Ok, here's some more: I checked the clock on pin 14 of U211, it's bang on to what the oscillator is putting out. There is activity on pins 8,9,11,12 (see pics). Funny thing is that the EXACT same data is on the outputs of U210. You can see they feed U206, which feeds the drivers for the displays 2 LSDs. This explains why the 2 LSDs are stuck on "7" and never change.
U214e is working, as you can see it is inverting the signal from U211 pin 11. Pin 15 of U210 is outputting to the other chips (I forgot to snap a pic of the wave). HOWEVER, pin 15 of U209 (and U208) is doing nothing, and the output pins are carrying different, steady, DC voltages. These voltages translate through U205 to the drivers, and explains(?) why the 2 MSDs don't know what to do.
U209 U208
pin 11 = 1.50V pin 11 = .12V
pin 12 = 4.24V pin 12 = .13V
pin 13 = 4.30V pin 13 = .14V
pin 14 = 4.34V pin 14 = .14V
pin 15 = 0.12V pin 15 = .11V
Regarding pin 13 of U215....I get this 2 pulse "blip" running at 1MHz, and it is riding on a 120Hz (ripple?) wave. See pics. So now it seems I have another problem that is off of the logic board. Before I go yanking chips, I'm going to wait to get the ps caps replaced. Just wanted to give an update on things. Anything else I should/could check in the meantime? Thanks for all your help, everyone!
