If we are talking about DP832, simply select the desired channel with the select button ("1", "2" or "3"), turn it on and enter the calibration mode.
Good day, Experts.
Please help me with the following questions
I have an oscilloscope Rigol DP832 converted to an oscilloscope Rigol DP832A using the method mentioned in this topic
After the modification, I got the available options LAN, RS232, color display
Communication with the device on the network through the LAN interface is successful using software ULTRA SIGMA from the manufacturer
Communication of the device with the computer through PC232 is not established (Reaction is absent)
The scheme of connection is used: Computer with RS232 port-Cable RS232 (9 pins) - Oscilloscope Rigol DP832(A)
The RS232 cable has the following scheme of contact pins 1-1, 2-2, 3-3, ..., 9-9
Communication of computer - other measuring device (not Rigol) using this RS232 cable is normal
Questions:
1) What type of RS232 cable should I have (1- ?, 2- ?, 3 -?, ... 9-?)
2) What RS232 cable lines are really needed to control the Rigol DP832A) and receive/transmit data from/to it ?
3) Do I need to make any settings directly on the device?
4) Does the device have any specific parameters of communication with the computer on RS232 ?
To update your Rigol DL3021 to DL3021A, here is the complete procedure, without the need of buying the LAN option...
You need:
-Computer with RS232 port
-USB stick formatted in FAT32 with the file keyfile.bin from Tossu (many thanks for the hack !)
-Cross cabel RS232 female-female (2->3; 3->2; 5->5)
-Free software Termite from Compuphase (https://www.compuphase.com/software_termite.htm)
Connect everything together. Start the computer first and launch Termite.
Termite Serial port settings:
-Port COM1 (depend on your computer)
-Baud rate 9600
-Data bits 8
-Stop bits 1
-Parity none
-Flow control none
-Forward none
-Transmitted text Append CR-LF
Turn on the DL3021
To check the connection, you can try to type *IDN? in the Termite command line.
He will return the model of your device.
Type in Termite :PROJ:SET MODEL,DL3021A
That all
Hello friends
In 2021 I tried this on my new DL3021, with no success. SW version is 00.01.05.00.01. RS232 works well. Command "*IDN?" returns product name, serial number and SW version. Command ":PROJ:SET MODEL,DL3021A" does nothing.
Any idea is welcome.
Thanks
Ed
the command is correct! And it is normal you don't get any reply after you send it. Only after a reboot you can see the model has changed.
Are you sure you build correctly the usb thumb drive? I used win32diskimager and all was smooth...
BTW: I used USB connection to instrument not RS232 and key sight connection expert to send SCPI commands.
Hope this can help!
NM
Hello natman69
Thank you for your response. I installed a keysight connection expert and connected to DL3021 via USB, but the result is the same:
-> *IDN?
<- RIGOL TECHNOLOGIES,DL3021,DL3AXXXXXXXXX,00.01.05.00.01
-> :PROJ:SET MODEL,DL3021A
! VI_ERROR_TMO: A timeout occurred
Visa ErrorCode: 0xBFFF0015 (-1073807339)
The same result is for command":PROJ:SET MODEL, DL3021A"
When command had been used, I tried "turn off and on" DL3021 and also tried make intial Reset DL3021, but no change version model to A.
Ed
Hope this can help!
NM
Hello natman69
-> *IDN?
Ed
Hope this can help!
NM
Hello natman69
-> *IDN?
Ed
Mr _Wim_, natman69 and aloso tossu
Thank you very much for your help. It really was my fault - a badly prepared USB key. Now I can confirm the hack is also possible with this latest firmware.
Everything is OK. The Keysight connection expert immediately set new product name to A and switched ON colour displey.
Status from The Keysight connection expert:
<- OK
Now it's a really great device
Thanks again for big support, I wish you all good health in this post covid time and have a nice day.
Ed
Hello friends , need help…
Using this method, success. (FW:00.01.05.00.01)
However, about one minute after power on, the high-resolution disappears automatically.
The option function also disappears (color UI is still there)(Attachment Link) " alt="" class="bbc_img" />
What model number does your unit return when you send -> *IDN?
I do not have a Rigol load, but if I am not mistaken, the color display is always enabled and there is no change when upgrading from a DL3021 to an DL3021A. Did you see the increased readback resolution on the display briefly? Can you make a picture of that? My best guess currently is the patch was not applied correctly and nothing was changed and it did not disappear automatically...
Thanks!
FYI:(Attachment Link) " alt="" class="bbc_img" />
Hello all,
Hoping this isn't the wrong place to ask, as this seems to be discussion around the model change hack, but I just bought and received a secondhand DP832, and immediately updated to the latest firmware. I then tried to apply the riglol hack (entered my serial number on the page, left the AAAA default options, and it generated a licence key.
However, when i try to install the key at the "licence" prompt, after entering all the characters, I press OK, and it says "Invalid Serial" number. I have tried twice without success, and even tried regenerating the key on the site several times - it creates the same key every time. Double checked that my serial number was accurate too...
Am I doing this wrong? Or is the latest firmware different and no longer allows the licence hack to work?
Hi Mate.
Can you please point me in the right direction for the download link of keyfile.bin from Tossu for the Rigol DL3021A Mod
regards
DTHCoCo
