Author Topic: New 2GHz touchscreen scope from Tek, June 6th  (Read 280758 times)
Offline Fungus
Re: New 2GHz touchscreen scope from Tek, June 6th
« Reply #250 on: June 05, 2017, 06:41:16 am »
If you're gonna argue that there's no advantage at all to at least a few physical knobs then you are veering into USB scope territory.  Paging Mr. Wolf....
I never said that, I just said you have a lack of imagination about what touchscreens can really do of you give them a chance.
Want a physical knob? How about the one Microsoft put in their Surface Studio?
(in the middle of this video somewhere):
Offline snoopy
    • Analog Precision
« Reply #251 on: June 05, 2017, 11:48:53 am »
Only a few more hours to go !!  :box:
Offline David Hess
  • DavidH
« Reply #252 on: June 05, 2017, 12:15:25 pm »
Along with transparency, most animation, and low contrast, skeuomorphic interface elements like knobs represent everything which is soulless and wrong in graphical user interfaces.
Online ebastler
« Reply #253 on: June 05, 2017, 12:33:24 pm »
Why would a physical knob (as present on the Surface Studio), which serves the function of a physical knob, be deemed skeuomorphic?  :-//
Offline David Hess
  • DavidH
« Reply #254 on: June 05, 2017, 12:51:41 pm »
Is it an actual physical interface?  I must be thinking of a different product.
Offline timb
    • timb.us
« Reply #255 on: June 05, 2017, 01:10:07 pm »
Yes, it's even in the thumbnail for the video. (Hint: To the left of the keyboard.)
It's basically a rotary encoder attached to a chunk of aluminum with a capacitive elephant on the bottom, so the screen can sense where it's being placed.
Griffin actually makes a similar, standalone (non-touch screen) product that works with any Mac or PC. They come in wired and wireless versions. Basically a machined block of aluminum with a clear rubberized base (which houses LEDs for user feedback). They have a full API available for third party developers to integrate it into their software. It's pretty neat, actually. (I bought one back in 2003 or so when they originally came out with them. Was nice for scrubbing video and scrolling long documents.)
« Last Edit: June 05, 2017, 01:14:55 pm by timb »
Offline Fungus
« Reply #256 on: June 05, 2017, 01:11:15 pm »
Yes, it's a physical knob that you can place anywhere on the screen and turn to control things.
Microsoft's knob is a bit big for an oscilloscope, but...  :popcorn:
« Last Edit: June 05, 2017, 01:13:12 pm by Fungus »
Offline BrianH_Tektronix
  • BSEE | Tek Product Marketing Manager
« Reply #257 on: June 05, 2017, 04:58:04 pm »
Here's my illustration for what the new scope will look like:
Tek's response -->  Love it  :-DD :-DD :-DD
Product Marketing Manager & NPI planner, Tektronix Low Profile Scopes & Digitizers
Offline serggio
  • Country: ru
« Reply #258 on: June 05, 2017, 06:40:26 pm »
Trigger limited CH1 and CH2 only.. In your new scope too?  :-DD :-DD
Offline David Hess
  • DavidH
« Reply #259 on: June 05, 2017, 06:55:21 pm »
Having the trigger source limited to one or a limited number of input channels (1) is actually a pretty common limitation in very old or specialized oscilloscopes.  Sometimes there is no room to implement a full channel switch for the trigger path and sometimes it is for performance reasons.
(1) Or even none!  Early oscilloscopes just had a vertical trigger source from after the vertical channel switch in place of all of the input channels which is where the "VERT" trigger source came from even though later it did not work in the same way.  You can see this even in the last analog oscilloscopes which Tektronix made.
« Last Edit: June 05, 2017, 07:00:19 pm by David Hess »
The following users thanked this post: eKretz
« Reply #260 on: June 05, 2017, 07:11:15 pm »
Nope, there will not be such limitations in triggering. All mainstream scopes on the market today have A/B sequencing trigger modes that can be any channel you select. In fact on today's Tektronix windows scope you can do A trigger--> B trigger --> visual trigger, allowing for many many trigger combinations. The same type of sequencing option will be true on this new scope.   :-+
Offline timb
    • timb.us
« Reply #261 on: June 05, 2017, 07:29:38 pm »
:D
If you guys want to send me one of the new scopes I'd be happy to do a more accurate illustration! ;D
Darn, I forgot to extend the selector switch for the trigger source! If I have time tonight I'll fix that.
(That 8 channel drawing is based off this illustration I did for a "Virtual Oscilloscope" web thing I'm working on, which will allow you to upload waveform data in CSV, WAV or RAW format and generate classic CRO looking images.)
« Last Edit: June 05, 2017, 07:36:32 pm by timb »
Online PA0PBZ
« Reply #262 on: June 05, 2017, 07:41:20 pm »
Nothing wrong with a T and external triggering input :)
« Reply #263 on: June 05, 2017, 08:46:16 pm »
Patience, my little Padawan, patience ...
 ;D
Offline j_hallows
« Reply #264 on: June 05, 2017, 08:51:35 pm »
Looks like photos are coming out now.
The following users thanked this post: tautech, electrolust, BrianH_Tektronix
Offline timb
    • timb.us
« Reply #265 on: June 05, 2017, 08:52:59 pm »
Damn! That kind gives me a bit of a chubby...
Offline tautech
« Reply #266 on: June 05, 2017, 08:59:41 pm »
8 channels gives new meaning to a benchtop ratsnest.  :-DD
« Reply #267 on: June 05, 2017, 09:00:39 pm »
Gotta Love it!   :-+ :-+ :popcorn:
Offline GreyWoolfe
  • NW0LF
« Reply #268 on: June 05, 2017, 09:01:45 pm »
Don't get TOO excited now or you will have premature waveform generation! :-DD
Offline ci11
« Reply #269 on: June 05, 2017, 09:58:37 pm »
Feast yourselves.....there are more being uploaded on the same channel as we speak.....including one from w2aew!
https://youtu.be/JDKtllS-Lw0
https://youtu.be/3jd8Iq8YVzM
« Last Edit: June 05, 2017, 10:01:19 pm by ci11 »
The following users thanked this post: thm_w, Octane
« Reply #270 on: June 05, 2017, 10:03:27 pm »
I guess the world knows now
 :phew:  :-+ :-+
Online mikeselectricstuffTopic starter
    • Mike's Electric Stuff
« Reply #271 on: June 05, 2017, 10:08:12 pm »
So to remove a waveform, you have to drag it to the bin, not just double-press like on pretty much any other scope?  :palm:
"first scope designed from the ground up for touch interaction" I think R&S and Micsig  may have something to say about that...
« Last Edit: June 05, 2017, 10:10:09 pm by mikeselectricstuff »
Day Job: Mostly LEDs
Offline nctnico
« Reply #272 on: June 05, 2017, 10:09:40 pm »
Offline tautech
« Reply #273 on: June 05, 2017, 10:10:48 pm »
 :phew:  :-+ :-+
About time, been the 6th for 10 hrs here.  :P
« Reply #274 on: June 05, 2017, 10:14:49 pm »
"Optional Windows to run PC Software on the scope"... What could possibly go wrong  :scared:
