Author Topic: NanoVNA V2 aka S-A-A-2  (Read 105210 times)
Offline 0xdeadbeefTopic starter
« on: June 04, 2020, 08:39:40 am »
As it wasn't discussed here yet (AFAIK): there are "V2" versions of the NanoVNA popping up on eBay. On second look, this seems to be a different product developed be different people. Main benefit is a much wider frequency range (50kHz - 3GHz).
Some links:
https://groups.io/g/NanoVNAV2
https://www.tindie.com/products/hcxqsgroup/nanovna-v2
https://nanorfe.com/nanovna-v2.html
« Last Edit: August 06, 2020, 08:03:59 pm by 0xdeadbeef »
Online ch_scr
Re: NanoVNA V2 aka S-A-A-2
« Reply #1 on: June 18, 2020, 04:31:15 pm »
I have designed a case for the NanoVNA V2. It has space for a 18650 cell, stores the stylus and has a lanyard attachment point. It is held together with 4 2.5mm countersunk screws on the bottom. Enjoy!
Edit: I just learnt that the 4 LED's on the bottom show the state of charge. Easiest would be to print the case (or at least the bottom half) out of translucent plastic. Another alternative may be to drill some holes into the side. Let's see what else we can come up with?
« Last Edit: June 21, 2020, 02:54:00 pm by ch_scr »
The following users thanked this post: aargee, dr.diesel, Kean, JohnG
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #2 on: June 18, 2020, 05:21:26 pm »
Didn't notice this post until now. I was the layout and RF engineer on the nanovna V2 team. I can answer technical questions.
EDIT:
- Only the Tindie store and RTL-SDR blog store support the original developers and fund the development of V2/V3 and maintenance of the firmware and software. All Aliexpress and eBay sellers are selling clones which have fancier packaging but lack QC on the RF characteristics and performance can vary. None of them check for things like uncalibrated directivity.
- S-A-A-2 is a completely new design not based on the original NanoVNA by ttrftech. S-A-A-2 does not use harmonics; it uses 2x ADF4350 to cover up to 3GHz. The linearity and dynamic range are improved.
- S-A-A-2 design is open source, which means anyone can manufacture it. However, only HCXQS is supporting the original developers. Other major players in the NanoVNA space do not share their design files, and all are working on competing V3 (6GHz) designs.
- Official support group is at https://groups.io/g/NanoVNAV2
« Last Edit: August 07, 2020, 05:21:12 pm by OwO »
Email: OwOwOwOwO123@outlook.com
Offline ebclr
« Reply #3 on: June 18, 2020, 05:31:28 pm »
What are the improvements on V2
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #4 on: June 18, 2020, 05:38:46 pm »
Original nano goes up to 900MHz using the third harmonic, and V2 goes up to 3GHz using only the fundamental (no harmonics mode). The dynamic range is improved.
The following users thanked this post: cdev, jjoonathan, 2N3055, nuclearcat, syau
Offline dr.diesel
« Reply #5 on: June 18, 2020, 05:40:03 pm »
You just saved me some trouble, thanks for posting this!
Online ch_scr
« Reply #6 on: June 18, 2020, 06:15:27 pm »
I'm happy you like it. A 5.2mm Drill works well to get the Support out of the stylus hole and is just barely long enough. The 18650 cavity is slightly oversized, a piece of 5mm foam makes it fit nicely. You will propably need to kiss the bottom part with a file to make it snug but not jam with the top.
The following users thanked this post: dr.diesel
Offline edigi
  • Country: hu
« Reply #7 on: June 18, 2020, 06:42:39 pm »
There is also a newer improved version of the original NanoVNA (see picture), it has a 4" LCD, goes till 1.5GHz and RF performance is also somewhat improved.
Nevertheless I've also bought the V2, but it ships quite slow (it was 2 weeks) so probably it's still quite some time till I receive it.
I'd prefer a bigger LCD variant from the V2 though (my eyes are not the best anymore) and I'm probably not alone with this... Any chance for such version?
Offline Gandalf_Sr
« Reply #8 on: June 18, 2020, 08:00:11 pm »
I just ordered one from Tindie  :D
If at first you don't succeed, get a bigger hammer
Offline Noy
« Reply #9 on: June 18, 2020, 10:01:15 pm »
Hm, i ordered a few days/weeks ago from AliExpress "official" Kkmoon Store because tindie hasn't Stock.
Hope it is good quality and not "cheaper" manufactured. Are there parts that i should check? Can i get the housing alone anywhere? It was not offered from kkmoon Store.
Offline Gandalf_Sr
« Reply #10 on: June 18, 2020, 10:45:20 pm »
Tindie offered a case but it was the laser cut plexiglass.  I'm going to 3D print my own from the files above.
« Reply #11 on: June 18, 2020, 11:29:35 pm »
There are already versions with a 3.2" screen floating around.
https://www.amazon.de/Portable-Handheld-Analyser-50kHz-3GHz-Touchscreen/dp/B08B8VBRLT
Offline Noy
« Reply #12 on: June 18, 2020, 11:38:42 pm »
Take Care, might be  another Layout. Look for the Switch positions.
Offline bicycleguy
« Reply #13 on: June 19, 2020, 02:09:21 am »
Received mine from Tindie in only 48 days  :D  The cal kit was unavailable so I bought a $20 eBay one.
Seems pretty amazing even to a complete RF knob.  Bought a cheap RF Demo kit to play with but it seems to be made for <1GHz.  It has U.FL connectors on 18 little circuits including a short, open, load and thru so you can cal with the cables on.  Should have bought the one that included a prototype area.
@Owo  Just out of curiosity, the current draw seems to cycle between 350 to 390mA, what causes that?  Maybe the lower parts of the frequency band are using more parts?
As others noted the text on the display is way to small unless I'm using a headband magnifier (which I need to hook up the U.FLs |O )
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #14 on: June 19, 2020, 02:50:23 am »
Most aliexpress stores are selling clones, I know of only two stores (in addition to the Tindie store) that get their V2s from our manufacturing partner, which is "KaisayaHIFI audio Store" and "LusyaTechnology Store", but aliexpress sellers do switch sources often so I can't say these two stores are always going to be selling "original" units. KKmoon, tomtop, and the *tool stores have always sold clones.
However, most clones nowadays perform fine. V2 design is open source so there are many (I think at least 5) clone manufacturers. If you are curious, post a high res image of the bottom side of the board, and a zoomed in picture of U401 like here: https://imgur.com/a/BMDyw3p and I can usually identify the manufacturer.
Not sure, might have something to do with ADF4350 switching in/out between bands, newest firmware turns off the ADF4350 when not needed.
There will be a 4 inch display version soon, the firmware support is already there and it's just a matter of reworking the PCB layout for the larger size. If you are using the VNA on the bench and don't care about portability, you can already swap out the display for a 4inch one like this (search "ST7796S", make sure to get one with the 14-pin header and touch support, and you will also need to update the vna firmware):
1004665-0
« Last Edit: June 19, 2020, 02:57:29 am by OwO »
The following users thanked this post: KD0CAC John, thm_w, Gandalf_Sr, xzswq21
Offline Berni
  • Country: si
« Reply #15 on: June 19, 2020, 05:46:02 am »
Oh neat! I was waiting for the V2 to be out, thanks for the thread.
I bought the first version and was really impressed, so im definitely buying this one too. Perhaps il hack the larger display onto it too and 3D print a case. The small display on the first Nano VNA was indeed a bit annoying to work with using fingers.
Offline Gandalf_Sr
« Reply #16 on: June 19, 2020, 10:56:48 am »
@OwO
My NanoVNA V2 is on order from Tindie and I'm interested in doing a 4" LCD upgrade; I may come up with a 3D printable case to use the standard V2 PCB with the 4" display.
Please can you point me to the firmware that will handle the 4" display and instructions on how to load it?
Also, what voltage is the battery? Is it a single cell 3.7-4.2V LiPo? (I don't find this information anywhere in the user manual) Can you recommend a specific battery?
« Last Edit: June 19, 2020, 11:04:26 am by Gandalf_Sr »
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #17 on: June 19, 2020, 11:17:55 am »
The git version has 4 inch display support but there is no binary released yet; I'll go do a release right now. https://github.com/nanovna/NanoVNA-V2-firmware
The battery is any li-ion battery (3.6V and 3.7V cells are the same thing, they are all 3.0 - 4.2V). The dimensions should be 6*40*60 mm to fit in the device, usually labeled as "604060", or use that enclosure that supports a 18650 cell (I would go this route because 18650s are generally safer).
The following users thanked this post: cdev, dr.diesel, Gandalf_Sr, Jacon
Offline Gandalf_Sr
« Reply #18 on: June 19, 2020, 11:43:23 am »
@OwO
Thanks :D  I already have some 18650 LiPos and single 18650 LiPo holders so I'll use one of those as you recommended.  I think I already have the 4" display too but I need to wait until I get home to check it's the one you're suggesting.  I have a Kirkby VNA SMA Cal kit which includes Open, Short, and Through connectors in male and female; am I right in thinking these will be suitable for use with the NanoVNA V2?
Offline edigi
  • Country: hu
« Reply #19 on: June 19, 2020, 11:57:32 am »
Note: In the newer version of the original NanoVNA it's not just the display size 4" but resolution is slightly better (480x320).
(I've just noticed that the picture that I've inserted has incorrect file name...)
The following users thanked this post: Gandalf_Sr
Offline Gandalf_Sr
« Reply #20 on: June 19, 2020, 03:56:07 pm »
Thanks, I just ordered a 4 inch display from AliExpress, this one https://www.aliexpress.com/item/4000946111830.html?spm=a2g0s.12269583.0.0.64a42129rATwwR
When I download the binary-st7796.bin file what program do I use to program the NanoVNA without loading IDEs and compiling?
Offline bicycleguy
« Reply #21 on: June 19, 2020, 04:38:57 pm »
Great update:
Larger text on the 2.8" display makes a huge difference.
The noise floor is improved.
The power consumption below 140MHz dropped from ~380mA to ~180mA
Maybe the 4" won't be worth my time, especially since its really only 3.5":
https://www.aliexpress.com/item/4000234986822.html
Edit: The display on Gandalf_Sr post looks to be actually 4".
« Last Edit: June 19, 2020, 05:03:28 pm by bicycleguy »
Offline Hydron
« Reply #22 on: June 19, 2020, 05:03:11 pm »
Does anyone know how the Tindie store units are being declared for shipping? I'd be OK with the VAT bill, but TNT charge like wounded bulls for "admin fees" on top when collecting it - at 20 quid it's over twice the VAT due :(
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #23 on: June 19, 2020, 05:22:35 pm »
Yes, any good SMA cal kit will do. If it has kit parameters in S parameter form you can import that into NanoVNA-QT, but the on-device calibration doesn't support kit parameters yet.
NanoVNA-QT can do the firmware update, and on Linux (maybe also mac os) you can use dfu.py: https://github.com/nanovna/NanoVNA-V2-firmware/blob/master/dfu.py
I'm pretty sure they under declare it to less than $20, but that doesn't mean you get a VAT bill, it depends on the country but I've heard DHL tends to ask for proof of purchase. After the pandemic is over and shipping times return to normal they will probably offer cheap ePacket shipping again.
Online ch_scr
« Reply #24 on: June 21, 2020, 08:45:51 am »
It should be mentioned: this is a really nice device :-+ Good work!
I have two questions: Is there a way to see the battery level on the device? Will it charge (and with how much current) from USB?
Offline Gandalf_Sr
« Reply #25 on: June 21, 2020, 10:00:38 am »
I don't have mine yet but I did read the user guide.
Battery level isn't displayed on the LCD, instead there are 4 LEDs on the left of the PCB which indicate battery level.
The batteries do charge and the max charge current is 1.2A
At least that's what the user guide says.
Online ch_scr
« Reply #26 on: June 21, 2020, 10:54:17 am »
It's almost as if I should have read the user guide first! :palm: Thanks for the clarification.
Offline Gandalf_Sr
« Reply #27 on: June 21, 2020, 11:15:33 am »
You're welcome  ^-^
Online ch_scr
« Reply #28 on: June 23, 2020, 01:57:40 pm »
I've made a small test fixture for 0805-size parts (should work for smaller parts as well), to use the NanoVNA as LCR meter. The pogo pins used are "P160-H2" from ebay, but the SHORT cal would benefit from something higher quality. Yes, the pogo pin heads are cross drilled with a 0.6mm PCB drill to help grab them with tweezers, that was a lot easier to do than expected as well. If you are interested in self resonance of SMD parts for e.g. filter construction something like this is highly recommended. The OPEN is a piece of 2.9mm white PLA, the LOAD are two 100R 0805 soldered in parallel.
Offline insine
« Reply #29 on: June 23, 2020, 02:10:52 pm »
Show us some measurement results :)
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #30 on: June 23, 2020, 07:27:03 pm »
any plan to build NanoVNA 6GHz version?
Offline Bud
« Reply #31 on: June 23, 2020, 08:08:21 pm »
What is the specification figure for Total Measurement Uncertainty ?
Offline Bud
« Reply #32 on: June 23, 2020, 08:22:29 pm »
Lets be real, at this level of the hardware your measurements will not differ much from those taken using a kettle and a pot.
Online ch_scr
« Reply #33 on: June 23, 2020, 08:46:18 pm »
The following users thanked this post: cdev, thm_w
  • Country: my
« Reply #34 on: June 23, 2020, 10:29:08 pm »
probably the 5,6 figure price HP or R&S brand too... if price is right, i want to compare with my Deepace KC901 VNA. 2 devices to confirm each other is better than 1. sub $100 GHz VNA was never be seen before. and recently w2aew published series of videos using NanoVNA, i think he got excited with it.
https://www.tindie.com/products/hcxqsgroup/nanovna-v2/
« Last Edit: June 24, 2020, 10:56:48 am by Mechatrommer »
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #35 on: June 24, 2020, 03:27:17 am »
Trace noise is 0.1dB typ and nonlinearity error is also ~0.1dB, and phase error is +/- 2 degrees max, at 0dB reflection magnitude. If you use perfect calibration kits that is the total measurement uncertainty for S11. Most of the time, however, the cal kits and cables are the bottleneck.
These specs apply to devices from the official manufacturer ("HCXQS" on Tindie), I have not yet characterized the clones.
