Author Topic: Multimeter choices for rural/outdoor use  (Read 14063 times)
Offline Stonent
Re: Multimeter choices for rural/outdoor use
« Reply #25 on: September 15, 2013, 08:49:58 pm »
Honestly I'd just get a throw-away meter if I was travelling. Your requirements are not very high so pick up a cheap CATIII or CATIV rated meter sold at a hardware store in the electrical wiring department.
Offline Lightages
  • Canadian po
« Reply #26 on: September 15, 2013, 11:12:22 pm »
His point was to have something safe and durable, but not too expensive. A "throw away meter" is what he already has and there is no such a thing as a "throw away meter" with true CATIII ratings.
Offline EEVblog
« Reply #27 on: September 15, 2013, 11:37:18 pm »
On old Fluke 27
Offline Wytnucls
« Reply #28 on: September 16, 2013, 10:44:29 am »
Well, you can't have your cake and eat it.
I'm talking second best option here.
Sturdy IP67 meter, CAT III 1000V, GS listed, that doesn't cost a fortune.
Well, exactly that DT-9949 is dubious.
When I search for it in the TUV database I end up at a certificate AN 50225998 http://www.certipedia.com/certificates/50225998 But for whatever reason the DT-9949 is not mentioned in the certificate data. Further, the certificate is for EU low-voltage-directive conformance. The description of that particular test contains the following
The EC declaration of conformity refers to the tested sample as stated in the certificate. It certifies that this sample complies with the safety objectives according to the latest version of Low Voltage Directive Annex I. The certificate does not refer to serial production of the product and it does not authorize to use a TÜV Rheinland test mark.
So even if this happens to be the certificate for the DT-9949 it does not allow to use the TUV and GS mark.
I'd rather use a brand where they have their shit in order and where the risk of "spontaneous" cost savings during production is low.
Here is the last updated (July 2013) list of the CEM meters that have been tested and which are allowed to bear the TUV GS mark:
http://www.certipedia.com/companies/33446/certificates_by_product?additional_title=Digital+Multimeter&locale=en&title=Multimeter
Some of the recent meters may have been tested already, but do not appear on the list yet.
You can always report CEM for unlawful use of the certificates if you're not convinced:
'In case a GS Mark has been attached to a product without permission - that is without the relevant tests, certification and factory inspection - corrective measurements against the unlawful user will be implemented on the spot.'
« Last Edit: September 16, 2013, 10:58:23 am by Wytnucls »
Offline EEVblog
« Reply #29 on: September 16, 2013, 10:59:14 am »
Another alternative perhaps?
http://www.testequipmentdepot.com/amprobe/multimeters/hd110c_hd160c.htm
They do look pretty darn good. Is there a better input rated meter?
An upgrade to the old Wavetek HD110 I'm assuming.
Amprobe is of course owned by Fluke, and I have been told that all Amprobe meters undergo full Fluke in-house testing certifications for their ratings. So yes, I'd trust Amprobes ratings.
alm
  • Guest
« Reply #30 on: September 16, 2013, 11:08:38 am »
That's interesting. Why would Fluke introduce a CAT IV 1000 V meter under the Amprobe brand? You would think the Amprobe brand is for people who don't want to pay extra for the Fluke name (and presumably quality). Introducing a CAT IV 1000 V meter while the highest Fluke goes to CAT IV 600 V (as far as I know) does not fit in that picture. Would a CAT IV 1000 V meter under the Fluke brand require more rigorous testing? Are they taking risks they don't want to take with the Fluke brand? Is this intended for a different market that they serve through the Wavetek brand?
Offline EEVblog
« Reply #31 on: September 16, 2013, 11:22:13 am »
Maybe not. But it does need to the made in the USA instead of China to to sold in the Fluke US market.
And it's designed by a different group I believe.
Offline Wytnucls
« Reply #32 on: September 16, 2013, 11:22:57 am »
The Amprobe meters are limited to a 2A range only, weird!
