Author Topic: delete  (Read 711 times)
Offline Hootis TigglebitsTopic starter
delete
« on: September 12, 2024, 04:29:32 pm »
delete
« Last Edit: December 19, 2024, 06:38:43 pm by Hootis Tigglebits »
Online KungFuJosh
  • TEAS is real.
Re: Need Oscilloscope Probe Suggestions
« Reply #1 on: September 12, 2024, 04:53:07 pm »
I generally love the quality of ProbeMaster.com probes, but they don't make those specs unless 300MHz is a typo. I've not seen any 1:1 probes that do higher bandwidth. 30MHz is around the limits I've seen, though I haven't looked that hard.
The following users thanked this post: egonotto, Anthocyanina
Offline tggzzz
« Reply #2 on: September 12, 2024, 06:10:14 pm »
What is "inaccurate" about your existing probes? Having a sharper tip probably won't improve accuracy.
At such frequencies there are many ways in which probes can be misused. For example, what is the load they have on the circuit? (Hint: not 10Mohm!) Will that affect your circuit?
Significant improvements in accuracy might require improved probing technique and/or a different class of probe. FRI see the references at https://entertaininghacks.wordpress.com/scope-probe-reference-material/
« Reply #3 on: September 12, 2024, 06:23:57 pm »
Sorry for not being more clear, I've noticed when comparing the waveforms that these probes see vs. a Tek probe on the same scope that these tend to have more noise. The finer tip is needed due to the size components I work with, 1.3mm in diameter on the H&S probes vs .75mm in diameter on the Tek probe I have.  I'll read the link, but I was trained on using scopes by two seasoned electronics engineers, so I'm confident I'm using them correctly; however anything is possible.
Offline David Hess
  • DavidH
« Reply #4 on: September 12, 2024, 06:31:39 pm »
The Probemaster 4900 Oscilloscope Probe Deluxe Kit appears to have exactly what you are asking for, but 300 MHz means a x10 probe.
Offline Phil1977
« Reply #5 on: September 12, 2024, 07:37:22 pm »
Regarding 1x probes:
Offline tggzzz
« Reply #6 on: September 12, 2024, 08:08:55 pm »
Many seasoned electronics engineers use scope probes "suboptimally". It isn't a subject explicitly taught during courses, so many end up learning the hard way.
I would expect the trace from a *1 40pF scope probe to look less "noisy" than that from a *10 10pF probe, due to attenuation and the low pass filtering effect.
What was the signal amplitude, frequency, risetime for digital circuits, impedance and/or logic family?
Was the noise broadband or single frequency?
Was the noise correlated with the signal?
How was the probe connected to the UUT?
A photo of the problematic scope traces and how the probe is connected to the UUT would be useful.
Offline Fungus
« Reply #7 on: September 12, 2024, 08:53:28 pm »
  • Bandwidth: 300 MHz
    Max Voltage: 55V RMS CAT II
    Attenuation Factor: 1:1
    Input Impedance: 1 MΩ // 39 pF
300Mhz 1:1 ain't happening.
Offline BillyO
« Reply #8 on: September 13, 2024, 04:54:30 am »
All depends on the depths of your pockets.  The "under $250" part is what's not happening for a 1:1 probe.
However, Tek P6139A probes can be had used in 9.5/10 condition for under $250.  They are 10:1 probes but I don't see that as an issue.  I don't know why the OP thinks it is.  However, they tick all the other boxes.  They are thin, miniature probes with a variety of ground options.  As well the user can modify the "normal" grond clip if they wish.
« Last Edit: September 13, 2024, 05:02:49 am by BillyO »