Offline Berni
  • Country: si
« Reply #36 on: June 24, 2020, 05:28:50 am »
I gave a shot at ordering one from Bandgood:
https://www.banggood.com/NanoVNA-V2-3G-50KHz-3GHz-Vector-Network-Analyzer-Tester-Antenna-Analyzer-Shortwave-S-A-A-2-Nano-Vna-HF-VHF-UHF-Cable-Tracker-p-1690543.html?rmmds=search&ID=511646&cur_warehouse=CN
Mostly because Banggood tends to be good at dodging under customs in my country. Hopefully its not a crappy performing clone.
Online ch_scr
« Reply #37 on: June 24, 2020, 09:31:40 am »
I had a play with this, and the bottom-of-the-barrel pogo-pin made the SHORT cal infuriating. Once i got it to play ball, measurements looked reasonable.
I suspect something like the "INGUN GKS-002 206 191 A 2800" would be the next logical step up. Hmm.
Offline Gandalf_Sr
« Reply #38 on: June 24, 2020, 09:37:57 am »
It's not clear from what you wrote but I think you meant at 6GHz, right?
Offline Gandalf_Sr
« Reply #39 on: June 24, 2020, 10:41:10 am »
So my new NanoVNA V2 (S-A-A-2) arrived (very fast shipping) from Tindie and, apart from loads of flux around the through hole parts, it looks really nice.  I cleaned the PCB and fitted a 1.2 AHr battery that I already had (from HobbyKing) and that battery includes a protection circuit; in <24 hrs of testing, it seems to charge and run the VNA fine.  I didn't have the right JST-XH connector so I used a 2-pin breakable header which works fine but runs the risk of reverse polarity if I'm not very careful.
[EDIT] I fixed the R&L link...
Then I saw that R&L are selling what appears to be my VNA but with cables, Cal items (open, short, & load), and fitted with a battery, for $60.  I wish I'd known that before paying $25 to ship from China with no cables etc.
I like the NanoVNA but my old eyes find that the tiny fonts are at the limits of what I can manage so I'm happy that I've ordered a 4" display.
Here's a few pictures of my unit testing a log periodic PCB antenna (0.4-1 GHz).
« Last Edit: June 24, 2020, 08:07:08 pm by Gandalf_Sr »
  • Country: my
« Reply #40 on: June 24, 2020, 11:01:24 am »
is this the authorized seller? (corrected the above link) any other authorized seller in aliexpress?
i think thats V1 1.5GHz max version like w2aew demo'ed
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #41 on: June 24, 2020, 11:09:12 am »
Only the Tindie store is official. Aliexpress, ebay, etc are mostly selling clones. R&L is probably selling Hugen manufactured units (speculation; hugen himself hasn't yet confirmed this). Only the Tindie and nanorfe store provide funding to the development team, but V2s from other manufacturers generally perform fine. Banggood seems to sell a mix of official devices and clones.
EDIT: I'm not so sure that R&L is selling hugen units because the pricing doesn't check out. The V2 is basically selling at the same price as the original Nano ($55 vs $50), even more so if you take into account the cable cost difference (the "low end" V2 bundle has a more expensive cable than the original Nano). I know for a fact that the BOM and manufacturing cost of the V2 is around double the original Nano, so whoever is supplying these units to R&L seems to be selling at extremely thin margins.
« Last Edit: June 24, 2020, 05:11:27 pm by OwO »
Offline JohnG
« Reply #42 on: June 24, 2020, 10:51:21 pm »
- S-A-A-2 design is open source, which means anyone can manufacture it. Most clones perform fine, but please consider buying from the official stores if you want to support our development team. Other major players in the NanoVNA space do not share their design files, and all 3 of us are working on competing V3 (6GHz) designs. Please support us if you want to see an open source V3 rather than a proprietary one.
I bought mine from Tindie, $64 shipped. I am happy to pay a few extra $$ and have an open source design. For one thing, the longevity and the device itself can be improved by those who know how. After all, that approach is a major reason we have this in the first place. And I, for one, would really like to see an open source 6 GHz version, either with higher accuracy, or perhaps the option to get higher accuracy built into the design for those who are happy to buy more expensive parts or do crazy things like mount resistors upside down.
Many thanks to the designer!
Cheers,
John
"Reality is that which, when you quit believing in it, doesn't go away." Philip K. Dick (RIP).
  • Country: my
« Reply #43 on: June 25, 2020, 01:54:55 am »
put it in Crowd Fund or Kickstarter, if the price is within $200 (depending on my financial condition/recovery state ie when the timing is right) i will get one, the cheaper the better :P. i dont have Kickstarter account nor Crowdfund to do the "backing" stuff. but i bought Erasynth Micro from Crowdfund (Crowd Supply) after backing/production period. it seems they keep producing it for future customers. keep us informed :-+
ps: err sorry to say... if you keep everything open (incl pcb gerber files), inevitably you will be doomed by cloners from your own flag, imho... not really a problem if that is your intention.. cheers.
« Last Edit: June 25, 2020, 02:22:30 am by Mechatrommer »
Offline 0culus
« Reply #44 on: June 25, 2020, 03:52:17 am »
I noted that you guys had them in stock again on Tindie so I took the plunge and ordered one. Can't wait to get it.  :-+ Yeah. it's not an 8510C (I am still planning to add one to my lab in order to have capability in the bands I want to work in), but this costs less than $100 and fits in your hand. Hard to argue with the what you're getting for the money based on everything I've read.
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #45 on: June 25, 2020, 04:02:54 am »
Yeah, clones are going to come out whether or not you publish the layout files ;) The original nano didn't have any publicly released layouts or gerbers, but it's cloned to death. Difference is that V2 clones tend to perform ok since they learned to use the published layouts rather than doing PCB copying. https://gitlab.com/bepissneks/S-A-A
I don't have a problem with clones as long as users can tell what they are getting.
Look forward to a 6GHz design soon. There are 3 competing players all working on their own 6GHz design; one of them even hired edy555/ttrftech. How come they are paying to develop their own design rather than wait for the OwOComm one and just clone it (which is allowed)? That is left as an exercise to the reader ;)
« Last Edit: June 25, 2020, 04:07:46 am by OwO »
The following users thanked this post: thm_w, exe
Offline Noy
« Reply #46 on: June 25, 2020, 09:12:12 am »
Hi, does somebody can tell me the pcb dimensions?
I have to order some parts and will save shipping costs. I will order a nice case for my nanovna v2 which is still in transit...
I will remove the display because i don't need it. Will use it as desktop device with the pc software without battery...
Offline rudolf
« Reply #47 on: June 25, 2020, 11:48:20 am »
Hello Noy,
The dimensions are 90 x 50 x 25 (no display: 20) mm.
73, Rudi DL5FA
Offline Noy
« Reply #48 on: June 25, 2020, 12:14:50 pm »
Hm, i cannot find any suitable case for this dimension.
Anybody an idea?
Offline Gandalf_Sr
« Reply #49 on: June 25, 2020, 12:32:24 pm »
Anybody an idea?
I'm waiting for my 4 inch display to arrive and then I plan to update the firmware and test. If it works well (and I can read the fonts), I plan to design a 3D-printable case for the S-A-A-2 with the 4" display that I posted a picture of earlier.
Offline Noy
« Reply #50 on: June 25, 2020, 01:05:23 pm »
My 3D printer is taken apart  ::)... so currently i have to buy the box unfortunally..
Offline Gandalf_Sr
« Reply #51 on: June 25, 2020, 02:12:27 pm »
Maybe you can send files to an online company to print them for you?
Offline G0MJW
  • Mike
    • G0MJW
« Reply #52 on: June 29, 2020, 10:26:49 pm »
Can you slow the development down a bit, I can't keep up! 0.9 GHz, now 4.4 GHz, next 6 GHz.
Mike
Offline Noy
« Reply #53 on: July 13, 2020, 10:14:04 am »
my KKMOON Store version arrived (green tax sticker).
I took some pictures with the shielding dismounted please find attached.
It's "working" (only switched it on).
Offline Noy
« Reply #54 on: July 13, 2020, 10:14:34 am »
Second picture (size limitation per post...)
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #55 on: July 13, 2020, 11:01:57 am »
Thanks for the pictures! This one is a well known clone, but I'm still unsure about who actually manufactures it. Do you remember when your order was shipped? Can you check the firmware build time (in CONFIG > VERSION)?
Offline Noy
« Reply #56 on: July 13, 2020, 11:54:42 am »
Of course:
Aliexpress says:
Ordered: 25.5.2020 19:46 (German Time)
Shipped: 01.06.2020 18:01 (Tracking info start)
Version shown in picture.
Offline Kean
    • Kean Electronics
« Reply #57 on: July 13, 2020, 04:21:21 pm »
I am just wondering why you say "This one is a well known clone"?  What stands out to you that is different?
I compared the photos with my one that I received last week from the recommended Tindie store.  Without taking the shields off, the PCB layout and silkscreen, as well as SMD parts, look identical.
The only differences I see are the electrolytic caps - mine is missing C712 near the buttons, and the other is different brand/value.  Oh, and the addition of a battery connector on mine.
Mine has almost identical firmware version display except being git-20200607-7980406 built on May 29.
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #58 on: July 13, 2020, 05:00:34 pm »
This clone is known for its 8 extraneous shield clips and 2 electrolytic caps. There are a lot of other subtle differences in the components used. I can usually tell whether a board is a clone with certainty by looking at the PCB bottom side, but I'm still unsure which clone types are made by whom. Once I can get a look at some clones manufactured in June or later I'll get closer to knowing who is responsible for these clones.
The following users thanked this post: KD0CAC John, Kean
Offline Noy
« Reply #59 on: July 13, 2020, 05:11:03 pm »
Performance difference would be interesting.
Only passive components can be different.
Are there critical ones for a good performance which should i check (LCR meter)?
Some of the IC markings are a bit "washed out" maybe they started a second life in this clones. 😉😂
I think it was 53,91€ inkl. shipping.
I ordered there because tindie hasn't got Stock.
« Last Edit: July 13, 2020, 05:13:52 pm by Noy »
Offline Kean
    • Kean Electronics
« Reply #60 on: July 13, 2020, 05:23:45 pm »
Thanks.  Yeah, I had also noticed what looked like extra shield clips.
I guess if they don't have much attention to detail with things like that, then we also can't know what cheap alternative SMD parts they've picked up at the local markets.
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #61 on: July 13, 2020, 05:44:10 pm »
The clones are fine on average since they use the published board designs, but there is a little known detail which is that the directional coupler does not have perfect yield, it is in the range of 80-90% depending on the baluns used. The rest do not pass the directivity test and have to be repaired. If this QC step is not done you can have 10-20% of devices with worse S11 trace noise. If unsure, do a SOL calibration up to 2.7GHz and keep the 50ohm load standard attached, the S11 noise floor should be around -40dB or less.
The SI5351 markings look faded but that could just be due to the double sided reflow process (board is placed on some "paper" on second reflow).
The following users thanked this post: KD0CAC John, thm_w, Kean
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #62 on: July 13, 2020, 05:53:08 pm »
The yield is something like
80% if using YB006T-1023A
90% if using 617DB-1023=P3 from TOKO
>95% if using CX2156NL from PULSE
The device in the last picture has TOKO baluns, which is what everyone including clones used until all stock is depleted (in May). That balun is no longer in production, but one particular clone manufacture bought a large amount of it. If a clone is still using TOKO baluns in June, that is very good indication of who is behind it. Official devices have now moved to CX2156NL but this is much more expensive (3x price increase).
Offline Kean
    • Kean Electronics
« Reply #63 on: July 13, 2020, 07:39:09 pm »
And which is end of life...
Popped the shield on mine and the baluns look very similar to the above photo but with golden instead of red enamelled wire.
And I just cracked the LCD  |O
Offline bicycleguy
« Reply #64 on: July 13, 2020, 08:14:22 pm »
 :-DD Sorry, but now you have an excuse to get the larger display.
Offline Kean
    • Kean Electronics
« Reply #65 on: July 13, 2020, 08:21:33 pm »
Yep!  I've just ordered a couple of the 4" ones linked by Gandalf_Sr above.   :-+
Offline Gandalf_Sr
« Reply #66 on: July 13, 2020, 10:43:58 pm »
Sorry guys, I haven't got round to loading the firmware and trying the new 4" LCD. I have plugged it into my NanoVNA V2 and it will physically work if I design a special case for it.
Online czorgormez
  • Country: tr
« Reply #67 on: July 13, 2020, 11:10:10 pm »
hi gabriel.
i am planning to buy V2 from bang good. which is the only option for me to avoiding tax problems at customs.
are they selling clones ? do you have idea.
Offline Berni
  • Country: si
« Reply #68 on: July 14, 2020, 05:20:21 am »
I ordered one on banggood but they only shipped it recently so it will still take some time to get here.
Will post some photos of it when it gets here.
Offline Berni
  • Country: si
« Reply #69 on: July 14, 2020, 06:21:59 pm »
The one i ordered from banggood just arrived:
Attached are the photos with the shields removed and placed above the PCB. The screenshot is a 1Mhz to 3GHz sweep with Open Short Load calibration showing -43dB up to 2.7GHz. It arrived with a resistive touchscreen pen as the only accessory
The following users thanked this post: Kean
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #70 on: July 15, 2020, 03:32:39 am »
That one looks good. It doesn't seem to be a clone (although I can't guarantee they don't mix clones with original units like "Shop5371093 Store" did).
The following users thanked this post: Berni, Kean
Offline Kean
    • Kean Electronics
« Reply #71 on: July 15, 2020, 04:05:59 am »
Yes, that looks just like the one I got from the Tindie store with the differences highlighted by OwO/Gabriel.
From the earlier photo of the suspected clone, the TOKO baluns seem to have a slightly different base with small protrusions which don't exist on the Pulse balun.  That matches photos of the TOKO part on AliExpress and diagrams in the corresponding datasheets.  I took a closer look at the baluns on mine, and the enamelled wires are actually red, they just look golden when viewed from directly above.  They don't have the protrusions so I'm pretty sure they are the Pulse balun.
Offline edigi
  • Country: hu
« Reply #72 on: July 15, 2020, 12:05:20 pm »
I've also received my NanoVNA v2 (in the menu shown as version 2.2) and after calibrating it with the received cal kit to 2.5, 3.2 and 4.4 GHz (the max) I've made a quick test with my SMA attenuators (40 and 50dB).
Result pictures attached.
Note to previous posts: If you don't see a C<number> in my understanding it's not calibrated.
I think it's pretty OK till 3GHz.
« Last Edit: July 15, 2020, 12:23:06 pm by edigi »
Offline edigi
  • Country: hu
« Reply #73 on: July 15, 2020, 04:14:33 pm »
I've decided to push the attenuation to the limits of the NanoVNA meaning 60 and 65dB.
