I picked up a JYTech DSO138 as a kit (like the one Fungus linked to) so I could get in some SMD soldering and have something useful as a result. (There are clones and fakes out there and JYTech were keen for people to know how to tell the difference.)
The UI is awkward, but it does work as a scope. It is limited in what it can do, so don't expect anything serious from it and you won't be disappointed.
I did use it in anger once for a situation where I nothing else I had could do the job safely. I wanted to see the operation of a certain signal (around 5V amplitude) in a circuit that floated at a couple of hundred volts - so I powered it from a battery, attached it and set it up before applying power to the DUT. It performed perfectly for the task ... as a fully floating scope.
One day I might spring for some differential probes.
