Markus,
The more time you spend with these SDS2000X + scopes the more you appreciate the superb instruments they are, that was my take away since this was the 1st MSO or DSO I have purchased for myself. Also had not used a DSO or MSO much at all when working, since my value was deemed outside the lab, but after retiring wanted more "hands on" so got a couple old Tek 2465 analog scopes to fix and use. Earlier last year pulled the trigger on a SDS2000X + based all the discussions here, figuring I needed something to record waveforms better than a iPhone image of the Tek 2465 display. I had never heard of Siglent, but went ahead with the purchase after spending time here to decipher the sources of all the comments, the fan folks, BSers, haters, and so on. Once you get a hand on the comment source, then things become much easier to navigate thru, and the path much clearer.
This is by far the most useful and feature rich instrument I had ever used, my poor old Tek 2465s don't even get powered on anymore!! The more use, the more impressed
Try a wireless mouse, works seamlessly with the GUI, the 10 bit mode, the FFT, the Bode plot and so on. The front end design is spot on, with low noise, good bandwidth & linearity, and good accuracy, which sets the "tone" for the rest of the instrument.
You navigated the path and made a good decision IMO
BTW you probably can tell I'm a Siglent fan, yes, but only because I have hands on experience and don't bash other equipment that I've never used or owned. Also will point to issues with Siglent, like the failed PP215 scope probe, or the issues with the SPD 3303X-E
Edit: Should mention we now have 2 of these scopes, 1st was a 2 channel (the 4 channel was unavailable). I got a 1st hand introduction to the innards of the 2 channel due to an unfortunate (long story) accident, and got another pleasant surprise. This instrument not only performed like something that should cost 2~3X, but the build quality looks like something that should cost 2~3X
Best,