With this attenuation the noise shows up quite remarkably in almost all frequencies. Maybe averaging could help...
This is where the older (v1) version of the NanoVNA can still compete. It has less noise in case of low frequencies.
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #74 on: July 15, 2020, 05:41:12 pm »
Latest firmware has some noise improvements at lower frequencies using AGC.
Offline cdev
« Reply #75 on: July 15, 2020, 10:08:51 pm »
I now have an SAA2 and its great. But I am having a problem using the software on Linux. The software starts with the menus on the top greyed out, and doesnt recognize (it doesnt even show the menu) or put the VNA into USB mode, unless I start it as root.
Ive compiled it properly because it does run as a privileged user.
It likely needs a udev.rules file, so I have been trying to figure out the magic incantation that works..
The only thing I can think of is I have tried an awful lot of software- I have at various times both installed from debs and source, a great many other programs (one example, sigrok another FX2prog) that use the Cypress FX2 in various ways installed. Also I have been playing around with installing other software ion the $2 stlink 2 clones.
Perhaps some interaction between them?
But anyway, the nanovna2 has been a lot of fun for me so far and Ive been like everybody else, taking all my old antennas and homemade patch cables and retesting them and making some new ones :)
« Last Edit: July 15, 2020, 10:17:46 pm by cdev »
Offline 1anX
« Reply #76 on: July 16, 2020, 12:17:58 am »
I have just ordered the V2 from Tindie and am looking at software and firmware for it.
It seems as I'm a win10 os user that both the vna_qt and NanoVNA Saver should work on the NanoVNA V2. Plenty of feedback for the original NanoVNA V1 and mentioned software but hard to find for the V2.
Has anyone run the vna_qt and Saver software on their V2 successfully?
Offline 0culus
« Reply #77 on: July 16, 2020, 01:24:45 am »
NanoVNA Saver works just fine with my V2...just make sure you have the latest version.
The following users thanked this post: 1anX
Offline edigi
  • Country: hu
« Reply #78 on: July 16, 2020, 06:39:13 am »
The drawing in CW mode seems to have some bug as the scale and Smith chart is at least missing.
Offline edigi
  • Country: hu
« Reply #79 on: July 16, 2020, 11:21:08 am »
The fonts have got better and there is indeed some noise improvement but it's not too big (I've used 60dB attenuation).
Offline edigi
  • Country: hu
« Reply #80 on: July 16, 2020, 06:24:22 pm »
I'm happy to report that 4" LCD change works like a charm (but due to lack of case I had to put back both the original LCD and firmware as well).
After the firmware upgrade although I could bring up the menu, I could not select menu points so probably some calibration is required after the change.
Strangely the 4" LCD without any firmware change shows a large part of the drawing (so the controllers must be indeed very similar).
When putting back the original firmware it has stuck around half so I had to restart it. Not even my calibrations were lost though.
I also did not expect to find a 2000mAh battery (which is glued to the back of the original LCD...).
OwO and others of this project created a really excellent piece of equipment.
« Last Edit: July 16, 2020, 06:27:08 pm by edigi »
The following users thanked this post: cdev, Kean
Offline flolic
  • Country: hr
    • http://filiplolic.com/
« Reply #81 on: July 16, 2020, 06:43:46 pm »
You need to calibrate new larger screen.
You can access calibration menu using push buttons.
Offline edigi
  • Country: hu
« Reply #82 on: July 17, 2020, 06:35:45 am »
I've found a new bug.
When multiple markers are used, higher frequencies turn to negative values (probably due to some number representation issue like signed 32bits).
Offline all_repair
« Reply #83 on: July 17, 2020, 08:13:14 am »
nanoLab is owned by Hugen.  He was the one that made nanoVNA popular by his offering.  Very fair guy that is worth supporting.  Get the nanoVNA H4, or wait for the 4 inch dsiplay for the S-A-A-22 which should be coming out soon.  Unless you totally connect it to your PC, 2.8inch display is too small.
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #84 on: July 17, 2020, 08:32:10 am »
No, the official taobao store for the V2 is "HCXQS group", same name as the Tindie store: https://item.taobao.com/item.htm?id=611527678459
Offline aristarchus
« Reply #85 on: July 17, 2020, 09:39:30 am »
+1
Got a NanoVNA H4 from hugen and all I can say is wow, he knows how to offer real quality.
Complete package, case, cables, calibration items, perfectly working, an end product not a half finished job.
Even now though he got an SSA-2 packaged with case, cables, SOLT and carrying bag.
https://world.taobao.com/item/620606324940.htm?spm=a21wu.11804641-tw.0.0.16ef5bedIxkuEg
I'll wait until he gets out with his own next package, as some posts say it will be an H4-like with 4"LCD, adding microSD storage, RTC and SI4432.
Anyway, there seems to be quite a few good products there in this VNA area that give users great low budget VFM performance, these are good VNA times  ;)
Offline Kean
    • Kean Electronics
« Reply #86 on: July 17, 2020, 11:28:10 am »
@OwO: do you take donations? I'd like to contribute 100 Yuan.
Ditto (20 AUD)
Offline Brumby
« Reply #87 on: July 17, 2020, 11:36:02 am »
I have NO justification for having one of these on my bench ....
..... but I'm getting an itch to acquire one.   :palm:
Offline aargee
« Reply #88 on: July 17, 2020, 12:38:56 pm »
Purchased one from the Tindie store, curious to play and experiment with RF, which I haven’t seriously looked at since my Uni days.
I went with the Tindie one for it’s more likely closer specifications. I’ll 3D print my own case.
Not easy, not hard, just need to be incentivised.
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #89 on: July 17, 2020, 12:58:20 pm »
So I went with the NanoLab one just for the preinstalled case and battery. Seems like a fair guy with decent product quality, unless there is a catch.
We don't take donations. Most of the cloners probably don't check for directivity, but for measuring antennas it really doesn't matter (20dB calibrated directivity is more than good enough). Hugen simply copied my board design verbatim and started selling it (which is fine), but he does seem to manipulate his order count on taobao in order to grab market share (look at the 20+ reviews from the same person on the same day).
The following users thanked this post: cdev, thm_w, blueskull
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #90 on: July 17, 2020, 01:37:43 pm »
I don't run the store so I can't comment on that. Can't you get an invoice from taobao/alipay directly?
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #91 on: July 17, 2020, 02:08:59 pm »
Well, I don't think they want to sell to the government. If you mean reimbursement as in buying something for work, don't you just take a screenshot of your orders page and use that as proof?
Offline dougg
« Reply #92 on: July 17, 2020, 02:40:31 pm »
With regard to not getting access with a non-root user it might be your non-root user's group permissions. On Ubuntu 20.04 I see:
$ ls -l /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 0 Jul 13 10:11 /dev/ttyUSB0
So that indicates the group name for ttyUSB0 is dialout. Then in /etc/group I (user: dougg) need this line:
dialout:x:20:dougg
before that edit (which needed root permissions) 'dougg' was not there. Then you may need to log out your user and log back in again before that takes effect.
Hope this helps.
Offline cdev
« Reply #93 on: July 17, 2020, 06:33:18 pm »
Well, I have to say, you have really done a huge thing by upping the quality and performance level of affordable VNAs the way you have. I have been basically been spending hours each day fooling around with mine. It really is giving life to the theory.
Online thinkfat
    • Matthias' Hackerstübchen
« Reply #94 on: July 21, 2020, 09:05:54 pm »
So, my S-A-A-2 was in the mailbox this morning. Complete with SOLT and two cables, had forgotten meanwhile that I didn't order the full kit including battery..
No problem, I have a battery going spare, just need to fix it up with a different JST connector.
First task was to measure a DiY WiFi antenna I made a long time ago. Seems to be fine, resonates where it should, proper, real 50 Ohms with a pico of inductance.
I even compiled the control software for Linux, but quite honestly, the device UI is easier to work with.
Kudos, this is a nice addition to my growing test gear collection.
Offline KD0CAC John
« Reply #95 on: July 21, 2020, 10:17:53 pm »
I went to the TaoBao web site to buy the nanoVNA SAA2 , 1st thing is most of it does not make sense , no fixed price -it says y 2.00 -378.00 .
I clicked on both [ at different times ] add to cart & buy now and do not see any response or cart or move to next step to buy ???
And no where that I can find a statement about screen size ?
Finely got to what looked like checkout , or close , seems like every page / click - it goes to another page in Chinese , even though each preceding page I click on english .
Too many things that I do not like to do , are adding up , 1 email , 2 phone number - defiantly not giving , 3 without giving all of the 1st two , it looks like the only way to pay is with there own payment Alipay what ever .
I get too many junk/phishing phone calls already and I do not trust too many payment methods attached to my card / bank .
Are there more standard methods ?
« Last Edit: July 21, 2020, 10:33:33 pm by KD0CAC John »
Offline cdev
« Reply #96 on: July 21, 2020, 10:45:52 pm »
I'd really love it if there was a metal case that took the larger size display.
I'm a bit worried about putting it in a plastic case, do the people with plastic 3D printed cases worry about it getting too hot?
  • Country: my
« Reply #97 on: July 22, 2020, 03:39:27 am »
Juat cancelled my order at Hugen, only to find your store cannot issue a tax invoice, making reimbursement impossible. So had to order from him again.
what the tax will be? $10-20.. use your imagination! what kind of big company that thinks that figure does matter?
Offline AlfBaz
« Reply #98 on: July 22, 2020, 07:19:50 am »
I purchased one from Tindie and it was here within 5 days :-+
I'm having a lot of fun with it and learning how to use it through w2aew's youtube channel.
I know nothing about vna's so excuse this probably dumb question.
Alan uses the original nanovna and in the calibration it shows the extra isolation calibration which doesn't appear in the s-a-a-2
I'm struggling to find information regarding this calibration. What is the purpose of it and why is it missing from the new version?
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #99 on: July 22, 2020, 10:16:42 am »
The isolation calibration step is now done automatically during Short and Open calibration. There are two stored leakage coefficients, since leakage is a function of reflection coefficient on port 1. This allows better correction of leakage than only measuring leakage with port 1 terminated.
The following users thanked this post: AlfBaz, ch_scr
Online thinkfat
« Reply #100 on: July 22, 2020, 10:21:48 am »
I've checked mine for noise floor, looks like it's OK, stays below -40dB between 50kHz and 2.7GHz. Are there other performance checks that could be performed?
Offline Berni
  • Country: si
« Reply #101 on: July 22, 2020, 10:40:31 am »
There are specs for it on the official website:
https://nanorfe.com/nanovna-v2.html#specifications
I wouldn't expect a lengthy 20 page datasheet of specs like you might get with a VNA from Keysight, but i suppose it does cover the major point pretty well. That return loss of port 2 should be easily measurable by connecting it to port 1 with a cable, but you do need a good 50 Ohm terminator to calibrate it for best results.
Offline 1anX
« Reply #102 on: July 22, 2020, 10:51:26 am »
I bought mine from Tindie! https://www.tindie.com/products/hcxqsgroup/nanovna-v2/
Follow the link its all in English language and easy to purchase from online with all the usual options.
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #103 on: July 22, 2020, 11:06:54 am »
Port 2 return loss isn't great in both original and clone devices at 3GHz, it's just an artifact of the old design from last year before I actually took a closer look at the transition tuning, but you can attach a 5dB or 6dB attenuator to improve that. In the next revision I'll improve it to 25dB across the whole range, but that will have to wait until all the current stock are sold which I hear is several months.
Online thinkfat
« Reply #104 on: July 22, 2020, 12:16:47 pm »
Decided to update the firmware and I'm quite happy with the bigger fonts. The noise level has maybe changed a bit, but I can hardly make it out.
The software update process is a bit unsettling however. It didn't work at all throught the Qt software. It took forever and the upload progress didn't change, so I interrupted it eventually and the device didn't boot up any more. So apparently it did something, but never showed what and never completed.
So, I went with the dfu.py script and that also didn't go terribly well. Initially, it found the device but then reported a read timeout and that the device wasn't in DFU mode (which it clearly was). Repeated trials eventually got it to show some dots but it got stuck along the way. I had to repeat the update a couple of times and I was at the brink of breaking out a soldering iron to populate the SWD header to recover the device when it finally completed. That is something that needs more care.
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #105 on: July 22, 2020, 12:37:53 pm »
That sounds like something else is writing to the serial port - maybe modem-manager or something like that? Which OS was this on?
Online thinkfat
« Reply #106 on: July 22, 2020, 12:41:03 pm »
Oh boy, yes. You're correct. There was a minicom lurking in the background. The ttyACM0 was previously something else and I forgot that I had the terminal program still running!
Offline 1anX
« Reply #107 on: July 24, 2020, 07:30:38 am »
Got my V2 so I tried out the software available for it. VNA_QT_Windows 10 works like a charm and nanoVNA Saver V 0.3.6 for Windows 10 also works, but a little bit trickier (flaky) to set up.
The little nanoVNA V2 worked really well, easy to set up and calibrate and quickly connected to vna_qt software.
I got the acrylic case included in the purchase as an easy way to put it in a protective box. Its fiddly to put together and to get the plastic film off the the cut shapes, but it works ok and the clear acrylic makes it easy to see the leds working. Just make sure you check the cut out slots for fit, as there are 2 different slot sizes. Trying to fit the thick plate into the narrow slot does not work out too well. Finally noticed the difference spun the plate around and screwed it in.
What a handly little easy to use analyser!
Offline cdev
« Reply #108 on: July 24, 2020, 11:25:18 pm »
I just love mine, I've been learning so much with it.
Is the pattern for the acrylic case online anywhere? I urgently need to make a case for mine.
« Last Edit: July 24, 2020, 11:27:00 pm by cdev »
Offline 1anX
« Reply #109 on: July 24, 2020, 11:46:13 pm »
If you have access to a 3D printer here is a link for the files to a really nice case!
https://www.prusaprinters.org/prints/30212-case-for-nanovna-v2
Offline Kean
    • Kean Electronics
« Reply #110 on: July 25, 2020, 03:30:22 pm »
I got my 4" replacement LCD (and a spare) the other day.  I programmed the latest firmware and it is working again.
The only problem I had was working out how to load the firmware from the VNA_QT app - it wasn't clear that you manually put the device into DFU mode first via the menu (via the buttons due to an uncalibrated touch screen), and then the VNA_QT app recognises it is in DFU mode and prompts to upload new firmware.
Anyway I'm happy as the 4" screen is a big improvement, but I definitely need to work out an enclosure of some sort now as there is otherwise no way to support the larger LCD.
Offline cdev
« Reply #111 on: July 25, 2020, 06:35:42 pm »
Thank you. Maybe I can figure out a way to make my own using something I have, it needs to be protected.
