Author Topic: New $40 2ch pocket scope, 2MHz/50MSps (august 2023)  (Read 3464 times)
Online tunkTopic starter
  • Country: no
« on: August 11, 2023, 08:02:46 pm »
- analog bandwidth 10MHz, actual bandwidth 2MHz (??)
- 50MSps
- storage depth 20kB
- 3.2" screen, 320x240 pixels
- size 120x66x18.5mm
https://www.aliexpress.com/item/1005005879558074.html
https://www.aliexpress.com/item/1005005878267272.html
Offline siealex
  • Country: ua
Re: New $40 2ch pocket scope, 2MHz/50MSps (august 2023)
« Reply #1 on: August 11, 2023, 08:28:48 pm »
Does it use the same ADC as the Zotek ZT702S (or possibly two such ADCs)? The characteristics look surprisingly similar.
Online Aldo22
« Reply #2 on: August 11, 2023, 09:49:21 pm »
Yes, it's cheap for a 2-channel scope, but does it have a name?
I don't even know what to google to find out more.
Offline Shonky
« Reply #3 on: August 11, 2023, 09:58:05 pm »
Says SCO_2_10M in the second image.
Online Fungus
« Reply #4 on: August 12, 2023, 07:55:59 pm »
What does that mean???
Maybe it's like the Zeeweii which is sold in two versions, 1Mhz and 18Mhz, even though they're identical hardware. The only difference is the type of probe, the "1Mhz" version comes with crocodile clips and the "18Mhz" version comes with a 10x probe. You can use your own probe with the 1Mhz version and it works at 18MHz.
https://www.aliexpress.com/item/1005005762980323.html
It's not worth doing it though, 6 Euros more for a probe+battery is a bargain.
(I'm holding out for a 2-channel version of that - they're awesome little things and as small as a credit card)
Offline Doctorandus_P
« Reply #5 on: August 12, 2023, 08:27:19 pm »
This could be a fun gadget for that price but it does have to have a decent level of reliability and trustworthiness.
I am more interested in a Siglent for anything serious, but still consider buying something like this just for shits and giggles or for hacking into. But some level of trustworthiness is still mandatory. The Fnirsi garbage for example does not do that, because it blatantly lies about it's specifications, and on top of that tries to hide this by always dong some weird averaging on the signal. That thing is just horrible.
This is all the more important because gadgets like this are targeted to the beginners market, and those beginners don't have the skills to interpret the limits and recognize the faults. I'm guessing fnirsi relies on that, and that makes them sneaky bastards all the more.
This thing also does not start well in that regard.
What does a "Sampling rate: 50M/Channels" mean?
And a bit lower, it suggests an "Actual bandwidth" of 2MSa/S/Channels, which could be interpreted as 1Msps if both channels are on.
But "Analog bandwidth" also uses "10MSa/S/Channels".
And someone should tell them that seconds is a lower case s, Upper case "S" is for Siemens, which does not make sense in this context.
To me it's a lot of Chinglish that adds to the confusion.
But still, I'd like to see thorough review, including a teardown of this thing. Especially if it has a half decent analog frontend. But even if it is decent, it is unlikely that I would buy one. It is the lack of a rotary button that does it for me. I'm addicted to rotary buttons. I have bought the "DSO Shell", (which does have a rotary button) and I would have liked it if it had better triggering.
« Last Edit: August 12, 2023, 08:37:11 pm by Doctorandus_P »
Online Aldo22
« Reply #6 on: August 12, 2023, 08:32:59 pm »
Wrong store link.  ;)
I recommend the Zeeweii Official Store.
They will answer questions if you bought there and send you firmware updates if necessary (the latter from hearsay).
https://www.aliexpress.com/item/1005004972406356.html
« Last Edit: August 12, 2023, 08:36:22 pm by Aldo22 »
The following users thanked this post: RAPo
  • Country: no
Re: New $40 2ch pocket scope, SCO2, 2MHz/50MSps (august 2023)
« Reply #7 on: September 05, 2023, 09:56:07 pm »
Found a shortish review, summed up as:
- The analog bandwidth is about 7MHz.
- Auto is useless in 2ch mode (probably a bug).
- The x10 probe cannot be calibrated because there is no reference signal.
- The operability is not good (although all cheap models are the same, so
   it's not a particular drawback of this).
- For the price, it has 2ch, several MHz bandwidth, cursors, and trigger
   movement on the time axis.
- The current measurement function is a major feature of this model.
https://www-jh4vaj-com.translate.goog/archives/40424?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=en-US&_x_tr_pto=wapp
Online Aldo22
« Reply #8 on: October 31, 2023, 01:28:47 pm »
There's a video in Portuguese:
  • Country: no
  • Country: no
« Reply #10 on: May 30, 2024, 03:12:51 pm »
Another review, basically it meets it's 10MHz spec: https://youtu.be/watch?v=6ggLijMyODE&pp
