Author Topic: Multimeter safety voltages ?  (Read 5747 times)
Offline waelTopic starter
  • Country: eg
« on: June 02, 2018, 03:29:18 pm »
I'm kind of confused with multimeter voltages ratings. Each meter(attached) has two different voltages ratings printed on it. Anyone knows why ?
Please check the attachment.
The grey one is RadioShack 22-811
The green one is kyoritsu Kew 1011
Best regards,
Wael
Offline GEOelectronics
Re: Multimeter safety voltages ?
« Reply #1 on: June 02, 2018, 03:47:32 pm »
Some links to help:
http://www.ni.com/white-paper/5019/en/
and search online:
"ABC's of DMM safety" by Fluke
Geo>K0FF
The following users thanked this post: wael
Offline joeqsmith
« Reply #2 on: June 02, 2018, 04:27:04 pm »
Looks like there are four in the first picture.  One appears to be a case insulation rating, one the maximum the inputs to the meter and the other's safety.
Online Fungus
« Reply #3 on: June 03, 2018, 10:14:13 am »
The individual voltages apply to the parts of the meter where they're printed.
I see this one as the maximum voltage you should apply to that terminal when you're holding the meter in your hand (ie. YOU are the earth point at the bottom of that indicator)
The 600V indicated on that meter is obviously maximum 600V between COM and V.
« Last Edit: June 03, 2018, 10:16:10 am by Fungus »
Offline stj
« Reply #4 on: June 04, 2018, 10:40:59 am »
it does not state the maximum voltage when testing current.
a common problem, but dangerous.
Offline joeqsmith
« Reply #5 on: June 04, 2018, 11:56:38 am »
What if the meter is hung by a magnetic strap to a grounded panel?  Are you then allowed to exceed this, after all you are no longer the earth point?   I wonder how they test for this in a lab.  Hard to believe any meter would break down through the case at even a KV.
Online Fungus
« Reply #6 on: June 04, 2018, 12:03:45 pm »
Yep, it doesn't make much sense to me.
eg. Can you reverse the leads and be safe?
Offline stj
« Reply #7 on: June 04, 2018, 01:06:47 pm »
given most people will have a probe in each hand, i think any talk about insulation-breakdown should start with the probes and cable!
Offline Neilm
« Reply #8 on: June 05, 2018, 06:42:15 pm »
Clearance is the issue. If the distance through the case join is too low it will breakdown to your hand through the join of the case rather than punching through the plastic.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline joeqsmith
« Reply #9 on: June 05, 2018, 07:03:33 pm »
  • Country: eg
« Reply #10 on: June 05, 2018, 08:49:12 pm »
May be they mean the high transient voltage ? I don't know.....
Offline joeqsmith
« Reply #11 on: June 05, 2018, 11:52:05 pm »
The manual should be clear about what they mean.   Page 12, Page 16 6-1.
https://www.kew-ltd.co.jp/en/download/pdf/manual/english/1011_IM_92-1824C_E_L.pdf
Offline Neilm
« Reply #12 on: June 06, 2018, 06:12:47 pm »
I don't remember what transient is put onto a 300V cat III system - probably about 4kV. Lets say that would need 5mm clearance, so if there is something conductive within 5mm of the outside of the case through the join it could jump to the users hand if the transient happens.
Manuals tend to be written by marketing people who don't know the fine detail.
Online Fungus
« Reply #13 on: June 06, 2018, 06:33:32 pm »
Good guess:
Offline joeqsmith
« Reply #14 on: June 07, 2018, 12:51:56 am »
I linked the manual and provided the page numbers.  Was clear to me.    Still hard to believe any meter would break down through the case at even a KV.
Online JustMeHere
« Reply #15 on: June 07, 2018, 01:53:46 am »
I think it also has to do with the thing not turning into a fire cracker and physically blowing your hand off.
Offline joeqsmith
« Reply #16 on: June 07, 2018, 10:21:22 am »
 :horse: Why beat a dead horse?  I want to make sure that you and others are not reading more into what I posted than what is there.
Offline stj
« Reply #17 on: June 07, 2018, 10:38:53 am »
that gives me an idea,
what would change if you had the meter casing filled with sand???
would it kill an arc like a safety fuse does??
Offline joeqsmith
« Reply #18 on: June 07, 2018, 10:56:31 am »
:-DD :-DD :-DD :-DD :-DD
Ok, well lets assume it uses some new switch technology anyway.  Sand and those switches may not play well together.     If the traces are so close that is can jump, the sand would not do much to stop it.   Maybe they could fill it with oil rather than sand.   Or, maybe just design the meter to handle the transients?   :-DD   I vote your post the best post of the day!!  Most out of the box thinking I have seen in a while!
Online Fungus
« Reply #19 on: June 07, 2018, 01:50:30 pm »
The instructions are clear and match what the graphics on the meter are telling us.
But ... it makes no sense. In both cases the CAT rating is higher than the "potential to ground" rating.
Can I only measure a 600V DC circuit with this meter if the 'neutral' wire is at -300V DC relative to ground?
(in which case it isn't very neutral, it's actually quite hostile)
Offline stj
« Reply #20 on: June 07, 2018, 02:17:33 pm »
i didnt mean any perticular meter - just in general.
and obviously seals would be needed to stop it pouring out of the sockets  or destroying the switches.
maybe the case could have walls in it to seperate the socket area where the high voltage stuff is and just fill that with sand.
Offline joeqsmith
« Reply #21 on: June 07, 2018, 04:41:18 pm »
I can only assume a lack of stimulant on your part or mine.
From page 12:  Never make measurement on the circuit in which electrical potential to ground over 300V AC/DC exists.
From pate 16:   To avoid the danger of getting electrical shock, never make measurement on a circuit over 600V AC/DC. (electrical potential to ground 300V AC/DC)
Why do you feel you need -300V DC relative to ground to measure 600V DC?
Offline joeqsmith
« Reply #22 on: June 07, 2018, 04:48:29 pm »
I got the general statement from the get go.  If you kept the sand out of the switch, maybe just keep in mind that switches have a lot of copper and in some cases, contacts are very close to one another.   Expanding copper can be a fun thing to play with.  Could also be deadly.   Of course, there are other ways to skin this cat but never hurts to think outside the box.
https://youtu.be/xLDok9Sm07Q?list=PLZSS2ajxhiQAk2Q57Obdy-2yVNF-m_huu&t=110
Online Fungus
« Reply #23 on: June 07, 2018, 04:54:14 pm »
What if I don't know which is the positive and which is the negative wire? (There's a fault somewhere, right?)
I might connect the COM probe to the 600V wire without knowing it.
Offline joeqsmith
« Reply #24 on: June 07, 2018, 11:34:23 pm »
If you play with the energy levels I do, it won't matter much but then you wouldn't be posting in a thread about safety.  So we can assume you are working in CAT II DC and up.   To be honest, I am surprised that playing with this stuff you would not know a positive from a negative wire.  Or for that matter, use equipment that was not certified.  That said,  your interpretation of the manual is the same as mine.    Normally, I if have a question about production, I turn to the manufacture.  This may be one of those cases.  Let me know what they have to say.   :-DD :-DD