Offline Gandalf_Sr
« Reply #112 on: July 26, 2020, 03:10:01 pm »
I'm now ready to update the firmware on my Tindie-supplied S-A-A-2 so that it works with the new 4 inch display.  Can anyone please confirm the correct firmware location to apply?
Thanks :D
Offline Kean
    • Kean Electronics
« Reply #113 on: July 26, 2020, 04:01:58 pm »
Thanks :D
Use binary-st7796.bin from https://github.com/nanovna/NanoVNA-V2-firmware/releases/tag/20200619
Offline Gandalf_Sr
« Reply #114 on: July 26, 2020, 10:25:59 pm »
I plan to design a new 3D printed case for the stock S-A-A-2 with the 4" display but it's still on my to do list.  Do you have (or have access to) a 3D printer?
Offline mdkendall
« Reply #115 on: July 27, 2020, 01:54:01 am »
If anyone is interested, I made a couple of changes to the NanoVNA-QT software that I think are small improvements. First, I changed the number of frequency divisions in the main plot from nine to a more conventional ten. Second, I made some changes to the Sweep Parameters dialog to allow entering either start and stop or center and span, along with some minor fixes and tidying.
I only built the release for Windows I'm afraid, but the source is all there if anyone wants to build for Linux or Mac:
https://github.com/mdkendall/NanoVNA-QT
https://github.com/mdkendall/NanoVNA-QT/releases/latest
The following users thanked this post: KD0CAC John, Kean, 1anX, hwalker, 0culus
Offline ab#FFFF
« Reply #116 on: July 27, 2020, 05:04:39 am »
I've got 2 questions maybe someone can answer:
1. Why the lower frequency is limited to 50kHz? It is possible to go under that frequency?
2. There is an official NanoVNA V2 that comes with a 4" display?
Thanks,
-ab
Offline edigi
  • Country: hu
« Reply #117 on: July 27, 2020, 07:17:12 am »
In the latest version actually it's 10kHz but NanoVNA is fundamentally an RF tool and it's hard to handle such a wide frequency range (for example among others to separate the incident and the reflected signal).
If you're looking to check something below 50kHz with NanoVNAv2 probably you're looking the wrong tool.
The other end of the frequency range is more interesting actually.
Probably it's just a matter of time (I don't know about any at the moment although I'm not continuously checking it) since more of us from here made it working with the 4" display (and it required nothing more than plugging in a new LCD module and changing to a firmware supporting it that is readily available).
« Last Edit: July 27, 2020, 09:19:16 am by edigi »
The following users thanked this post: ab#FFFF
Offline Kean
    • Kean Electronics
« Reply #118 on: July 27, 2020, 12:18:22 pm »
[I plan to design a new 3D printed case for the stock S-A-A-2 with the 4" display but it's still on my to do list.  Do you have (or have access to) a 3D printer?
Yes, I have a few 3D printers here (ABS/PLA/Resin).  FWIW I use Fusion 360 for modelling.  I just won't have much free time over the next month or two.
Looking forward to see what you come up with.
Offline Gandalf_Sr
« Reply #119 on: July 28, 2020, 10:56:00 am »
No promises but I may get to it in the next week or so.  I taught myself FreeCAD (vn 0.16) and it does well for the price.
Offline Gandalf_Sr
« Reply #120 on: July 28, 2020, 02:40:05 pm »
So I got round to upgrading the firmware to the version that handles the 4 inch display.  For those who haven't done it before:
1. Get the new .bin file ready.
2. Plug in your NanoVNA and check which port it comes up on.
3. Turn the NanoVNA on and put it into DFU mode via touch menus.
4. Plug into USB port.
5. Run up NanoVNA_QT
6. Select the port under device
7. You should now see a pop up window that says found device in DFU mode, do you want to upgrade firmware (or something close to that)
8. Click [Yes], browse to .bin file, and click [OK]
9. When it's finished unplug and power off NanoVNA
10. Fit new display and power on, it should work.
I recalibrated my touch screen after the upgrade but it was close anyway so the menus worked.  I removed (carefully) an SD card reader that was fitted to my display as it interferes with the fit.  I must say that the larger display and font has made this very usable for me, much easier to read now.
This may inspire me to design a case for it :D
« Last Edit: September 14, 2020, 11:19:01 am by Gandalf_Sr »
Offline SHF
« Reply #121 on: July 28, 2020, 06:32:22 pm »
Hi  Gandalf_Sr where did you buy the 4 inch display for the nanovna?
Precision is no coincidence
Offline Gandalf_Sr
« Reply #122 on: July 28, 2020, 09:54:43 pm »
I got it from AliExpress, the link is in this post on the first page of this thread. That link is problematic, says item doesn't exist - [EDIT] removed link to one that doesn't have the touch panel. See next post below with a link to the correct display from Amazon.
I was not happy that my new display was not attached firmly to the NanoVNA and then I had an idea.  The posts that came with mine are brass so, with a really powerful soldering iron, it should be possible to scrape away the solder mask to reveal the copper on the display PCB, tin the exposed area, and then solder the posts on.  I did this and it works. See pictures.
« Last Edit: July 29, 2020, 01:04:58 pm by Gandalf_Sr »
Offline Kean
    • Kean Electronics
« Reply #123 on: July 29, 2020, 01:58:55 am »
I got it from AliExpress, the link is in this post on the first page of this thread. That link is problematic, says item doesn't exist - here it is.  It would be better if you could find it without the SD card holder but it's easy to remove it.
Except that new listing seems to not have the optional touch included.   :--
I also bought some of the ones in the original AliExpress listing which has now dissappeared.
Edit to add: as mentioned by someone earlier, when scanning listings for similar LCDs note that some sellers list the 3.5" ones as 4", so you need to review the specs/measurements
I was not happy that my new display was not attached firmly to the NanoVNA and then I had an idea.  The posts that came with mine are brass so, with a really powerful soldering iron, it should be possible to scrape away the copper on the display PCB, tin the exposed area, and then solder the posts on.  I did this and it works. See pictures.
Oh, neat idea.  I'll try that too.
« Last Edit: July 29, 2020, 02:00:45 am by Kean »
Offline Berni
  • Country: si
« Reply #124 on: July 29, 2020, 06:01:02 am »
Yeah i made the mistake of ordering the wrong one. Have not looked at the listing very much, mostly went off the photos. But then i got it and it turns out it doesn't have touch. :palm:
So yeah im gonna have to order a new one.
Offline Kean
    • Kean Electronics
« Reply #125 on: July 29, 2020, 06:55:10 am »
Not the end of the world - it can also be controlled via the 3 menu buttons, or over USB.
Offline Gandalf_Sr
« Reply #126 on: July 29, 2020, 09:27:59 am »
I found this one on Amazon https://www.amazon.com/480x320-Display-Module-ST7796S-Driver/dp/B08C5FFX9P/ref=sr_1_2?dchild=1&keywords=480x320+ST7796S&qid=1596014221&s=electronics&sr=1-2 from DONGKERUS
It looks just like the one I got but it's $19 :(
You'd also have to remove the SD card reader but that's no big deal IMHO.
[EDIT] I also just found this one on AliExpress, please check but I think it's the right one.
« Last Edit: July 29, 2020, 01:22:07 pm by Gandalf_Sr »
Offline Gandalf_Sr
« Reply #127 on: July 29, 2020, 11:50:36 am »
Can anyone point me to a dimensioned drawing of the V2 PCB (Tindie version) so I can work on my 3D printed case ideas?
Offline cdev
« Reply #128 on: July 29, 2020, 12:05:10 pm »
There is also a new, nice metal case being included with one of the NanoVNA clones.
I wish that an upgrade pacage was available with the case and the compatible screen. A larger size would be great, with a metal case and an appropriate substrate for the current nanovna.  Worth making, if anybody has metal fabrication skills.
It would be great to have a SD card slot for saving calibration setups long term while operating portable. That is a feature I would appreciate in the firmware a lot.
I am concerned about heat in a plastic case. Unless it has ventilation.
« Last Edit: July 29, 2020, 12:09:24 pm by cdev »
Offline Gandalf_Sr
« Reply #129 on: July 29, 2020, 12:29:00 pm »
The 4" display I'm using has a 4 pin connector at the left edge but there's no corresponding connector on the NanoVNA V2 so it's all redundant.  I will allow for air flow through my case design which, in case it's not obvious, is a design for the standard NanoVNA V2 with the 4" display fitted as per my recent pictures.
Offline AlfBaz
« Reply #130 on: July 29, 2020, 01:12:19 pm »
This sounds like a great little mechanical project. I have 2 of the 4" displays comming and I'm good with verniers and inventor.
I'm thinking maybe I can come up with a printed mount of sorts that can be used to mount into a standard extruded case.
If they're not here by the weekend I might try and model the parts anyway and see what, if anything, I can come up with
Offline Berni
  • Country: si
« Reply #131 on: July 29, 2020, 04:45:21 pm »
For my second try i ordered this display instead: https://www.aliexpress.com/item/4000966874873.html
Its 15 bucks with shipping from Europe.
Really made sure it has touch this time. So hope it works out.
Offline Gandalf_Sr
« Reply #132 on: July 29, 2020, 07:29:28 pm »
I think that's a good one, hope it works out for you.
Offline sn0w_gl0be
« Reply #133 on: July 30, 2020, 06:38:21 pm »
Hey everyone,
First post here (yay) after lurking for a little bit. Since the authorized dealer is on Tindie, is the one on Amazon by Aursinc just a fancy clone?
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #134 on: July 31, 2020, 04:21:19 am »
Yes all amazon, ebay, and aliexpress sellers are now selling bad clones. I'm getting emails about defective NanoVNA V2 devices every week now and they all turn out to be clones. If you have to buy a clone go for the 3.2'' version. This one has the least defect reports and seems to be well built.
Btw there will be a small hardware upgrade soon (1 month or so) that will allow 2x faster sweep and lower noise. It will be called V2-N and will only be released outside of China to keep off the clones for a while.
The following users thanked this post: wolfy007
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #135 on: July 31, 2020, 04:35:49 am »
Do you mind if I order an exception unit?
Just PM me for a free sample. I think I'll have a lot of prototypes ready in a few weeks.
The following users thanked this post: blueskull
Offline edigi
  • Country: hu
« Reply #136 on: July 31, 2020, 05:46:31 am »
I'm interested in it as well, but I'm also ready to pay for it.
Online thinkfat
« Reply #137 on: July 31, 2020, 08:09:07 am »
Layout change or just a BOM change? Something that could be retrofitted into an existing device?
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #138 on: July 31, 2020, 08:33:58 am »
It's a slight architectural change, so layout is modified and firmware support will need some work too. It's mainly ADF4350 fast lock, reworking the mixer signal path and noise reductions.
The following users thanked this post: thm_w, thinkfat
Offline Hydron
« Reply #139 on: July 31, 2020, 11:23:46 am »
Same here - price seems very fair for what it is, and I appreciate the efforts trying to stop people getting burnt by bad clones. Are there any plans for a case etc too? Or is 3d printing one the way to go?
Offline sn0w_gl0be
« Reply #140 on: July 31, 2020, 01:49:11 pm »
I'll echo this. I don't mind buying what would be my third NanoVNA (first official one) assuming it's ~$100.
Offline KD0CAC John
« Reply #141 on: July 31, 2020, 03:41:51 pm »
OwO ,
I have older eyes so the need for a larger screen 4" ?
Also no printer here so would like a case also .
I can wait , I would prefer to buy from You and or from at least one of the developers [ seems like there are 2 or more ? ]
Thanks for your efforts
Offline cdev
« Reply #142 on: July 31, 2020, 03:51:18 pm »
Gabriel,
Your organization should put together a case, 4 inch screen package with a "mother board" to mount both the existing NanoVNA and the posts to keep it all together on. You could sell it direct.
Frankly, I am so overjoyed to have such a useful tool, I want to support your efforts by buying all my accessories through you..
OwO ,
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #143 on: July 31, 2020, 03:57:17 pm »
I don't sell these, I'm just one of the engineers. I think the V2-N will be priced basically the same as the current V2 on Tindie.
There are plans for a 4 inch version, but it will be a major redesign and not just swapping in a 4 inch display (which I'll leave to the clones). The aim is 5x faster sweep (500 points/s). We might hire someone from here to do the enclosure design.
Offline KD0CAC John
« Reply #144 on: July 31, 2020, 05:46:43 pm »
Oh ok .
I have no problem if getting more / costs more , bigger screen for old eyes & case .
Hopefully I could get on a mailing list of this version of one of these ?
Just sold my Sark110 because the screen was too small , and saw these around - NanoVNA .
Have a miniVNA Pro , MFJ-269 , had a Timewave TZ-900 .
Besides what ever bench gear I can afford , mainly broken and get twice the fun out of them - learn how to fix and then use , the best of both worlds .
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #145 on: August 02, 2020, 11:37:04 am »
We are working on getting a 3D case included with the current 2.8 inch version and maybe even a battery. We didn't go with a metal enclosure because it was found to worsen port to port isolation.
The following users thanked this post: cdev, TimNJ
Online TimNJ
« Reply #146 on: August 03, 2020, 02:30:56 am »
I know you are not the seller, but can you suggest to make the case available standalone too? I would like to buy a case for my V2.
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #147 on: August 06, 2020, 06:24:54 pm »
So we ended up getting permission from one of the members of the community to use their 3D printed case design. I don't think it will be sold standalone but you can always just 3D print it.
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #148 on: August 06, 2020, 06:38:16 pm »
I have now prototypes of the 4 inch version with 400 points/s sweep rate. The noise floor stays at around -80dB up to 1.5GHz even with the faster sweep. The DSP code can go up to 500 points/s but the UI refresh almost doesn't keep up when the 4 inch display is used, so it'll have to be 400 points/s.
V2-N will be renamed to V2 Plus to avoid confusion with another NanoVNA variant. I think it'll be available in a week or two. The improvements are 200 points/s sweep (compared to 100 points/s for the current V2) and a bit lower noise floor.
The 3D enclosure and battery option will also be available in a week or two, maybe a bit earlier than the V2 Plus.
EDIT: typo
« Last Edit: August 08, 2020, 05:07:20 pm by OwO »
The following users thanked this post: KD0CAC John, dr.diesel, thm_w, Kean, phs, 2N3055, czorgormez
Online TimNJ
Re: NanoVNA V2 aka S-A-A-2
« Reply #149 on: August 06, 2020, 08:12:39 pm »
Are you referring to ch_scr's case, post #2 of this thread?
