands for the Rigol MSO5000.
New SDS2000X HD is probably acoustically quietest device I ever used. It has best quality materials it makes R&S scopes look like plastic toys. It feels solid, and premium quality when used.
When released, first comment on EEVBLOG was that it was expensive... But it is not, it priced according to it quality and performance class...
You seem intentioned to defend the brand with your life, more than tautech who sells it..
As I said (and you folks duly observed) I know nothing about test equipment, so I'll leave to others that thing about the R&S stuff being plastic toys.
Let me just say that I didn't ask for a device that belittles top-brand scopes into plastic toys. I would have been content with exactly the same scope as the actual 1104x-e, but with a reasonable acoustical performance.
That they can make silent stuff when they want, well, that just makes things worse for the brand.
It's not that I have such incredible sensitivity to noise. It's that this scopes outputs a sound pressure that's comparable to a portable vacuum cleaner. If you want, tomorrow I'll take the car VC at home and make a video with the same iPad at the same distances.
It's just not acceptable.
Now that you made me think about cars, let me tell you something.
One crucial aspect about cars, especially for those who do considerable mileages is how comfortable the driver's seat is.
Now, among utility cars (say up to 30K eur) very few do have seat inclination adjustments, or lumbar support adjustments (seat inclination refers to the part of the seat upon which you place your arse).
How much, in percentage terms, are these adjustments going to impact over 30K? Nothing, or almost.
Still, they don't put them into utility cars.
Manufacturer stupidity.
A friend of mine works as traveling salesman. It has back pain and suffers from his high yearly mileage. My car has an AGR certified driver's seat and you can adjust whatever you want with it (I paid just 450 more bucks for it when I bought the car), and he observed that it's much more comfortable to drive. I asked why didn't he buy such an option. He replied he didn't even think about such trifles.
Customer stupidity.
People "don't care", and manufacturers (particularly the bad ones), consequently care even less.
Then the same people try a quality product, maybe just slightly more expensive, and then say "oohh, it's another world!".
