Author Topic: Multimeter spreadsheet (80 manufacturers and over 400 meters listed)  (Read 583104 times)
Offline Wytnucls
Re: Multimeter spreadsheet (80 manufacturers and over 400 meters listed)
« Reply #525 on: March 21, 2021, 03:41:03 pm »
If you look at the column heading notes, you will see that the accuracy is limited to 3% for an objective comparison with other meters.
I will add a note for the Brymen to state that the accuracy is 4%+60 between 20 and 100 kHz, up to 60V only and above 30% of the range.
« Last Edit: March 21, 2021, 08:07:12 pm by Wytnucls »
The following users thanked this post: Trader
Offline Microdoser
« Reply #526 on: March 21, 2021, 08:47:43 pm »
Having just ordered a Brymen 867s I thought I would have a look at it here to compare, is the Brymen 867 in the list the same MM?
Offline Wytnucls
« Reply #527 on: March 21, 2021, 09:54:36 pm »
Yes, the only difference is the fuse voltage rating.
The following users thanked this post: Microdoser
Offline AtomicRob
« Reply #528 on: May 20, 2021, 05:16:20 am »
Thanks for maintaining this helpful spreadsheet. I've been using the handheld meters list to compare meters and I noticed a possible improvement to the formatting which makes it much easier to sort and filter. New guy here so apologies in advance if this idea has already been discussed and ruled out somewhere in the previous 22 pages.
In the current format, you can't really use the Excel Filter feature because column A includes both the model numbers and the brand. If instead there was a new column added to the left side for the brand, then it's possible to use the Filter feature and be able to specify criteria. For example you could select only certain brands, and then filter again on the accuracy, or price, etc. Screen shot included below.
« Last Edit: May 20, 2021, 05:18:16 am by AtomicRob »
Offline fqahmad66
« Reply #529 on: June 03, 2021, 02:59:25 am »
Thanks for your work. I have been using a TPI 153 for a long time and it is a very reliable meter.
https://www.testproductsintl.com/digital-multimeters-dmms/
Offline lastguy
« Reply #530 on: September 15, 2021, 08:31:59 pm »
I strongly recommend HT206D as it has 60/600A AC/DC clamp. It has no probe current, but you can short the probe with 0.1ohm then you get a 6A range with 0.1V/A drop. I got one from Aliexpress less than $30. I also have a Fluke and a Tek.
I clamped it on my Odyssey measure starting current 350A. I also use its MIN to get my battery drop voltage during start that is 7.4V, 2nd start 6.9V, my GS300 is 9V. These are best way to check for battery/starter status. As I know my Odyssey batter is weak, I charged it offline 48 hours and get better digit.
Offline Gmetal
« Reply #531 on: October 09, 2021, 06:22:47 am »
I think i noticed an error. The spreadsheet says the EEVblog Brymen 786 lacks NCV, while the Brymen 789 has it, but according to the manual, both have it? https://www.eevblog.com/files/BM786-Manual-Original-Jan2021.pdf
Am I missing something and there is a difference in functionality here?
(Was about to buy a 786 from Dave and just was trying to understand what the delta was to the 789).
Offline Wytnucls
« Reply #532 on: October 09, 2021, 07:13:51 am »
Well spotted. Both have it. The list will be corrected at the next edition.