Offline cdev
« Reply #150 on: August 06, 2020, 11:19:53 pm »
I don't think V2-Plus is such a good name. Also, V2-N may be N now, but at some point there will be a newer N. I think you could probably think of a much better name.  You could have a numerical name that gives the most important specs, and a model name that has a kind of fun or endearing quality - which is unique. Try to think of some cultural name - maybe a character for a TV soap opera or manga or mythology you all like (if there is such a thing)  ????
bla bla bla.. Or at least thats what I think.
I totally know what you mean about a metal case sometimes causing problems. I am dealing with that right now with a LNA that I am trying to put into a nicer metal box. Its hard to get it right, where the box really makes a big improvement instead of making issues like unwanted USB-originating noise worse..  Because so many cases now have an anodized outer metal shell, (which doesnt conduct electricity!) they are really crap. The ones that look semi decent are more often than not crap. Here is what I am trying to do. Put a picece of copper - not coppper tape, on the inside to be the actual grounded thing. A c shaped piece of copper that connects to everything as if it was the case. It doesnt have to enclose it completely, the outer case is for the looks. And it conducts inside. Just not on its surface. The [iece of copper flashing is simply to create a common ground point thats very low impedance, between the two connectors (and the USB) thats  not the PCB.
That works with an LNA.
I need every bit of help I can get with my local RF noise.
Gradually the noise where I live has just been getting worse and worse. Some of it is not coming from here so its very hard to get rid of. I need to get a small radio and literally hunt its source down.
Try using a piece of metal to see if that makes the metal case work acceptably well. The two horns they have on that other case are nice to protect the connectors. They are likely trying to sell below their cost.
I have now prototypes of the 4 inch version with 400 points/s sweep rate. The noise floor stays at around -80dB up to 1.5GHz even with the faster sweep. The DSP code can go up to 500 points/s but the UI fresh almost doesn't keep up when the 4 inch display is used, so it'll have to be 400 points/s.
« Last Edit: August 07, 2020, 02:00:35 am by cdev »
Offline joeqsmith
« Reply #151 on: August 06, 2020, 11:32:56 pm »
Very nice.  For headless, can you get the data across the USB fast enough to run 500pps?
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #152 on: August 07, 2020, 05:22:57 pm »
Yes
Should be doable, but it's a bit more noisy at 500 points/s.
I think V2 Plus is a good name, there was "miniVNA Tiny plus" and "miniVNA Tiny plus2" ;)
Email: OwOwOwOwO123@outlook.com
The following users thanked this post: joeqsmith
Offline 0culus
« Reply #153 on: August 07, 2020, 05:59:47 pm »
Definitely gonna keep my eye on the store...of course it comes out right after I got a standard V2.  :-DD
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #154 on: August 07, 2020, 06:24:01 pm »
Yeah, the reason we have to push out a new design so fast is because others have started selling our V2 design at extremely thin margins and with fancier packaging. HCXQS had not even 6 months to sell the V2 before getting overtaken by clones. They are the only manufacturer supporting the developers, so please help us and keep reminding people that only HCXQS on Tindie is the official manufacturer and supports the original developers. We had to move to a new groups.io forum because the admins on the old nanovna-v2 forum (none of HCXQS people or I are admins, go figure) keep promoting a clone as if they are official.
New support group is here: https://groups.io/g/NanoVNAV2
The following users thanked this post: dr.diesel, thm_w, joeqsmith, thinkfat, syau, 0culus
Online thinkfat
« Reply #155 on: August 07, 2020, 08:03:27 pm »
When you have the new 4" design ready, I'll certainly buy from the tindie store. Just make sure they have stock ;) I only bought from Aliexpress because of that, but I made sure to check with you beforehand which store sells original equipment.
Offline avlijas.sladjan
  • Country: ba
« Reply #156 on: August 07, 2020, 08:15:38 pm »
Hi. I received V2, and it worked perfectly. I hope that mine is original, not clone (I will love to support real developer).
Before V2, I was working on my version of VNA (to have a small VNA for 25M-4G, together with nanoVNA v1), and make a v0.1 HW version + software/firmware (I implement nanoVNA command set to be compatible with NanoVNA saver software). But I found some bug in HW (PLL internal interference), and did not have time to fix and finish (covid stopped all work and post service). But after some time I see on aliexpress V2, and now my project doesn't make sense.
Thanks again for nanoVNA V2, it is very very good. Also, for better calibration, you can change load with some better (I use amphenol 18GHz 50ohm load), and that improves s11 measurement ;)
Offline JohnG
« Reply #157 on: August 07, 2020, 09:37:28 pm »
This can often be greatly helped by adhering a layer of carbon-impregnated anti-static foam to the inside of the case in strategic locations. The foam needs to be the black kind that DIP ICs and such used to come in. You should be able to measure some level of conductivity of the foam with an ohmmeter for it to work well.
John
Online TimNJ
« Reply #158 on: August 08, 2020, 03:43:16 am »
Yes
Not sure if you mean you (HCXQS) will ship units with ch_scr's case, or it'll just become it the official 3D printing recommendation.
Two pieces of feedback, and one already noted:
1. Battery status indicators not visible (Add holes?)
2. The space for the 18650 cell should be a little bit longer, at least 72mm on the inner dimensions. No one should be using an unprotected 18650 cell, unless the NanoVNA V2 has built in battery protection IC. If not,  need 18650 with protection PCB. The allocated space in this design is only 67.5mm.
Typical protected cell here: https://www.jauch.com/downloadfile/5c3d9cd710f29e9c09d67ef33e58d94ac/3350mah_-_li18650jp_1s1p_2_wires_70mm.pdf
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #159 on: August 08, 2020, 03:53:00 am »
Yes, we got permission to let HCXQS offer the case on Tindie with the V2. The 18650 hole is lengthened, and the batteries have the protection board on the side, so lengthening it by 2mm was enough.
The enclosure material is translucent white and you can see the indicator LEDs.
Online TimNJ
« Reply #160 on: August 08, 2020, 05:16:36 am »
Cool. In terms of "sell-ability", I strongly believe the translucent material gives off a "less premium" look. I know we're talking about a $60USD VNA, so perhaps trying to say it's a premium product is a bit of a contradiction...although I do believe the hardware is excellent!
Something funny about the red and green PCBs together makes it seem like someone's Arduino project. I am typically very aesthetically minded, so those are just my comments. An SLA print is best, but SLS probably cheaper, but should be media tumbled after to get anywhere near a finished looking product.
As others have said, although it's an engineering tool (and perhaps looks shouldn't matter as much), most people buying these are every-day people acting as consumers. When they see a shiny V2 clone in a beautiful case next to a genuine V2 which ironically looks a bit half-baked, it's a tough decision.
Offline aargee
« Reply #161 on: August 08, 2020, 05:47:08 am »
I made my case out of red PLA and the LEDs show through the case nicely.  :-+
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #162 on: August 08, 2020, 06:53:43 am »
Agreed, I'm going to forward your suggestion to do some post-processing on the 3D printed enclosure. Thanks!
The following users thanked this post: TimNJ
Offline cdev
« Reply #163 on: August 08, 2020, 03:45:18 pm »
I have quite a bit of experience trying to do this and it works with one caveat. The foam dries out in really hot environments and it may become problematic in the future. In order to work properly the popular wisdom is that it has to connect to metal on its backside but it can actually be put in a small thin plastic bag thats taped shut and then taped against the metal backing so that it wont deteriorate and cause shorting. This causes a significant improvement with LNAs input and output isolation. Also use ferrite beads on leads when its possible.
John
I also keep a bag of the larger picces of broken ferrites which I sometimes find useful. A couple of times its turned out to help with something, and is just what is needed.
Flat pieces are useful just as they are and C-shaped pieces - one half of a split bead, also may sometimes be very useful.
« Last Edit: August 10, 2020, 02:11:54 pm by cdev »
Offline JohnG
« Reply #164 on: August 09, 2020, 03:17:24 pm »
Yes, one probably doesn't want conductive carbon-coated particles on their PCB. Works pretty well for a quick and dirty lab setup, though.
I do recall taking apart an satellite dish LNA not too long ago. It had similar foam pads all over the place, above transmission lines, couplers, mixers, etc. They seemed to be a little more robust, and maybe the foam felt like it was silicone based. No dust whatsoever inside the LNA. So, this sort of foam should be available without the problems of the carbon-coated foam, but I have never looked for it.
John
Offline rf-loop
  • Country: cn
« Reply #165 on: August 10, 2020, 05:34:04 am »
My NanoVNA V2 clone is in "metal box hybrid" with 3.2".
All sides sides, including ports are metal.  Switches are not between ports. Top and bottom of case is more or less plated PCB.
Directivity. I have seen truckload of HP, Agilent RF things including of course also differerent VNA's
Partially bit  :P  but why they do not talk how metal case have some adverse effects...  they are metal and they are heavy and specially older ones all are deep inside aluminium casting.  They do not also tell that metal case destroy some values...  Of course they are expensive but what is real Root reason why peoples tell that metal case is bad. I like to hear Real reason. Where is this secret thing and why.  Is it perhaps so that there circuits are designed for "open air". Why they are dot designed so that metal case make it better instead of it give some negative effect.
I do not have seen any directly comparative images so I need ask how peoples who know more deeply this NanoVNA V2  think about this. Is this normal, more bad than normal or part of bit better group.  I am bit amazed overall how good this is related to price.
This question with image is also because I am really far from my homeland and I can not use my all tools so I really can not at this time make many kind of real tests with trusted data.
Attached image.
First done SOL Cal (CH0)
After then run sweep from 1MHz to 3GHz and CH0 just same  50ohm load used in cal directly in port. (no cables)
NanoVNA firmware: 20200619
NanoVNA-Saver 0.3.6
EV of course. Cars with smoke exhaust pipes - go to museum.
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #166 on: August 10, 2020, 05:54:25 am »
S21 is a little out of spec above 2.8GHz, but that's just due to reflections by the metal enclosure.
S11 looks good.
Offline rf-loop
  • Country: cn
« Reply #167 on: August 10, 2020, 08:10:29 am »
S11 looks good.
Tnx.
Here perfectly same but now without metal "box" what is not just box. It is metal band round four sides. One side can open and bend bit and take out. Bottom and top are painted and clearly they are PCB and golden figures and name looks like they are just  PCB traces. But other way looks like PCB is without any conductive copper, only painted black. So true metal is only this band between these bottom and top cover.
Again SOL Cal and result is:
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #168 on: August 10, 2020, 08:15:42 am »
S21 is within spec now. Mind taking some pictures of the PCB top and bottom side? I'm curious what their layout looks like with the buttons and switches moved.
Offline rf-loop
  • Country: cn
« Reply #169 on: August 10, 2020, 12:10:57 pm »
Yes 21 upper freq. noise level drops some amount without  case sides metal parts.
 I will later take it parts. I do not know how this battery is fixed (glued) inside this "sandwitch" but  when it was partially open it looks bit weird.  I want open it without damages and any signs I have opened it.  PM can not attach images. Also I do not have my camera here, only phone as "camera" but I will look some solution.
« Last Edit: August 10, 2020, 12:20:38 pm by rf-loop »
Offline cdev
« Reply #170 on: August 10, 2020, 02:18:44 pm »
What happens when you terminate S21?
I often make temporary cases for my hardware out of cardboard because its easy to make and gets them out of harms way. In order to have shielding I then usually use either copper tape or sometimes I will use what you describe, a copper "O" a flat strip joined with solder with holes cut to give SMAs good ground points.
I will then often solder a wire to the copper tape to ground it to the chassis and also ground the power at the same point the DC power is attached.
USB noise is oten hard - very hard to get rid of.
« Last Edit: August 10, 2020, 02:33:50 pm by cdev »
Offline rf-loop
  • Country: cn
« Reply #171 on: August 10, 2020, 03:43:34 pm »
Naturally no significant change. This is not designed just like toy. Even when price is what it is.
Offline bicycleguy
« Reply #172 on: August 11, 2020, 01:17:51 am »
Now here's a case.  It's a wonder what you can do with Covid-19 spare time.
Angled so you can see it.
Holds SOLT, attenuators and adapters in a drawer.
Holds a standard 18650 Li cell.
Lots of air holes for cooling.
« Last Edit: August 11, 2020, 01:19:46 am by bicycleguy »
The following users thanked this post: KD0CAC John, cdev, rudolf, Gandalf_Sr, JohnG, cx1cnc, TorinoFermic
Offline cdev
« Reply #173 on: August 11, 2020, 02:24:39 am »
Beautiful, I have some very nice recycled brown stiff cardboard I think is going to go into my case. What did you make the drawer out of?
Offline bicycleguy
« Reply #174 on: August 11, 2020, 04:39:56 am »
The whole works is 3D printed PLA fiber with faux wood, white and black text.  The top took about 3 hours and the base about 4.  The drawer took about  8 hours because I wanted to test modifications I had made to my multi-color Prusa printer.  The brown on the front caused the printer to switch colors every layer (182 layers).  If I had left it white it would have been about 3 hours even with the black text, because that text is only on 4 layers.
Offline rf-loop
  • Country: cn
« Reply #175 on: August 11, 2020, 12:18:39 pm »
My previous answer was from memory.
Now after full teardown it is again back working and I can answer with real data if can think image as data.
Sweep 1 - 3000 MHz.
As  previously also used, segments 10.
S11 Calibration.
First image
S11 50 ohm  load, same as in Cal.
S21 just SMA fully Open (nothing in SMA) .
Second image
S11 50 ohm  load, same as used in Cal.
S21 just Short, same as used in Cal.
I do not explain result, images talk.
S11 50 ohm Load, S21 Open
S11 50 ohm Load, S21 SHORT
« Last Edit: August 11, 2020, 12:35:07 pm by rf-loop »
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #176 on: August 11, 2020, 01:23:53 pm »
Looks good; if you want to fix the enclosure reflection issue there are RF absorbing ferrite sheets like these:
1044932-0
The 3.2 inch clone is just one of the many clone manufacturers that played it fair, and I don't mind recommending it if you want a NanoV2 with a metal enclosure.
The following users thanked this post: rf-loop, KD0CAC John, 2N3055
Offline rf-loop
  • Country: cn
« Reply #177 on: August 11, 2020, 02:17:35 pm »
(Attachment Link)
 :-+ OMG this was good ! Not only for Nano but... I have totally forget to try find some this kind of things even more importantly to my some other things... I have direct places for these products after I return my homeland.  (not only just in image but they have also other things..)
But for NanoVNA it need experience what exact product and how is best to try -- of course without experience it can find using  long iteration... but it is not nice to teardown for several iteration if there is allready some experience..
