marmad, thanks for taking the time to clarify.
Actually, I've been suggesting exactly the same problem for the DS2000 when it's bandwidth is 300MHz;
Yes, I did see that. Which most would apparently prefer to ignore. "
Hey! I've got a 300MHz scope!"
200MHz is not an issue for it since it doesn't attempt to do sin(x)/x interpolation at sample rates below 1GSa/s...
Thanks. I wasn't aware of that. So it does linear reconstruction for 200MHz signals, when sampled at 500MSa/s.
I wondered how that differed from the 1000Z though, also in linear mode for 100MHz signals, sampled at 250MSa/s? You wrote, "
...2.5 samples per period are not enough for an accurate linear reconstruction, pretty or not."
[This is one example of what puzzled me about your original posts. You appeared to be singling out the 1000-series for criticisms, that applied equally well to the 2000; which you'd never been concerned about. E.g., I had never heard you say about a DS2202,
"it's not a 2-channel 200MHz BW DSO".
But of course, the DS2000 goes one step further, by offering double the sample rate, because it's not trying to mux one ADC 4 ways (to save costs). So there you get 5 samples per period, instead of 2.5, and that's enough for reliable sin(x)/x reconstruction of a 200MHz signal. So now I understand what you were getting at.]
The major stipulation for sin(x)/x interpolation (which is a mathematical formula imposed on the sample points as opposed to just connecting the dots) to function correctly (i.e. not introduce errors into the reconstruction) is that NO components above the Nyquist frequency be present in the sampled signal. That is the MAIN rule that must be followed (to reap the benefit of a lower sample rate to frequency ratio) - there are reams of literature about it.
Yep. Thanks for the review of Sampling Theory 101.
At 250MSa/s, the Nyquist frequency is 125MHz - and according to BW tests I've read about for the DS1000Z - frequencies >=125MHz do not seem to be adequately attenuated to make sin(x)/x interpolation a reliable option at that sample rate (i.e. there's no way to know for sure if it's introduced errors in the waveform).
You may be right about the 1074Z, rated at 70MHz, but actually only -3dB ~90MHz. You're certainly correct about the "100MHz" 1104Z, which is actually -3dB at ~160MHz. 250MSa/s is nowhere near adequate for sin(x)/x curve-fitting you can believe in, on a real or modded 1104Z. And therefore shouldn't be used in 4-channel mode.
So, just as the DS2000 automatically switches to linear interpolation at sample rates <=500MHz, I would suggest a DS1000Z owner that wants reliable signal reconstruction should switch to linear interpolation at sample rates <= 250MHz - or else - bandwidth-limit the signal to 20MHz. Either of those options, obviously, reduces the "effective reliably-interpolated maximum analog bandwidth" of the DSO when using all 4 channels.
It would certainly be nice to have some better control over the BW Limiting, especially considering the realities of sampling constraints. It's too bad the attenuator chip Rigol uses has only 20MHz and 100MHz rolloffs, at the low end. 80MHz and 50MHz would be handy to have.
You mean adequate when using an input filter designed to properly attenuate signals >=125MHz, don't you? Not only that, but a 2.5:1 ratio is actually fairly 'bottom-end':
Yes. And, yes.
From a LeCroy document on sin(x)/x interpolation:
"SinX interpolation works very well only when this ratio is greater than 2:1. 3:1 is a good ratio, with 4:1 usually working almost perfectly."
Again, the original 200MHz DS2000 only uses sin(x)/x when the ratio is 5:1 or greater.
Thanks! I've read a lot of LeCroy's stuff, but don't recall this. I liked the "
usually", and "
almost", with 4x.
I would have expected them to say, "
works very well" with >2.5:1 though, rather than 2:1. LeCroy uses good filters, but they're not brick-wall (because they'd introduce too much phase-shift in the pass-band).
In theory, 250MSa/s is (just) fast enough for a sin(x)/x reconstruction of 100MHz - but in the real (Rigol-designed-input-filter) world, I don't believe it is.
After reading your additional commentary, I'd have to agree with that conclusion.
Thanks again.
