Author Topic: New ANENG Q1 9999 Counts ?  (Read 75043 times)
Online malagas_on_fire
  • Country: pt
  • Kernel Panic
    • Malagas Lair
Re: New ANENG Q1 9999 Counts ?
« Reply #150 on: January 16, 2019, 03:43:25 pm »
Similar deal but a sticker covers the Amps sockets. Ammeter ANENG Q1
https://ebay.us/uJHCMz
Wouldn't that make it everything except an "ammeter"?  :-DD
A good one :P Yeah that way they may also skip the fuses as well. Does it works well for panel meter?
If one can make knowledge flow than it will go from negative to positve , for real
Online Fungus
« Reply #151 on: January 16, 2019, 03:53:24 pm »
For a panel meter I'd use one with a better display. Even if we stick with ANENG they make dozens of little manual ranging meters that would be suitable (and cheaper than the Q1).
eg. This one is "large screen":
PS: Does the Q1 power-on and show a reading automatically after power is applied to a device? One of those will...
« Last Edit: January 16, 2019, 04:34:24 pm by Fungus »
Offline casinada
« Reply #152 on: January 16, 2019, 04:20:39 pm »
The same seller has the Aneng 8009 for $6
https://www.ebay.com/sch/youjin950/m.html?item=283337236145&hash=item41f8371eb1%3Ag%3AA-0AAOSwmvpcOqdA%3Ark%3A5%3Apf%3A0&rt=nc&_trksid=p2047675.l2562
I'm sure he's just trying to establish himself as a seller. Those prices are way low. Shipping costs more  :-//
Online ebastler
« Reply #153 on: January 16, 2019, 07:43:37 pm »
I guess you can remove the sticker; it's only a warning.
It says: "STOP TESTING VOLTAGE IN CURRENT MODE!"
https://www.aliexpress.com/item/ANENG-Q1-TrueRMS-Digital-Multimeter-Button-9999-Counts-With-Analog-Bar-Graph-Ammeter-Voltmeter-Ohm-Voltage/32908396270.html
Good advice, actually.  :P
The following users thanked this post: malagas_on_fire
Online calin
« Reply #154 on: January 16, 2019, 09:08:39 pm »
Now can somebody tell me why the h$@^#@ ?!!! I i just bought other two of these  :-//  I already have two !!!
Thanks a lot "casinada"  !!! It is ALL your fault ;D
I am curious tough if we get anything delivered @ that price.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #155 on: January 16, 2019, 10:11:42 pm »
Thanks :P
Were customers using too much voltage in current mode for such labeling?  :-DD
The price is somehow very low ... hope somebody receives one to confirm shipping :P
Offline sleemanj
  • Professional tightwad.
« Reply #156 on: January 17, 2019, 03:50:33 am »
With the sticker, and this as the first line of the eBay description "Please Note you have to reading the operate manual first before use,otherwise you will burn the device with wrong operat." I imagine they are getting a lot of people putting the probes into the current socket and then putting the other end into the wall socket.
I havn't used one, but I see that the DCA/ACA modes are on the power button... don't tell me that if you hit the power button it goes into DCA mode... that would be quite an easy way to fail.
Online Fungus
« Reply #157 on: January 17, 2019, 06:28:09 am »
I'm guessing you're right.
On the AliExpress page:
* Do NOT input voltage at the Current Mode, the Resistance Mode, the Diode Mode, the Continuity Mode, or the Temperature Mode.
* Do NOT input voltage exceeds 36V DC or 25V AC when you are at the setting of measuring current.
They've probably had a lot of customers claiming "It doesn't work!"  :scared:
Still, it's evidence that the meter is "safe". A complaining customer is a not-dead customer.  :popcorn:
« Last Edit: January 17, 2019, 06:37:00 am by Fungus »
Offline sotos
  • Country: gr
« Reply #158 on: January 17, 2019, 07:41:59 am »
Let’s see how much current the socket can provide.
I have seen it a lot of times usually it happens from inexperienced DIY guys.
Offline sleemanj
« Reply #159 on: January 17, 2019, 08:41:50 am »
Yeah but you don't see these warnings or stickers on other meters, there must be something about this one which makes it more likely, or more of a problem.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #160 on: January 17, 2019, 09:28:41 am »
Well the uni-t 50b has some warning symbols printed near to the sockets and this meter is quite old, from 2010 , but yet stickers rather new. :
https://www.fasttech.com/product/1204400-uni-t-ut50b-2-5-lcd-handheld-digital-multimeter
Good spoting on the description.