Even some advisory so that do not start from empty board. What material exactly, they have many, and where exactly add in Nano. There is several thickness and different materials.
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #178 on: August 11, 2020, 02:35:09 pm »
From experience the thicker the better (up to 0.5mm at least). The best positions for the absorbing material are hard to predict, but you can always just put it on all walls of the enclosure.
Offline rf-loop
  • Country: cn
« Reply #179 on: August 11, 2020, 02:46:32 pm »
If I understand right there is different permeabilities,  types "50", "80" and  "TE" but difficult to understand (language) all what they tell.
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #180 on: August 11, 2020, 02:48:51 pm »
The higher permeability versions have more ferrite "dust" mixed in; there is a small improvement in isolation last time I tried.
Offline cdev
« Reply #181 on: August 11, 2020, 03:26:50 pm »
You can use layers of anti-static foam. The lowest resistance/most conductive should be the closest to the conductive surface beneath it and them as you go out from there each layer should be less conductive more resistant. You can use anti-static foam. How well does it work? Ive tried it but have never been able to test it beyond just subjectively. But it does seem to help.
The following is just for fun/as an experiment.. I'm not suggesting you do this for any commercial product.
You might also be able to make RF absorbent material using a two part foam, activated charcoal (and possibly iron or ferrite powder, but I would suggest not using that, even if it improves its RF qualities- see below) .
But if you do try to do this, plan out the workflow really well and to the second because its hard to mix quickly and hardens to a very tough consistently almost immediately. Whatever clothes you are wearing if it gets on them it will be in these forever. It will be very very hard to get off of anything it splashes on.
Also,I suspect iron powder is likely dangerous inhaling it is likely very bad for you.  So i would just use activated charcoal (which I got from used up water filters (Brita) which have a lot of it in them).  You need a lot to get a resistance low enough to measure. Which makes the  pinkish black "foam" I ended up with as hard as a rock. Its very hard to mix it before it hardens. It hardened so quickly I think for me because the activated charcoal I used was wet. (Dry used up activated charcoal might harden much more slowly)
Anyway, for what its worth, thats how I tried to do it.
(Attachment Link)
The following users thanked this post: Bravo
Online asmi
« Reply #182 on: August 12, 2020, 04:58:17 pm »
I would really like that device with larger and higher-resolution screen, because normally I look at them from some distance (to have enough space for DUT directly in front of me). I wonder if it's possible to re-design the display part to utilize something like 7" RGB24 screen (perhaps via something like EVE controller - FT813 or BT815). Or use beefier main MCU which supports parallel RGB LCD panels directly.
Offline AlfBaz
« Reply #183 on: August 12, 2020, 07:28:48 pm »
My 4" displays finally arrived.
I've created a rough model of both the nanovna and lcd boards to begin design of a 3d print enclosure for the whole lot.
Due to the large overhang created by the LCD display the case would have to be a weird small bottom large top enclosure so as to have the sma ports, jog buttons, on/off switch and USB port protrude from the walls of the enclosure
I can accommodate for the jog buttons, SMA ports and and on/off switch by placing the nanovna board in the bottom left corner of the enclosure and then using a ribbon to connect the LCD display but we're still left with a problem accessing the USB port
Maybe a design similar to bicycleguy's with the nanovna board flat and the LCD display tilted will do the trick :-//
Offline Gandalf_Sr
« Reply #184 on: August 13, 2020, 12:48:53 am »
I've done a design for a case (the bottom half anyway) that deals with the issues you describe but I have been unsuccessful in making an array of holes for cooling purposes.  I may print a prototype just to prove the dimensions - give me a few more days.
If at first you don't succeed, get a bigger hammer
Offline aargee
« Reply #185 on: August 13, 2020, 05:14:55 am »
I have just printed ch_scr's enclosure from the beginning of this thread using https://www.proto-pasta.com/pages/magnetic-iron-pla, not sure how/if it will improve performance - I was just interested to print one in this material. I bought the reel off EBay that was surplus to someone's requirements a while back.
Interestingly... https://3dprintingindustry.com/news/3d-printing-proto-pasta-create-magnetic-donut-transformers-117936/
Here is the result. The last photo is the enclosure being picked up be a HDD magnet.
Offline AlfBaz
« Reply #186 on: August 13, 2020, 09:48:47 am »
... I have been unsuccessful in making an array of holes for cooling purposes.
I wasn't aware the unit got hot enough to warrant ventilation. I'll have to make some measurements
Offline AlfBaz
« Reply #187 on: August 13, 2020, 09:50:09 am »
I've done a design for a case (the bottom half anyway) that deals with the issues you describe ... give me a few more days.
Looking forward to it :-+
aargee, is that enclosure for 2 batteries?
« Last Edit: August 13, 2020, 09:52:16 am by AlfBaz »
Offline cdev
« Reply #188 on: August 13, 2020, 03:53:47 pm »
The magnetic PLA may not have desired RF properties and may not even be that compatible with electronics, if they were I would expect their web page would be crowing its benefits for use in cases of RF devices.
Powdered iron may in fact be at best a major irritant and at worst dangerous.
Note that I really know next to nothing about this stuff and could easily be wrong, this is just my gut feeling from spending around two minutes reading the web page at https://www.proto-pasta.com/pages/magnetic-iron-pla
Offline bicycleguy
« Reply #189 on: August 13, 2020, 05:04:46 pm »
I was going to go that route but got caught up with a neat drawer.  As you noted, the USB connector is too deep even with the 3.2 inch display and the display and RF boards have a mismatch at the SMA connector.  In my design the angle of display (50°) and its height are dictated by the bend of the RF cables.  Straight cables and a 60° angle would have been nicer.
Separating the boards would have required wiring some headers.  As long as they are separated why not a flip up display since the wiring would have allowed it.  I stopped when realizing this was becoming a time-nut like obsession |O
You can't see it in the pictures but I have a ton of air circulating holes.  I had noticed the board got very hot sitting horizontal on my desk but it never caused any issues.  The angle of the board does help the cooling.
The following users thanked this post: AlfBaz, cdev
Offline aargee
« Reply #190 on: August 13, 2020, 10:06:43 pm »
Probably the same risk as having a case of ferrite material. The iron is bonded up in the PLA filament, there is no powder floating about at all. There is no conduction across the case using probes and a multimeter. I'm not sure what you mean about 'compatible with electronics' - it seems to me the suggestions in this thread so far about using conductive foam might be more of a risk?
Then again, it would also be possible to line the case with adhesive copper tape if external noise was a concern, I too am not sure how well ferromagnetic material acts as an RF shield, I'm sure a search would bring up some reading material when I get aroiund to it :-)
I don't think the people who make this stuff ever thought of the electrical uses up front, most of the suggested applications are for 'rusted look' 3D prints, any electrical specs seem to be an after thought.
AlfBaz - that enclosure fits one 18650 battery in it.
Offline bicycleguy
« Reply #191 on: August 14, 2020, 01:01:19 am »
@aargee
Can you try a test like this: https://www.eevblog.com/forum/testgear/nanovna-v2-aka-s-a-a-2/msg3182046/#msg3182046 in and out of your case and see if you get the rise at high frequency?
Offline AlfBaz
« Reply #192 on: August 17, 2020, 10:44:24 am »
Had a busy weekend so was unable to do a test print to check sizes. That's why no stl attachment
Instead a small jerky video of the assembly for a unit with the 4" display.
I'm thinking I might add a draw or some pockets on the opposite side of the battery for the SOLT cal pieces
I had to go a little bigger to allow for an 16850 battery holder since locally its hard to source these batteries with wires already attached and I dont want to mess around soldering stuff when ever I have to change the battery
PS
the file is zipped so that the forum software lets it upload
Offline AlfBaz
« Reply #193 on: August 17, 2020, 10:46:30 am »
pps
forgot to mention the lcd is meant to be attached with ribbon
Offline Gandalf_Sr
« Reply #194 on: August 17, 2020, 12:55:40 pm »
Looks good Alf, better than my half-assed one.
Offline AlfBaz
« Reply #195 on: August 17, 2020, 01:00:27 pm »
Thanks
Offline cdev
« Reply #196 on: August 17, 2020, 02:29:27 pm »
How could we visualize the interaction's causes better? Make fixing it more of a realtime interaction (faster)
@aargee
« Last Edit: August 17, 2020, 02:36:55 pm by cdev »
Offline cdev
« Reply #197 on: August 17, 2020, 02:40:26 pm »
Having a pop up screen that would remain at an approximately 45 degree angle while being used
would be extremely helpful for my use case which is usually on my desk behind my computer keyboard.
pps
Offline Gandalf_Sr
« Reply #198 on: August 17, 2020, 05:29:30 pm »
I haven't done a test print but I did figure out how to do the vent holes.  My battery is between the 2 PCBs so it doesn't need extra space.
Offline AlfBaz
« Reply #199 on: August 17, 2020, 07:29:00 pm »
I looked back through this thread to see what battery you used, it didn't occur to me that perhaps cordless phone batteries might be usable as they come wired with connectors.
I like your approach to the case design, there's no need to modify the nvna board. The on/off switch has to be removed on mine
The following users thanked this post: Gandalf_Sr
Online TimNJ
« Reply #200 on: August 18, 2020, 12:52:33 am »
 @OwO
Just a general comment that the SMAs on my board are quite crooked...I checked the NanoRFE webpage, and lo and behold, seems like those connectors are crooked too.
Not sure the angle, but pretty obvious. Consider tightening up the holes a little bit?
« Last Edit: August 18, 2020, 12:54:39 am by TimNJ »
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #201 on: August 18, 2020, 02:23:35 am »
Thanks for bringing that up, I'm just about to do another prototyping round for the 4 inch PCB and also realized many other holes are too loose too. I should add this to my DFM checklist...
Offline rf-loop
  • Country: cn
« Reply #202 on: August 26, 2020, 01:45:00 pm »
NanoVNA V2 have also "zero span" mode as CW mode. Even more there is selection for stop sweep.
It can asssume in this mode it generate normal CW signal as what ever RF generator or as example common SA's tracking generator in zero span mode.
It was quite big surprice to me that Nano works in this mode more like noise transmitter than anything else. Useless.  Now I wonder why. There is quite ok TCXO reference and circuits what can generate much more clean signal than now - I believe.
Where is this problem. Is it possible to repair just adjusting things in FW for generate more clean CW than this do now. Why there is CW mode if it is totally useless for anything but playing fun.
Here is one SA image.
Signal is 146.5MHz out from Nano.
Mode CW and then also selected sweep stop.
Jitter, FM, residual FM, hopping, phansenoise or AM mod or what ever mess there is....
I know this is VNA. In this use it is not so problem but same HW can use also for some kind of RF generator. There is even selection for CW.
Is in any "to do" list so that may have some hope about small somehow working tiny RF generator because there is hardware already...
Kind wish to development team, please look if it can make usable with just programming without any HW mod.
Lets give picture talk...how it is now.  All understand it is now nearly useless...
Yes it can also see that TCXO is far off but somehow acceptable stable in this class. "SA" used here is based to better reference and it is least inside 0.1ppm.
« Last Edit: August 26, 2020, 01:52:06 pm by rf-loop »
Offline edigi
  • Country: hu
« Reply #203 on: August 26, 2020, 01:58:41 pm »
I you check it with DSO (that can handle reasonable high frequency and has big enough memory) it'll become pretty clear that it's not a continuous signal (which I'd also prefer) but more like when it's sweeping so a bit of signal then silence for PLL to lock to the next frequency (which is just the same here) and so on (I've checked it a long time ago but if my memory serves me correct, stepping is something like 5ms).
While I did not check the code, I suspect that the same loop is used to sweep.
It's OK for VNA functionality but for CW it would be indeed better to emit real CW signal like the original Nano (even though it may eat a bit more battery etc.)
« Last Edit: August 26, 2020, 02:00:38 pm by edigi »
Offline rf-loop
  • Country: cn
« Reply #204 on: August 26, 2020, 02:57:50 pm »
Yep.
As I write no prob in VNA mode but in CW mode this is totally bad. CW is Continuous Wave.
And when it pulse after then it is modulated. Now with this modulation there is also quite high phase noise and perhaps we can see some residual FM after this pulsing is stopped but then we can talk is it ok... yes perhaps due ti its nature as it is, mainly tiny cheap VNA what is better than its price.
Offline switchabl
« Reply #205 on: August 26, 2020, 03:57:35 pm »
Yes, this has come up a few times, I think. Here is what the ouput power looks like in the time domain (@1GHz). The stimulus is turned off every ~5ms. I believe the device regularly performs some kind of self-calibration to deal with drift. The intervals are not quite regular either (likely depends on what other tasks it has to perform), so the spectrum will look rather wild.
I don't think "CW mode" is intended for use as a signal generator. It is simply a zero span mode for the VNA (this is called "CW time" on Agilent VNAs as well). I agree that the name is somewhat misleading.
Adding a proper CW output in the firmware should not be particularly hard. It would still be of somewhat limited use, since it is unlevelled and there is no filtering. This is probably why no one has bothered so far. It is open-source after all.
Offline rf-loop
  • Country: cn
« Reply #206 on: August 27, 2020, 02:15:00 am »
Yes. But there is more than just one zero span mode. For what all these need use this pulse mode for measurement.  Least one can be just plain Continuous Wave. I have in my homelan workshop "trucload" of RF generators. But I think peoples who have this Nano, what is cheap, pocket size handy tiny tool. Even if its RF CW output is not good quality and without level adjustment and not even known level and or it is far away from  flat, not even close, from low to high freq.
Still I think it is not at all bad feature for many peoples if it have just this RF quality but without this "pulse modulation" what just make it totally useless if try use it as some kind RF generator. And because all is ready in HW for it.
In menu there can select start, stop, center, span,  cw freq, and pause sweep. Is it enough that one setup can result CW without pulsing.
No matter if Nano do not "listen and measure" anything in this CW output mode (CW and Pause selected example). Now in CW+Pause it still is pulsing and this is what I wonder. Without pause, it also measure in CW mode so perhaps it need pulse as it also do when sweep (stepping sweep).
Of course if known level and need adjust level, nano do not this, but for many hobbyists there is available many cheaper and more cheap low grade attenuators and some day he or shee may check different frequencies true level and after then he can use it knowing something more about level. For things what need medium or high quality RF generator, this is not.
Also its RF out is quite "dirty" but still better than no gen for some hobby purposes and in machine what can take in pocket to everywhere.
I am not ranting about this and that like I am if this is true commercial business model product, but it is not, this is just open source as you told.
