Starting off with a $20 or less meter is fine for low voltage electronics work (there a bazillion of them out there,and nearly all except the absolute cheapest will give accurate enough readings for volts & ohms). I'd agree with the previous recommendation of watching Dave's $50 shootout even if the low end landscape has changed. The info in it will give you an idea of what's important to look for.
I recently got one of these to check out (I can't really explain why - I already have more meters than I know what to do with):
https://www.amazon.com/dp/B09M8641Y7 (note, there was a 20% off coupon checkbox when I bought - look for it if you decide to pull the trigger)
I haven't put it though all the paces yet, but initial impressions were good:
- within 1-2 counts on all V and Ohm measurements
- fast continuity buzzer (might need better probes for best results here)
- the NCV function works better than many other meters I've tried
- it has really good 1.5 to 12V battery test functions that load the battery and works better than the simple V check. For example, a marginal 12V "23A" battery I have shows as 11.5V on any meter's V function, but on this meter's 12V battery test with the load it shows 8.2V explaining why some of the functions of the device the battery is in don't work very well.
One minor downside is that there's no capacitance function. I haven't tested the current measurements.
But if you want a professional quality meter and are willing to spend up to around $100 USD (which isn't a bad price for a pro meter) the Brymen BM235 would be worth a look. Brymens aren't particularly easy to find in North America. Dave sells his own eevblog-branded version of the BM235 on the eevblog.com store part of this site, but it can also be had (for less than $100 USD including shipping) from
www.welectron.com.
Before ordering, email welectron for an "EEVBlog" discount code to save a few bucks.
