Author Topic: Name an inexpensive DMM with True RMS?  (Read 549 times)
Offline cvanc
« on: June 21, 2019, 12:47:41 pm »
So, what are the trustworthy DMMs down in the "cheap" price range that do a good job of reading TRMS?
Thinking of getting a couple for a dedicated bench function... thanks.
Offline larsdenmark
Re: Name an inexpensive DMM with True RMS?
« Reply #1 on: June 21, 2019, 01:02:18 pm »
Uni-T 139A and upwards as well as Unit-T 61D and 61E are TRMS.
I think all Brymen multimeters that are not pocket multimeters are TRMS, but they are more expensive.
The Uni-T 61D or 61E may be the best options for bench work since they come with a USB-cable so you can collect data from the multimeters.
Offline djnz
« Reply #2 on: June 21, 2019, 01:48:25 pm »
ANENG 8008 / 8009.
Offline Electro Fan
« Reply #3 on: June 21, 2019, 08:00:30 pm »
ANENG 8008 / 8009.
+1 for Aneng 8008, especially for low voltage DC work.
(I'd exercise caution with AC/high voltage work - no particular reason other than to be cautious)
It used to be possible to find these, some times new in the box for about $20 but that might be difficult now:
https://www.ebay.com/itm/Radio-Shack-True-RMS-Digital-Multimeter-/333120171027?epid=1728461874&hash=item4d8f826c13%3Ag%3A1p8AAOSwMuBcjaOu&nma=true&si=2xqjpYdQs9bEIypK6ZayjxtoRtI%253D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557
After these, maybe Uni-T, and Brymen - just a matter your specific needs and budget.....
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #4 on: June 21, 2019, 08:15:54 pm »
Uni-T UT139C (the Amazon equivalent is only $20.00).
https://www.amazon.com/Digital-Multimeter-Synerky-Temperature-Measurement/dp/B077ZQ2Z5S
Well built meters and reasonable input protection. The design is several years old and it is proven to be quite a reliable DMM.
Up in the reasonably priced range would be the UT-61E with many more features, adds bargraph and remote logging, but its input protection is not great (if that is important to you).
The Anengs have a wide gap in the current range and not great input protection (if these are important for you). I would look at the Mestek DM91A before considering the Anengs.
Some interesting tests are at: https://lygte-info.dk/info/indexDMMReviews%20UK.html
Offline Fungus
« Reply #5 on: June 21, 2019, 08:30:50 pm »
Nobody's asked what bandwidth is needed yet?  :popcorn:
The following users thanked this post: 001, Damianos