How useful is that?
alm
  • Guest
« Reply #33 on: September 16, 2013, 11:48:39 am »
[Maybe not. But it does need to the made in the USA instead of China to to sold in the Fluke US market.
The Fluke 115-117 is made in China and sold under the Fluke brand in the US, isn't it?
I'm guessing 11A fuses of suitable ratings would be prohibitively expensive. The ones Fluke use may not be enough for CAT IV 1000V. 2A is perfectly usable for many applications. Most battery powered consumer gadgets, for example. Many older meters were limited to 2-3A, and power usage has gone down since the days of discrete transistors and TTL. I can't really see the CAT IV 1000 V crowd breaking the circuit to measure current. That's when the clamp meters shine, especially for currents above 1A.
Offline Wytnucls
« Reply #34 on: September 16, 2013, 01:44:44 pm »
I don't think it is a question of prohibitively expensive fuses. The Amprobe 2A fuse sells for 13$ for a set of two. Just as well, as with a range of 2A only, one can expect to blow fuses on a regular basis.
They are probably made by Mersen or a similar company and are available in different Amp ratings:
These ones are quite long though at 120mm and I don't have the dimensions of the Amprobe ones. Actually, they are half the size at 65mm.
« Last Edit: September 17, 2013, 08:51:13 am by Wytnucls »
alm
  • Guest
« Reply #35 on: September 16, 2013, 02:21:28 pm »
That would be tricky to fit into a meter ;). Especially if you want fuse access through the battery door.
But what I was referring to was that the 10A range would probably need a fuse with an even higher interrupt current rating, since the shunt resistance, and the effective impedance as seen from the fuse, would be lower. I believe the 440 mA and 11 A fuses used in many Fluke meters also have different ratings. The 440 mA fuse is 10 kA while the 11A fuse is 20 kA, IIRC.
Offline Wytnucls
« Reply #36 on: September 16, 2013, 03:29:39 pm »
Hey, you could load them like torpedoes on a submarine (Should get a patent for this...)  8).
The CAT IV 1000V rating for the fuse only requires no arcing in the meter for 1 minute, with a ruptured fuse in place at double the rated voltage (i.e. 2000V). This is the same requirement as the CAT III 1000V. The difference between CAT III and IV, in this instance, only concerns the voltage range, with higher transients for CAT IV. A CAT IV 1500V rating would need a 3000V arcing test on the amp range for 1 minute.
The HRC fuse must be certified for the highest voltage and should withstand a minimum of 50kA or 1500V/shunt, fuse and leads impedance, if lower. The voltage source must be capable of delivering at least 500VA.
« Last Edit: September 17, 2013, 09:53:05 am by Wytnucls »
Offline retiredcaps
« Reply #37 on: September 16, 2013, 07:41:12 pm »
Now I would like to purchase a multimeter for usage in tough environments, more specific in Mexico on an seaside property, like for debugging the local power installations (probing 110V power cables in the fuse box, measuring resistances etc...).
What range do you need for resistance measurements?  Do you need to measure more than 4000 ohms (4K)?
Offline Robomeds
« Reply #38 on: September 16, 2013, 10:04:39 pm »
I like the idea of the Fluke 8025/25/27 but would the 113 do the trick?  They are horrid bench meters because they only have a low Z voltage testing mode but they might work well for the job.  They aren't water proof but neither is the 87 and it's known for ruggedness.  The 113 would work well for checking AC lines.  Its certainly a durable meter (check out Dave's 117 review, same meter family).  They also can be had almost new on ebay for $40.
Offline AG6QR
    • AG6QR Blog
« Reply #39 on: September 17, 2013, 04:29:07 am »
If it were me, and I were going to use it to probe around in mains distribution panels, fuse boxes, and such, near salty air, I'd wouldn't negotiate on two criteria:  Safe CAT III protection, plus at least enough dust/water resistance to maintain that Safe CATIII protection.  A meter might be very safe the way it came from the factory, but if it is exposed to salt spray for a few years, those carefully designed creepage clearances might not be maintained.