[Edit] Forgot to mention the date of the meter and sorry the english...
« Last Edit: January 17, 2019, 12:49:22 pm by malagas_on_fire »
Online Fungus
« Reply #161 on: January 17, 2019, 11:50:19 am »
Let’s see how much current the socket can provide. I have seen it a lot of times usually it happens from inexperienced DIY guys.
Make sure the wires are OK?  :-DD
There's nothing intrinsically different about it, the sockets are labelled just like all the others.
Maybe it's just the start. Maybe all meters will have those stickers soon now that the price is low enough for tempt more people to buy direct from China.
Online Fungus
« Reply #162 on: January 17, 2019, 12:12:10 pm »
Delete that, I just watched Dave's video again and it auto-detects the ranges when you move the leads around. If you plug it into the mA range it selects mA for you and allows current through. The other meters need you to select mA with the dial before current flows.
I'm not sure what demons are unleashed by that feature but I'm guessing quite a few people have done that then tried to return it after it went bang.
PS: I'd forgotten that the display is unreadable at 2.4V battery voltage. That's game over, right there.
« Last Edit: January 17, 2019, 12:14:14 pm by Fungus »
Online Fungus
« Reply #163 on: January 17, 2019, 04:29:28 pm »
I'm tempted to order one just for the leads, case and submersible temperature probe.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #164 on: January 17, 2019, 05:11:37 pm »
In the description is there a mistake?
 "Do NOT input voltage exceeds 36V DC or 25V AC when you are at the setting of measuring current. "  or doesn't handle 250V volt on the Amps scale for example measuring current in DUT on a mains circuit.... That would give some burned multimeters....  if exceding this voltages :P  It is also written in the manual...
For acessories thats a good bargain indeed
Online Fungus
« Reply #165 on: January 17, 2019, 05:28:02 pm »
Presumably that's what it takes to blow the fuse (current given by Ohm's law).
I just noticed it's the model with NCV as well. Overcome by GAS, I ordered one.  ::)
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #166 on: January 17, 2019, 05:39:17 pm »
Sorry it is not written in the manual that warning but another:
"When the voltage to be measured exceeds 36V
DC or 25V AC, the operator shall be careful
enough to avoid electric shock."
Doesn't refer about maximum allowed / rated voltage on current measurement. So are added notes :P
Offline floobydust
« Reply #167 on: January 17, 2019, 06:02:45 pm »
ANENG products approved to 3V under 61010. After all, it does just run on a pair of AA batteries...
It is a way to fudge safety certification (claims), so they need the <36VDC spec.
Offline martin1454
« Reply #168 on: January 23, 2019, 09:26:05 am »
Will be interesting to see if I will recive the 6$ multimeter there were on ebay - Just checked the order:
We had to remove this listing from the site and you're not required to complete the transaction. If you've already sent payment, the sale should process as normal and you don't have anything to worry about. If you have any questions about delivery, please check tracking or contact your seller. If you run into any trouble along the way eBay is here to help. Please visit the Resolution Centre to help resolve any problems you may encounter.
This user is no longer registered on eBay.
This item has been dispatched.
I have a tracking number,  but it only says: Jan 19, 2019
22:34pm PST
Tracking number provided
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #169 on: January 23, 2019, 09:35:16 am »
I had one richmeters RM101 that was on that situation of listed item being removal and it came to PO box luckly.
Online Fungus
« Reply #170 on: January 23, 2019, 10:43:46 am »
22:34pm PST
I get the same thing!
Offline stj
« Reply #171 on: January 23, 2019, 03:32:44 pm »
i hate ebay - 99% of my shopping now is from aliexpress.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #172 on: January 23, 2019, 05:11:09 pm »
22:34pm PST
I have been in this situation before; eBay will not allow opening a case before the end of the estimated delivery time - which in my case is March 20th. Just have to keep an eye on the mailbox and/or the date (time to put an alarm on my scheduler).
If that was a scam, what annoys me is that I received the promotion via eBay e-mail. I even got an AN8009 together with the RM409B.
I saved the screenshot of both listings if you are interested (and if you end up receiving something that does not match the description).
The following users thanked this post: martin1454
Offline martin1454
« Reply #173 on: January 24, 2019, 12:26:22 pm »
@rsjsouza Well, then we just play the waiting game - thanks for the screen shots, I also bought both the 8009 and "Q1"
Online Fungus
« Reply #174 on: January 24, 2019, 12:35:29 pm »
Yep. It's only $6, not $600. Let's wait and see.
Those prices were very suspicious though.  :D
