And what you all were waiting for:
Part 3: The PCBPic 18: Overview PCB topPic 19: Overview PCB bottomThe PCB reveals no magic nor anything special. It is a mixed construction of through hole parts and SMD components. The PCB is a standard green one with white silkscreen and a heavily structured surface. All pads are gold plated. Not very thick but at least! The soldering on the SMDs looks very regular and even, no problems there. Same goes for most through holes.
There is Writing in copper saying "
4233-1307-A" on the top side and the same ending with "
-B" on the bottom. Also on the bottom there is the number "
0506" to be found. This is read in the same direction as the other text. Of course it may also be "
9050" when turned upside down. Not sure about this (7-segment stile, both seems possible). I did not bother to take pictures of that.
The Silkscreen shows a "GTR" logo and "
CD-1".
The PCB is clearly laid out to be used with different types of parts. The trimpot, for example, could be of various sizes, the pads are arranged in a way that allows several types to fit in, even through hole types. One can see this at various places.
Also, this PCB could be used for several models, I think. There are many spots which can take different parts. Not all of this is to make usable what could be found, I think. There is room for a much larger ceramic type, sand filled fuse (how do you call them?) instead of that simple one on the Amp-jack, for example. Also the pads for a third softbutton are cleared and gold plated. I am sure this is for a hold button, wich some other models show.
Pic 20: Detail input area top sidePic 21: Detail input area top side from the other sidePic 22: Detail input area bottom sideThe input area looks pretty crowded and a bit chaotic (pictures 20 to 22). Also I would suspect things could go wild in case of a blast. There are no cutouts and there is no shielding. I am a bit dissapointed about that after the good start. The Fuse on the 10 Amp range is a proper 10A / 600VAC one of those blast protected types I don't know the english name for. The other Amp ranges are fused with a FF 0.5A / 250V rated type. It sure has a ceramic body but I am not sure if it is a proper one.
One can also see there some resistors underneath the large fuse. What the hell is going on there?! I would not want anything near that beast at all! Also I find that airgap between the hot end of the 10A fuse and the bare metal of the com jack a bit small (measured: 3mm). Not sure, what is allowed there.
Also, they used different types of input connectors. Why? The com port and the voltage jack are massive tube types while the amp jacks are split types. The overall construction of the jacks looks good to me. All the pressure that might be applied when plugging in a connector goes into the supports on the back of the case, not stressing the soldered connections too much. Additional posts on the upper half of the case support the hole structure (Refer to picture 15 in my previous post).
For the rest of it, please take a closer look to the pictures above, I did not dive any deeper into the magic of proper DMM construction.
In the top right of picture 20 one can see one of too logic-ICs. There is one NAND and one NOR type (4001B and 4011B).
Pic 23: Detail main chip areaPic 24: Detail chip, powerconnector and oscillatorOn the opposite side of the board one finds a 40pin samsung branded package. This seems to be a microcontroller, although I could not find any information about it. For the type please see picture 24. This picture also shows in Detail the spring type battery connectors wich I like. Also the glued down oscillator can be seen. As far as I can tell there is nothing special happening there.
Pic 25: Detail empty pads and trimpotBut here it begins to get funny. I did not dive in there, but I suspect those empty pads R19-1 to R22-1 to be in parallel to their counterparts R19 to R22 (only followed the traces for 1). while the distance of the pads would fit the used smd resistors exactly they decided to make extra room for through hole resistors. But those would have to be mounted standing up! I can see absolutely no reason for that. There is room enough to mount them flat on the board. Any ideas?
Pic 26: Detail pads and gold platingPic 27: Detail display connectorFinally, on to the backside. Picture 26 shows the nice gold plated pads for the rotary switch and the softbuttons. Also one can see there is absolutly no single part on the backside of the board. The large double contacted pads for the softbuttons are a nice touch. I for sure will investigate that third one in the middle. I am interested to see if I could get a hold funktion for free with the existing firmware. Picture 27 gives a detail of the nice lined up pads for the display. As I said in the previous post: The display is only pressed on there (graphite pads, maybe? I cannot see any metal part there) and it works just fine.
So there is need for a conclusion... What can I say? The mechanical construction is pretty good for a simple meter. In fact - that is kind of overkill. There was paid much attention to detail which can also be seen on the inside. The PCB is also constructed well and designed with some thought. Just think of all those pads with several possibilities for the used part. What I don't understand is why they decided there is not so much thought needed in the input area. This just looks like an average everyday cheap meter to me while the rest looks and feels way better.
Again, feel free to request details, pictures or clarification. Comments are welcome, no matter if they are adressing the meter and teardown itself or my style of writing and showing it to you.
