Author Topic: New 2GHz touchscreen scope from Tek, June 6th  (Read 280438 times)
    • Mike's Electric Stuff
« Last Edit: May 18, 2017, 06:05:53 pm by mikeselectricstuff »
Day Job: Mostly LEDs
Offline Avacee
Re: New 2GHz touchscreen scope from Tek, June 6th
« Reply #1 on: May 18, 2017, 04:39:31 pm »
That link is pre-populated with your personal details ...
Edit: Thanks for the heads-up - have entered :)
« Last Edit: May 18, 2017, 06:05:23 pm by Avacee »
Offline BravoV
  • +++ ATH1
« Reply #2 on: May 18, 2017, 04:45:39 pm »
Yeah, that is nasty ...  :--
Offline amitchell
« Reply #3 on: May 18, 2017, 04:50:55 pm »
He didn't mean too, he would be disqualified if entering it twice. It's probably just the way the form works.
Offline Avacee
« Reply #4 on: May 18, 2017, 04:53:27 pm »
I wasn't suggesting Mike was trying to get more entries but that anyone following the link would see his details ....
Apologies for not being clearer.
Offline BravoV
  • +++ ATH1
« Reply #5 on: May 18, 2017, 04:53:37 pm »
I know, he accidentally just copied the url when the typed the entry.
Mike, you better edit your 1st post.
Online JPortici
« Reply #6 on: May 18, 2017, 04:54:20 pm »
Quote from: T&C
The Sweepstakes is not available in countries, states or provinces where local laws prohibit such offers, including Belgium, Sweden, Italy, Spain, Puerto Rico, and Quebec, Canada.
whatever, it's not like i wanted a tek scope.
image and quotes suggest it's more than 4 channels?
« Last Edit: May 18, 2017, 04:57:49 pm by JPortici »
Online JPortici
« Reply #7 on: May 18, 2017, 04:55:33 pm »
this is the link: http://info.tek.com/en-a-new-era.html
but since i previously entered following mike's link it's populated with all his data. boo tek.
« Last Edit: May 18, 2017, 04:58:00 pm by JPortici »
Offline mubes
  • Do Not Boil
« Reply #8 on: May 18, 2017, 04:55:47 pm »
Edit the URL to remove the stuff after the ?
Offline TheAmmoniacal
  • Country: ph
« Reply #9 on: May 18, 2017, 04:58:26 pm »
Yeah, Mike's phone number is in the form, I don't think that one is public. The rest of the information is though. You can remove all the identifying parts in the URL and shorten it to: http://info.tek.com/en-a-new-era.html
I filled it in too, but I'm not affiliated with any company, just wrote "none".
Offline PartialDischarge
« Reply #10 on: May 18, 2017, 05:10:58 pm »
seems like 6 or 7. It will probably be awesome, Well, I'll get one when it reaches the second hand market in 20 years
Offline BravoV
  • +++ ATH1
« Reply #11 on: May 18, 2017, 05:15:35 pm »
And whine its so hard to find the hybrid ic .. customized chip replacement ?  :-DD
Offline rx8pilot
« Reply #12 on: May 18, 2017, 05:21:02 pm »
My guess is any extra connectors on the front with be a AWG, trigger - not 7 or 7 analog channels.
Offline Muxr
« Reply #13 on: May 18, 2017, 05:27:25 pm »
June 6th is the reveal. Sounds interesting. #MTGA (Make Tek Great Again?)
The following users thanked this post: Monittosan
Offline technogeeky
  • Older New "New Player" Player Playa'
« Reply #14 on: May 18, 2017, 06:00:17 pm »
I don't quite understand how, but I guess it's because the URL is capitalized that that link gets forwarded to "http" which my browser assumes is really "http.com"...
edit: Yeah, it appears moving to lower case http fixes it.
But anyway, the 1st post needs another edit.
edit: mike, just use the link I made. lol.
« Last Edit: May 18, 2017, 06:05:05 pm by technogeeky »
Offline tablatronix
« Reply #15 on: May 18, 2017, 06:01:51 pm »
wow they made a form that uses GET and not POST and puts your info into the query string ?
tsk tsk
The following users thanked this post: janoc
« Reply #16 on: May 18, 2017, 06:06:26 pm »
Bloody phone text UI....
« Reply #17 on: May 18, 2017, 06:07:48 pm »
Re. channels, I'd guess either 32ch MSO or 6ch analogue - some applications lihe 3-phase motor drives could use this for simultaneous V/I on all phases.
Offline rx8pilot
« Reply #18 on: May 18, 2017, 06:11:01 pm »
If it goes that route - I wonder if they will have 10 or 12bit A/D to go head-to-head with LeCroy 8ch  - maybe this will be lower cost than that? For power applications - dynamic range is good to have
Online JPortici
« Reply #19 on: May 18, 2017, 07:00:41 pm »
32ch MSO
but.. why 32 channels? (I mean, applications?)
« Last Edit: May 18, 2017, 07:15:45 pm by JPortici »
« Reply #20 on: May 18, 2017, 07:16:03 pm »
32ch MSO
Because it's "More". like 2GHz is more. Tek have failed to keep up with the competition on similar specs, so maybe now they're trying to find niches not served by them.
Offline MrW0lf
  • Country: ee
    • lab!fyi
« Reply #21 on: May 18, 2017, 07:25:24 pm »
At least on Pico X+16 MSO you run out of all digitals if use 16x1bit as 16bit ADC input to gain 16bit "virtual channel". With 32 would still have 16 left... Of course if such thing even possible on Tek. As for analog channels - indeed run out of them in no time when attach to some motor... +use digitals to listen for 24V PLC signaling. So think more the merrier :-+ Besides micros and HF signaling there is whole world full of actual machinery that does actual stuff. But if its 2GHz... hmm... Tweak 3ph motor plus wireless signaling instead of 24V at the same time maybe :-/O
In that case they should install enough memory so it could run at least 5GSa/s in ~100ms/ timebase.
« Last Edit: May 18, 2017, 07:28:22 pm by MrW0lf »
Offline nctnico
« Reply #22 on: May 18, 2017, 07:31:55 pm »
32ch MSO
Yokogawa has had scopes with many (>4) channels for decades so it isn't new.
Offline rx8pilot
« Reply #23 on: May 18, 2017, 07:57:23 pm »
32ch MSO
I have (only once) used all 16 channels on my MSO. It was an unusual case for sure.
« Reply #24 on: May 18, 2017, 08:25:20 pm »
32ch MSO
I wasn't being entirely serious about 32ch MSO, but it would be a relatively cheap way to claim "The Most channels". I highly doubt it's >4 channels at 2GHz though ( or if it is, the price is way into 5 figures for that configuration)
Though re-reading the Tek site : "...with unparalleled digital visibility..." maybe it is more MSO channels
« Last Edit: May 18, 2017, 08:28:02 pm by mikeselectricstuff »
