can you add a fuse in a multimeter on the 10 a line
Decent multimeters have a fuse on the 10A or 20A current input.
If you have a multimeter without a fuse, I would just buy a new multimeter. Most half decent multimeters from $30 upwards should have a fuse.
If you only need the fuse for low voltages, any of the cheap multimeters would be fine.
If you need fuses with full CAT III or CAT IV rating for 300V to 1000V, you probably should be looking at paying a bit more for a quality brand.
