The Cal output is really just to use as probe calibration. They are used to calibrate the probes for best square wave. Yours is off more than I would hope for but most of them are not accurate as freq standard, they are usually off quite a bit. The voltage is usually pretty good but although scopes are good volt meters they are not excellent volt meters,
