Basically, I got a set of HP 8510C for free recently, but it didn't come with any original cable.
It needs some non universal cable that costs more than 400$ on ebay, I probably need to figure out a way to make them myself.
08510-60101 for connection between VNA and display, both male 37 D-SUB on each side.
08510-60102 for IF signal between S-parameter test set, 24W7 D-SUB with coaxial contact, one male and female on the other.
I ordered the right connector already, now the problem is to findout the correct order. Can anyone with 8510 check their pinout of these two with a multimeter?
Thanks for any related clues.