It was wish that if developing team see it is easy to do change it is perhaps good to do. Even with all cons what it have as rf generator. Just like, better than nothing for perhaps many peoples. Least it do not shoot not down this NanoVNA value if there is this "CW only out" mode.
It also mean that in this mode it do not measure anything like it do now. In CW mode now,  it do measurements also of course.
But then there is Pause Sweep selection. Now it do not update any displayed measurements in CW mode but still it continue Pulsing. For what.
In this state it can, imho,  send just Continuous wave out. Least I somehow think that when it do not need measure anything in CW mode then pulse modulation can also stop if reason for pulsing is measuring.
Perhaps example OwO can answer what is real reason for pulsing in state/mode when it do not any measurements.
Or is it just..."no one care" reason.
« Last Edit: August 27, 2020, 02:32:06 am by rf-loop »
Offline cdev
« Reply #207 on: August 27, 2020, 02:41:01 am »
Yes. But there is more than just one zero span mode. For what all these need use this pulse mode for measurement.  Least one can be just plain Continuous Wave. I have in my homelan workshop "trucload" of RF generators. But I think peoples who have this Nano, what is cheap, pocket size handy tiny tool. Even if its RF CW output is not good quality and without level adjustment and not even known level and or it is far away from  flat, not even close, from low to high freq. Still I think it is not at all bad feature for many peoples if it have just this RF quality but without this "pulse modulation" what just make it totally useless if try use it as some kind RF generator. And because all is ready in HW for it.
In menu there can select start, stop, center, span,  cw freq, and pause sweep. Is it enough that one setup can result CW without pulsing. No matter if Nano do not "listen and measure" anything in this CW output mode.  Of course if need adjust level, nano do not this, but for many hobbyists there is available many cheaper and more cheap low grade attenuators and some day he or shee may check different frequencies true level and after then he can use it knowing something more about level. For things what need medium or high quality RF generator, this is not.
It also mean that in this mode it do not measure anything like it do now. In CW mode now it do measurements also. But then there is Pause Sweep selection. Now it do not update any displayed measurements in CW mode but still it continue Pulsing. For what. In this state it can send just Continuous wave out.  Least I somehow think that when it do not need measure anything in CW mode then pulse modulation can also stop.
It would be worth it to code an interface to allow scripting of the signal generator. ,I have some very small 3.3 volt omron RF relays I would like to use them to be anle to do a RF switchbox so I could script and speed up testing and workflow.
« Last Edit: August 27, 2020, 04:42:32 pm by cdev »
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #208 on: August 27, 2020, 03:09:03 am »
The pulsing isn't because of internal calibration, it's because the reference channel is measured by shorting port 1 to ground. The two synthesizers do not have known phase relationship (ADF4350 phase resync is not usable for the full frequency range) so the reference measurement is required. It is possible in CW mode to only measure reference once, but then you will have a lot of drift and anything that causes a ADC buffer overrun (like writing to flash) will cause it to lose sync and phase will become random.
Offline rf-loop
  • Country: cn
« Reply #209 on: August 27, 2020, 04:30:00 am »
Afaik, in normal "CW" aka pulse modulated CW it still do normal S11/21 measurements. It pulses and measure continuously, example if I connect load or what ever it give measured results.
I mean now, outside of this functionality, just different "CW blind output" mode what do not measure anything but push raw RF out, if something drift or not just "so what".
It is now same pulsed output if I select start and stop same, if I select center and zero span or if I select just CW. All same. But even more, if I select Pause Sweep independent of  selected Span or just CW it also generate pulsed output.
Example it can do so that normal CW out as now can be just as now including it do measurements. But if CW is selected and then user select sweep pause. It do not anymore measure anything or least it do not display anymore new results. In this mode when CW selected and PauseSweep selected  Now it can just blind push selected RF frequency out without anything else. If there is some drift or not, just out with blind eyes and ears. Then this generator output drift like it drift, more or less and it is as it is, take it for use or not.
I believe still this feature add some small value to Nano, it hardly reduces the value.
« Last Edit: August 27, 2020, 04:32:46 am by rf-loop »
Offline switchabl
« Reply #210 on: August 27, 2020, 04:25:47 pm »
I have patched the firmware so the measurement is turned off when the sweep is paused. I am not too interested in the S-A-A2 as a signal generator, but I want to some more detailed performance characterizations and for that purpose it can be useful to have a CW output.
https://github.com/switchabl/NanoVNA-V2-firmware/tree/cw
From a quick test it seems to work fine, but it is probably not ready to be included in the mainline firmware. There are other events (like changing display settings) that unpause the sweep and in that case the ECAL switch may be left in an unexpected position and throw off the next measurement. Also this is based on the current master, so may contain other unexpected bugs (and features). Still, if you feel adventurous, feel free to try the binary (https://github.com/switchabl/NanoVNA-V2-firmware/releases/tag/cw-test1, usual disclaimers apply).
I am not entirely convinced that this is the right way to go about it. I think the least surprising behaviour would be to turn the stimulus off entirely when the sweep is paused. If desired, there could be a separate mode (or at least menu) for use as a generator. But on the other hand that would be a lot more work.
Online ch_scr
« Reply #211 on: August 27, 2020, 07:12:30 pm »
Your drawer has bugged me for a while, but I wanted it optional and tiny. Today was the day!
The black PLA seems to get only warm, not full on hot on the bottom so I opted out of cooling holes.
This will not fit the case I posted earlier, so I have not included an stl for now.
« Last Edit: August 27, 2020, 07:15:46 pm by ch_scr »
Offline switchabl
« Reply #212 on: August 28, 2020, 08:05:28 pm »
Somewhat more polished version, where you can change the frequency without having to pause again afterwards:
https://github.com/switchabl/NanoVNA-V2-firmware/releases/tag/cw-test3
I think it shouldn't break anything else (sweep pause is now separate from UI refresh). :scared: So if there is interest in having it in the official firmware, I can make a pull request.
« Last Edit: August 29, 2020, 03:53:22 pm by switchabl »
Offline DiSlord
  • Country: ru
« Reply #213 on: September 01, 2020, 08:46:51 am »
I test 7`display for H4, and it show good perfomance on only SPI bus (on display test i use 401 point measure) (yes if use 8bit or 16bit parallel connection can more faster), but 8bit color mode + hardware bitblt and fill allow get good speed.
After all optimization (on video my first run after add touch, after i increase update speed ~2-3x), at this moment update speed ~as on old firmware H4 (full screen update need only ~90ms)
Code can ported to V2 (it use some codebase for display as H or H4)
Additional possible add 5x4 keyboard (20 keys)
Capacitive touch allow use finger for control
Backlight control
Minus is only cost for display module ~40$
« Last Edit: September 01, 2020, 09:32:18 am by DiSlord »
The following users thanked this post: cdev, Kean, JohnG
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #214 on: September 08, 2020, 01:55:30 pm »
to avoid hijacking the other thread, i just post this here...
That's the one I bought; look back at my posts to see how I changed it to 4" display.
I have to say that the original 3.2"? LCD was close to unreadable for my old eyes, the 4" display I fitted is really good and I have no problems using it now.  I haven't got around to printing my 3D case for it yet though :(
thanks for the tip. requoted here for future reference... i'm thinking if 3d printing cant do what i want, maybe cutted wood/acrylic/plastic/metal can may do the job as well for the enclosure / test rig... i'll try to do whats best for my "way", not necessarily need 3d printed enclosure.
5. Run up NanaVNA_QT
The git version has 4 inch display support but there is no binary released yet; I'll go do a release right now. https://github.com/nanovna/NanoVNA-V2-firmware
The battery is any li-ion battery (3.6V and 3.7V cells are the same thing, they are all 3.0 - 4.2V). The dimensions should be 6*40*60 mm to fit in the device, usually labeled as "604060", or use that enclosure that supports a 18650 cell (I would go this route because 18650s are generally safer).
edit: i just noticed someone upgraded it with 7" LCD. i got one here for rasp pi orange one, not sure if its compatible, will check deeper when my unit arrived..
« Last Edit: September 08, 2020, 01:59:41 pm by Mechatrommer »
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #215 on: September 14, 2020, 08:13:42 am »
Quote from: Mechatrommer
can existing version be made faster sweep too? is it simply updating FW,  or there using new IC?
There are both circuit and firmware changes, I will post more info some time after it's released, or DM me.
The following users thanked this post: Mechatrommer
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #216 on: September 14, 2020, 10:30:51 am »
Pictures of the V2 plus4 in metal enclosure, with 3200mAh battery inside
After calibration the dynamic range still reaches 70dB to 3GHz, so plus4 will come with a metal enclosure.
The following users thanked this post: cdev, 2N3055
Offline joeqsmith
« Reply #217 on: September 14, 2020, 11:19:30 am »
I still haven't pulled the trigger on the V2 but you keep enticing me.
Will this one support the faster sweep times you mention?  How fast on the screen, and how fast across the USB port?   Was there a hardware change to support the faster sweeps, or will this firmware run in the original V2, allowing for the same faster sweep rates?
Whats the number of samples per sweep?
Will it support more complex SOLT?  At 3GHz, I'm surprised it wouldn't have something better than the Nano.  OF course, this leads to the question, what's the progress on the 6GHz unit?
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #218 on: September 14, 2020, 11:29:32 am »
Yes this one is 400 points/s (compared to 100 points/s for V2_2), same speed on-screen and over USB. I will post a comparison video later. There are substantial hardware changes to support the higher sweep rate, and a new directional coupler with high native directivity (>18dB for the coupler itself, ~17dB in circuit with SMA connectors, 50kHz to 4GHz).
Number of sweep points is adjustable up to 201 points on-screen and unlimited over USB (compared to 1024 points in V2_2 and V2 plus). More advanced calibration may be added to the firmware later. 6GHz VNA is developed by a different person and I'm not sure what the timeline is.
The following users thanked this post: joeqsmith, 2N3055
Online Miti
« Reply #219 on: September 14, 2020, 12:25:44 pm »
Where and when will this be available? Price? I'm sorry if this is discussed somewhere in the thread, TLDR.
Fear does not stop death, it stops life.
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #220 on: September 14, 2020, 01:06:12 pm »
Probably 2 more weeks, I think the PCBs are already finished and they are waiting on PCBA. I don't control the pricing but it'll be set based on cost, so plus4 won't be as cheap as the V2, but I do know V2 plus costs the same as the V2 so it will be priced the same.
Online thinkfat
    • Matthias' Hackerstübchen
« Reply #221 on: September 14, 2020, 03:41:28 pm »
I'm starting to loose track of the different models now.
V2 plus4 is the upgrade with better dynamic range and faster sweep with more points and 4" screen?
V2 plus is - what?
EDIT: going back through the thread, "V2 plus" seems to also have lower noise and faster sweep, but not more points and small screen. Can you perhaps provide some differentiation between the models? Since both seem to improve in similar areas, but there's no numbers on the improvement the V2 plus brings over the original V2 and how it compares against the V2 plus4.
« Last Edit: September 14, 2020, 04:21:29 pm by thinkfat »
Offline cdev
« Reply #222 on: September 14, 2020, 05:07:29 pm »
Looks gorgeous!
What is the new hole to the left of the three buttons, also am I corrent in that you now are using a full size USB connector?
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #223 on: September 15, 2020, 04:43:20 am »
V2 plus is - what?
V2 plus - 2x sweep speed and slightly lower noise, this version replaces the V2_2 which will no longer be manufactured (but will continue to receive firmware updates).
V2 plus4 - 4 inch display, 4x sweep speed, 70dB dynamic range to 3GHz, frequency range extended to 4GHz, and metal enclosure. This is the only hardware version that can be put into a metal enclosure without messing up dynamic range because signal isolation is much improved.
« Last Edit: September 15, 2020, 04:44:59 am by OwO »
Offline Kosmic
« Reply #224 on: September 15, 2020, 02:50:48 pm »
woo I'm clearly not following, I thought the V2_2 was the latest and greatest. Ordered one yesterday  :palm:
Online Miti
« Reply #225 on: September 15, 2020, 03:17:14 pm »
I’m looking forward to the release of V2 plus4. Will you let us know when it’s available?
  • Country: my
« Reply #226 on: September 15, 2020, 03:25:09 pm »
yup announcement today, i bought few days ago :palm: i'll see what i can upgrade...
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #227 on: September 15, 2020, 04:16:28 pm »
V2_2 is the newest hardware revision right now, all the "plus" versions will take at least several more weeks. I can provide info about how to convert V2_2 to plus if you DM me, although conversion to plus4 isn't possible because the circuit design has been reworked.
The following users thanked this post: Mechatrommer, cdev, mikeydread, Kosmic
Offline VK3DRB
« Reply #228 on: September 23, 2020, 08:29:34 am »
OwO, please let us know when the V2 plus4 it is released, but I am happy to wait longer before buying from Tindie to ensure all testing has been completed so there are hardware no bugs or weaknesses. Also, thanks heaps for being an excellent contributor to the VNA discussions.
I have access to a MegiQ VNA0460E periodically. I intend to do a comparison test into the same loads.
The following users thanked this post: ducus
Offline cdev
« Reply #229 on: September 24, 2020, 12:40:55 pm »
I have to say, I have had more "fun" and probably spent more time using my NanoVNA 2.2 than any of my other electronic instruments except my main DMM (UT-61e) and perhaps scope. (old Tek 2211) Because the scope is so bulky, probably more than that too.
I still dont have it working 100% properly when connecting up to my computer on Linux, it appears to be a permissions problem, as I can only run it as root, which is a PITA. I'm on Debian 10. I should see if I can run it on my RaspberryPi. Is anybody else having this problem? I shouldnt have to write a udev rule, should I? I have tried a lot of different udev incantations but have not gotten it right.
When not running under sudo the software starts but doesn't see the device, even though its connected, when lauched via sudo it works fine.
« Last Edit: September 24, 2020, 12:47:15 pm by cdev »
Online ch_scr
« Reply #230 on: September 24, 2020, 12:57:37 pm »
Make sure your user is in the dialout group "sudo adduser your_username dialout"
You need to log out and back in for it to take effect.
Offline cdev
« Reply #231 on: September 24, 2020, 01:18:51 pm »
Yes, I am a member of dialout and that hasn't fixed it!
Usually this situation requires creation of a udev rule, and Ive tried to come up with the right rule, failed, and then deleted udev rules so that I could implement the right solution. Still have not found it.
Nor have I found the log that gives me the info I need either. Should revisit it now that I know more about the NanoVNA2's normal operation. I prefer using it tethered when I can, as then I can take screenshots, etc.
