The other day I was at a surplus components warehouse and happened upon some <5 Ohm power resistors that I wanted to check before buying. Unfortunately, the only thing I had in my pocket at the time was an el cheapo CEM DMM (a.k.a., free HF meter). Although the CEM is small and OK for quick low-power measurements, the low quality and high impedance of the probes/leads made it useless for measuring these resistors. Yeah, I know, but the U1252B, U1272A, and U1282A require much larger pockets.
How well do the small ANENG models (with either fixed or removable probes) perform at measuring single-digit resistances?
Yes, as you can see in the picture, small Aneng AN8008 is very usable in this regard.
Result:
( 1 ohm
5% 1% (bought cheaply from ebay) metallic resistor )
Fluke 289: 0.985 Ohm
Fluke 87V: 1.00 Ohm
UT61e: 0.98 Ohm
AN8008: 0.98 Ohm
Very happy with small Aneng in this regard!
Notes:
Meters after REL (except of AN8008 - does not have that button, you have to deduct for yourself), all measurements were performed deliberately with AN8008 leads.
REL was checked even after measurement for sure.
Fluke 289: needs at least 1 minute settling on LowOhm range, then stable reading, seldom jumps 1count.
Fluke 87V (HiRes): very unstable, jumps +- 2 counts, I chose the smallest value, LSD never gets still.
UT61e: very fast, no need to wait long for settling, then stable reading, seldom jumps 1count.
AN8008: need to wait half minute for settling, then little bit unstable LSD jumps +-1count, but much better than Fluke 87V.
