Author Topic: Need some help selecting a power supply  (Read 942 times)
Offline RespawnRestrictedTopic starter
« on: April 01, 2020, 04:18:23 am »
Re: Need some help selecting a power supply
« Reply #1 on: April 01, 2020, 04:35:24 am »
They're both SMPS based so are very likely to have some good amount of HF ripple.
That can be mitigated some with additional caps on your circuits but that's not to say these are easy to get really clean.
What's your primary use as maybe there's a better fit for your needs ?
Offline maginnovision
« Reply #2 on: April 01, 2020, 04:41:37 am »
I've had bad luck with the tacklife. Earth isolation issues, output capacitance issues causing roughly 1v p-p noise on the ouput, current regulation issues(multiple supplies). If it's gonna be one of those I say not tacklife. Unless you need the 10A I'd recommend a dr.meter linear supply or something.
« Last Edit: April 01, 2020, 05:01:45 am by maginnovision »
Offline Jan Audio
« Reply #3 on: April 01, 2020, 02:00:00 pm »
That Tacklife looks like peaktech 6225A only then black.
Online nctnico
« Reply #4 on: April 01, 2020, 02:10:36 pm »
At least the Tacklife may have 5 turn potmeters. This model is sold under many different names. These supplies are OK if you need a lot of power but they aren't suitable as bench power supplies if you want to measure circuits. The output noise will swamp any signal you try to measure.
« Reply #5 on: April 01, 2020, 07:20:52 pm »
the main use is just gonna be for building projects with led strip lights powering motors charging batteries and basic things so it does not have to be ripple free . i was just looking for best on i could find at  30v10a for under $100 u.s.
« Reply #6 on: April 01, 2020, 07:37:03 pm »
OK. Do your really need 10A ?
I've had good success with the 5A MCH K305D and haven't been able to bust them in normal tests.
I commonly use mine near full output charging 24V batteries.
Thread about them here:
https://www.eevblog.com/forum/testgear/cheap-variable-switching-power-supply/
