I've not seen or used the software but I would expect the correction factors for each Autocal module to be stored internal the module - if not without the original parameters the module would be pretty useless.
edit - I've been told the correction factors may not be stored in the modules - but that you can characterize them yourself if you have a known good cal kit with a sliding load etc.
