Author Topic: Need help for using of RTB2004 Oscilloscope  (Read 967 times)
Offline Frank_MVTopic starter
« on: May 26, 2023, 07:58:18 pm »
Hi experts,
When I select a channel on the RTB2004, the previously selected one (using the Ch1, Ch2, Ch3, Ch4 buttons) becomes invisible
What do I have to do if I want to see more than one channel at the same time ?
in short: how do I see more than one channel on the display ?
I could not figure out from the manual.
Thanks,
Frank
« Last Edit: May 26, 2023, 08:11:34 pm by Frank_MV »
Online egonotto
Re: Need help for using of RTB2004 Oscilloscope
« Reply #1 on: May 26, 2023, 11:19:55 pm »
Hello,
You've had the RTB2004 for over a year and a half and have never used more than one channel?
Best regards
egonotto
Offline coromonadalix
« Reply #2 on: May 26, 2023, 11:38:26 pm »
have you played with ch1 ch2 ch3 ch4  buttons, when you push 1 2 3 times etc ....
and   you should have done some search and you would have obtained all the infos you need, took me under 5  minutes ??
https://www.rohde-schwarz.com/ca/manual/r-s-rtb2000-user-manual-manuals_78701-402707.html
https://scdn.rohde-schwarz.com/ur/pws/dl_downloads/pdm/cl_manuals/user_manual/1333_1611_01/RTB_UserManual_en_12.pdf
« Reply #3 on: May 27, 2023, 09:24:24 am »
Hello,
Best regards
egonotto
I had simply forgotten about it, the last few months I have actually only needed one channel.
With my old analog Hameg is the switchon on of an additionaql channel much easier ;-)
« Reply #4 on: May 27, 2023, 09:25:58 am »
Thanks a lot :-)
