Author Topic: SKY Top Power STP3005 - noisy switching supply  (Read 2506 times)
Offline bbt95762Topic starter
« on: August 19, 2017, 08:16:37 pm »
Hey, I recently purchased a SkyTopPower STP3005 switching supply from eBay
one of those you get what you pay for moments I think
incredibly noisy
https://youtu.be/r0OCPXS96og
but, for $30...must be some way to clean it up.  I'm guessing if I open it, I"ll find no chokes or caps, anyone else have experience with this supply?
Thanks,
Brian.
Re: SKY Top Power STP3005 - noisy switching supply
« Reply #1 on: September 13, 2017, 07:37:35 pm »
on the bright side, the eBay seller seems genuinely interested to solve the issue.
I snapped this photo of the inside (we tried some additional caps between +, -, and EARTH
I was surprised the high side caps are much bigger (10000uF) then the output side caps 470uF)
Offline electronhauler
« Reply #2 on: November 01, 2017, 06:22:11 pm »
If you can add a common mode choke and a couple of ground capacitors to the output it will reduce the noise.
See attachment