Ideally I'd like something with at least IP67 certification, and I'd rinse it off with fresh water after every exposure to salt air.  I'd might settle for dust intrusion protection.  But if I got a meter with no certification on its case, I'd be periodically opening it up and checking the circuit board to make sure it wasn't getting salt buildup or corrosion.
To save money, I'd go for a used Fluke 27 or similar meter out of calibration.  Utmost accuracy doesn't seem as important as safety/waterproofing for this particular scenario.
Offline bernrothTopic starter
« Reply #40 on: September 17, 2013, 07:46:42 am »
Thanks to all for your responses. I try to reply to every question :)
@AG6QR:
You got the point, there is a lot of salt in the air and I agree to all what you wrote.
I will definitely check the board of meter every once a while to make sure there are no salt residues. I have some plastic boxes there to keep all my tools to avoid them to rust.
Last time I had there some hyper quiality swiss steel tools and after some time even them got rusty.
I have not yet found a used fluke 27 at a reasonable price, I will continue watching
73
@retiredcaps:
For resistance measurement I will require more than 4k because most of the wires have been put underground and there might be a measurable resistance of maybe some 10th k between the phase and earth  :o
Typical mexican installation unfortunately. Electricians tools there are shovel, wire and black pvc tape :palm:
In the meantime I scored a reasonable priced Extech EX510 meter for USD $45 and I might get it today in my hands.
As we have learned I will take it apart first, check if it meets international and my ambitious quality and safety standards and then turn it on :)
I will post some pictures of the inner workings of that meter.
If I find another reasonable priced Fluke, I will take it into consideration.
These thow-away meters from the local tool store are crap - sorry. If not the electrical 110v installation or the insane SWER transformer puts your life in risk, the meter will do
Offline retiredcaps
« Reply #41 on: September 17, 2013, 07:55:40 am »
Yes, please provide pictures of the insides (both sides of the pcb).
I'm trying to keep an open mind about the CEM made multimeters especially the soldering quality inside on the pcb.
« Last Edit: September 17, 2013, 08:00:59 am by retiredcaps »
« Reply #42 on: September 20, 2013, 01:39:38 pm »
Today I received the meter and took some pictures of the inside.
The solder quality is not the best but okay except for the joints on the current sensing shunt.
I wonder why they put a huge ball of solder on the shunt itself, maybe for tuning?
The long red (but isolated) trace which goes from the common input to the shunt is bad design IMHO.
I wonder how they can claim that this meter supports 20A max current (see the specs at http://www.extech.com/instruments/product.asp?catid=48&prodid=266) using a 10A fuse and a crappy shunt. Okay, they spec 20A for 30sec max with reduced accuracy but please... come on  :-\
Quick some details about the casing: There are rubber gaskets all around the case and the battery compartment. The screws which hold the two case parts together have all a metallic and a rubber washer which is quite nice. I need to check how they sealed the range switch which must have been more complicated.
BTW: The photos are intended to have high-res so that you can see all details
Offline Wytnucls
« Reply #43 on: September 20, 2013, 02:08:09 pm »
I never liked that long wire to the shunt either. Probably works ok, but it looks messy. Seems to be a common feature on that EX series. A thick tinned trace would have been better. Shunt looks weird, but if it works OK, I wouldn't worry about it. Let's hope that the solder blob doesn't fall off with 20A running through it.
This meter should do the job for you and at least you won't cry if it gets stolen.
Offline retiredcaps
« Reply #44 on: September 20, 2013, 04:24:34 pm »
Thanks for the pics.  I appreciate it.
Can you also remove the 4 screws on the lcd and post pictures of underneath the lcd?
Offline Lightages
  • Canadian po
« Reply #45 on: September 20, 2013, 06:55:25 pm »
I am glad you got one that wasn't put together by a monkey this time. It looks like it should serve your needs quite nicely.