« Last Edit: September 24, 2020, 01:22:56 pm by cdev »
Online Miti
« Reply #232 on: October 04, 2020, 10:43:28 am »
Hey OwO,
Any news?
Offline gizmo5418
« Reply #233 on: October 06, 2020, 01:18:28 pm »
...Usually this situation requires creation of a udev rule, and Ive tried to come up with the right rule, failed, ...
You need to create a udev rule with content:
SUBSYSTEM=="usb", ATTR{idProduct}=="0008", ATTRS{idVendor}=="04b4", MODE="0666"Put this content in a file named e.g. 99-nanovna-v2.rules in the path /etc/udev/rules.d/
Then you have to reload the udev rules:
sudo udevadm control --reload-rules
sudo udevadm trigger
or restart your computer.
Now you can communicate with nanovna from the normal user level.
Regards, Pawel
Sorry for my English. I am using google translator.....
« Last Edit: October 06, 2020, 01:20:51 pm by gizmo5418 »
Offline cdev
« Reply #234 on: October 06, 2020, 11:18:01 pm »
Your English is fine.
But there is something wrong with my computer's cofiguration that I need to fix to get this working. I probably need to approach this more methodically.
NanoVNA saver works without the fix, so I know it can work, however NanoVNA saver crashes on my machine and the Chinese software works and is stable, just requires to be run using sudo or it launches part way, but doesnt see the VNA. So parts of the interface dont respond.
It fails to handshake with the vNA.
Regards, Pawel
Offline switchabl
« Reply #235 on: October 07, 2020, 11:40:44 am »
Apologies if this is obvious, but have you looked at the actual group/permissions assigned?
ls -l /dev/ttyACM*
Anyway, if I understand correctly that NanoVNA saver can connect successfully without root, so this doesn't point to a permissions problem (unless it is something more subtle involving AppArmor).
It might also be worth checking if something else tries to connect to the device and messes things up, e.g. ModemManager likes to talk to anything that looks like a serial port.
So maybe try to disable it before plugging the NanoVNA in and see if that changes anything
sudo systemctl stop ModemManager
More generally, check immediately after plugging it in if anything is trying to use it
lsof /dev/ttyACM*
  • Country: my
« Reply #236 on: October 14, 2020, 01:31:37 pm »
i received my nanovna v2+ from HCXQS group (tindie) today. i ordered with solt and cables option, but they sent the whitish plastic enclosure as well thumbs up. for the solt, load is comparable or similar performance to my Kirby's load to 7GHz, the open and short standards are significantly different though. for the cable, its good all the way to 7GHz, much better than the used 12" Huber Suhner cables that i bought for about the same price as this nanovna set. so what i basically got is $70+ incl shipping of 2x 12" 7GHz cables with FREE SOLT and a working new NanoVNA unit ::)... i havent test the nanovna itself yet, having trouble to understand how it works, which button to start sweep or cal etc. and which one is port1 and port2. need to read manual first. fwiw...
Offline joeqsmith
« Reply #237 on: October 14, 2020, 11:11:14 pm »
It would be great if you could run an isolation test on it and post the data in the other thread (just to keep it in one place).   I would also be interested in seeing any other comparisons you come up with.
Offline Noy
« Reply #238 on: October 15, 2020, 07:20:23 am »
Will there be a cheaper NanoVNA V2+4 without the 4" display and with a completly closed case? Im using my V2_2 without the display as PC based device. But the +4 would be better with case, USB B and so on...
Online thinkfat
« Reply #239 on: October 15, 2020, 07:24:03 am »
I ordered a V2 +4 from the Tindie store yesterday. I'm excited, this will be quite a step up from the V2+, in terms of usability and performance.
Offline Gandalf_Sr
« Reply #240 on: October 15, 2020, 10:38:09 am »
I too just ordered a V2 +4 from the Tindie store, I will be selling my V2 Plus that has been upgraded to a 4 inch display upgrade; if anyone is interested, PM me.
  • Country: my
« Reply #241 on: October 15, 2020, 02:05:37 pm »
i'm still struggling to understand it.. i want log vertical scale on resistance and reactance but i still cant find where the option is.. i got used to KC901V (and i guess every other brand name VNA out there) that we can see R and X all values all in one screen nicely in log scale with 50 ohm at the center, 0 ohm at bottom and inf ohm at the top.. currently i need to keep changing the linear vertical scale if i want to see short, 50 ohm and Hi resistance. sometime traces and freq range lose control, changed setting and other weird stuffs when i play with side menu... anyone can give a hint?
i thought of upgrading to 4" display earlier, but i still can see most of the things on the bundled small screen, so i think i will not make an upgrade soon. btw, the sweep speed is comparable to my KC901V, not too slow, so i'm quite happy already with it. but sometime less resolution plot (many straight lines).
« Last Edit: October 15, 2020, 02:12:22 pm by Mechatrommer »
Offline Gandalf_Sr
« Reply #242 on: October 15, 2020, 09:57:09 pm »
My old eyes couldn't cope with the tiny fonts on the 3.2" display, the 4" version is just fine.  I like that I'll get an extra 800 MHz with a top frequency of 4 GHz.
I also am happy to get a SOLT kit and metal case with the new one.
  • Country: my
« Reply #243 on: October 16, 2020, 12:02:07 am »
(reading back this thread from start) the one with me titled V2 Plus, but OwO mentioned in reply #234 above (after i made the order) that V2 Plus is not released yet, so i'm confused now... my pcb is V2_2 same as yours but the FW is git-20200707-2a35e6e can go from 10kHz up to 4.4GHz, so i'm curious what you meant by you need extra 800MHz with a top frequency of 4 GHz? mine can go beyond that. maybe you still using old FW? upgrading FW will enable 10kHz-4.4GHz i guess (spec (old FW?) 50kHz - 3GHz).
edit: bug report... if we enable more than one marker... moving them past center will make frequency label negative (jump from 2GHz to -2GHz) and moving down in magnitude as we continue to the right (bigger frequency) until near end, they become zero and positive again, something like 50-100MHz at rightmost, where actual span is 10kHz-4.4GHz (they should show 4.4GHz). i believe this was mentioned earlier by a member here..
« Last Edit: October 16, 2020, 12:52:02 am by Mechatrommer »
Offline Gandalf_Sr
« Reply #244 on: October 16, 2020, 10:09:20 am »
I understand that it's possible to make my V2 into a V2 Plus by changing 3 components and applying a new firmware; I might still do that but, for now, I would rather just move to the latest hardware and sell my V2 with 4 inch display to someone for $75.
  • Country: my
« Reply #245 on: October 16, 2020, 05:34:30 pm »
fwiw.. i converted the online manual into pdf (attached zip) i believe this will not violate anything on OwO's side. it was quick editing for what i needed, feel free to poke me if there need corrections, if you want to edit yourself i can provide the master copy in docx (840KB zipped). i got dizzy easily reading flat screened format, no bookmarks to go back and forth etc. if needed i will print this in much more logical "paged" way and learn NanoVNA peacefully without a cpu fan running. edit: i corrected some formatting and added pages' number (here is version E2)
The following users thanked this post: Kean
Offline Electro Fan
« Reply #246 on: October 16, 2020, 06:06:45 pm »
Is this the latest version of the product, or is there something newer/better?
What's the chance this might become available on Amazon?
Thx
Offline Electro Fan
« Reply #247 on: October 16, 2020, 08:33:18 pm »
thats the clone, performance not guaranteed by OwO. you can join here if you want... https://www.eevblog.com/forum/testgear/4-inch-display-saa-2n-nanovna-v2-3ghz-with-n-type/?topicscreen
Thanks
What are the ear markings of the clone vs. the OwO product?  (How can you tell the difference?)
Any idea if/when the OwO product might be for sale on Amazon?
Thx again
  • Country: my
« Reply #248 on: October 16, 2020, 10:12:15 pm »
if you read this and the other thread, you'll know the original V2 version by OwO only sold in Tindie only, thats the problem...
  • Country: my
« Reply #249 on: October 16, 2020, 11:26:35 pm »
trap for young player. we need to calibrate completely all SOLT and save to make S21 plot works, we cant just calibrate the T alone, otherwise S21 plot will go wacky... this is not the case with my KC901V. attached is S21 noise floor (uncalibrated and calibrated).. so comparing the 2N unit (Hugen) from another member in the other thread side by side with my unit (OwO)...
uncalibrated..
calibrated...
« Last Edit: October 16, 2020, 11:32:18 pm by Mechatrommer »
Offline Electro Fan
« Reply #250 on: October 17, 2020, 01:29:11 am »
If I started reading all the threads here again, along with all the other articles I can find along with watching all the youtubes I can find, it will be at least my third attempt at getting up to speed on the history and current status of the various related products.  It's cool to see that 1) the bandwidth is going higher, 2) the display is getting larger, 3) the price continues to be affordable (actually a great deal for what it does), 4) the software seems to be steadily getting better, etc etc etc.  But it is a lot of reading and watching to continually sort through it all (not so much the technology, but the commercialization politics).  In any event, if it was available on Amazon I think more people would probably quit reading and just buy one knowing that it's an easy return if it isn't what they were thinking/hoping it might be.  To be square, I return maybe 2% of stuff I buy on Amazon (about 1.5% Amazon or the seller messed up, and 0.5% is a self-made issue) - but one of my returns was an earlier version of a "nanoVNA" product (in one of it's variants).  I'm sold on the concept, I'd just like one that meets a threshold of usability that is hard to know until you can play with it for an hour or so.
Offline Electro Fan
« Reply #251 on: October 17, 2020, 01:50:47 am »
I've just started sorting through this for my attempt #3 and it's confusing (and potentially very time consuming) again ..... even people who seem to have read all the most recent stuff seem to have found surprises within the last week or so.
What we need is a nanoVNA "family tree" diagram that goes back to the adam and eve nanoVNAs; mostly it would be an easy to navigate tree diagram with very brief name and note boxes (kinda like name and title in an org chart, or a family tree chart with birthdays).  Once that was brought current it would just need to be updated when new fruit falls from one of the branches.  But the beauty is you could see at a glance all the model naming/nomenclature, maybe who spawned it (adam or eve, etc.), and what it's major breakthrough or flaw was/is.
Just suggestin'.... in case anyone likes making family trees or org charts :)
A really good chart would have just the basics on the top layer with hyperlinks to the detailed info.  Just dreaming.... :)
We could start with just the top layer and add the links later :)
Offline texaspyro
Re: NanoVNA V2 aka S-A-A-2
« Reply #252 on: October 17, 2020, 01:54:19 am »
This is a test message... I keep getting notifications for this thread but no new messages show up...
Offline aristarchus
« Reply #253 on: October 17, 2020, 12:42:07 pm »
It requires you to join the nanovna-users in groups.io, but it contains everything that you want to see.
https://groups.io/g/nanovna-users/wiki
The following users thanked this post: Electro Fan
Offline joeqsmith
« Reply #254 on: October 17, 2020, 03:30:02 pm »
I thought they were claiming 4GHz but I wasn't seeing any data beyond 3.  Is 3 the upper limit?
Offline Kosmic
« Reply #255 on: October 17, 2020, 03:33:47 pm »
4Ghz only on the NanoVNA V2 Plus4 that was released somewhere last week. I guess Mechatrommer has the NanoVNA V2 Plus.
« Last Edit: October 17, 2020, 03:42:20 pm by Kosmic »
Offline Kosmic
« Reply #256 on: October 17, 2020, 05:07:08 pm »
More info on the different hardware versions over here:
https://nanorfe.com/nanovna-versions.html
Offline joeqsmith
« Reply #257 on: October 17, 2020, 07:55:48 pm »
As impressive as the original Nano is, I suspect the +4 outside of not having being able to collect all 4 S-Paramters, missing the step attenuators and bias Ts, may be better than my first VNA in every way.   Looking forward to seeing what it can do.
  • Country: my
« Reply #258 on: October 17, 2020, 09:52:26 pm »
i was capturing 3GHz span to make easy comparison with the 2N next thread... but mine can go 4.4GHz on display (attached) just maybe a little bit out of spec.
i bought it as NanoVNA V2 Plus. i guess what i have is V2+ (V2_2) HW with latest FW (sept 2020) meant for V2+4? not sure... maybe mine is pilot unit for testing V2+4.
« Last Edit: October 17, 2020, 09:54:28 pm by Mechatrommer »
The following users thanked this post: ogden
Offline eliocor
    • rhodiatoce
« Reply #259 on: October 17, 2020, 11:21:49 pm »
Instead of relying on others to do so, why don't read the WHOLE threads and do this "graph" by yourself?
Once studied the whole subject, if anything is not enough clear to you, you can start to make RELEVANT questions regarding the who and when so you will be able to complete the graph!
In a such way you will able to help the others (instead of whining)
Offline ogden
  • Country: lv
« Reply #260 on: October 17, 2020, 11:35:15 pm »
Right. Become famous - make THE CHART of Nanovna. Don't be the whining [...] who expects that somebody else shall do the job for you.
Offline joeqsmith
« Reply #261 on: October 17, 2020, 11:45:29 pm »
Electro Fan,   did you check out Kosmic's link above?   Looks like it covers many of the various flavors.
Offline Electro Fan
« Reply #262 on: October 17, 2020, 11:58:02 pm »
I try to contribute when I think I have some answers and I ask for help when I don’t have or can’t find the answers.  In this case if the shoe doesn’t fit you, don’t wear it.  No worries.
To be square this wasn’t a request to help just me it was an idea about structuring information in a way that might help lots of people who are interested in VNAs get and stay current with developments that seem to have a history of interwoven moving parts.  I’m not JFK and we’re not going to the moon, but it was just a suggestion for anyone who might be a content expert and who enjoys organizing info. If the idea doesn’t have merit please feel free to ignore it. Sorry if it was whining.
Offline Electro Fan
« Reply #263 on: October 18, 2020, 12:00:37 am »
I did see that Joe, thanks.  It looks like it has concise and useful summary info.
Offline ogden
  • Country: lv
« Reply #264 on: October 18, 2020, 12:10:17 am »
Right. Why don't you do main work gathering all the info. We can help you to organize it :)
Offline joeqsmith
« Reply #265 on: October 18, 2020, 12:29:08 am »
I doubt you are the only one confused by all the flavors of hardware.  Guessing the firmware versions are a nightmare.  Once Radiolistener took on modifying the firmware, I basically followed them to the point they had it working well enough and called it a day.  I haven't reprogrammed it since.
For now, I'm just keeping my fingers crossed that they kept the same basic command set as the original Nano.  I haven't looked into any of it yet.
  • Country: my
