Author Topic: New ANENG Q1 9999 Counts ?  (Read 75033 times)
Offline all_repair
Re: New ANENG Q1 9999 Counts ?
« Reply #200 on: March 05, 2022, 06:16:18 am »
My Aneng Q1 was unused for some time, after that, it just selects the functions and incorrect reading in the DC and AC scale.
Test with a new battery
The following users thanked this post: Fungus, wandows
Offline wandows
  • Country: br
« Reply #201 on: March 05, 2022, 11:16:30 am »
I tested with a new battery but the problem remains!
Online Fungus
« Reply #202 on: March 05, 2022, 12:13:11 pm »
Take it apart, clean the rotary switch contacts and PCB.
Are you sure nothing bad happened the last time you used it? What did you measure with it?
Offline wandows
  • Country: br
« Reply #203 on: March 05, 2022, 12:35:05 pm »
The batteries leaked a little and I took the opportunity to disassemble it and clean it as you mentioned.
Before that, no wrong measurements were taken (this Aneng is not always used).
Online Fungus
« Reply #204 on: March 05, 2022, 01:09:17 pm »
In other words: Something bad did happen. Why didn't you mention that?
The PCB could be contaminated, the rot could even have got inside a component which would be difficult to fix. You could try scrubbing with IPA and a brush but at this price you're probably better off getting a new one.
And don't use any more alkalines in stuff that goes long unused for long periods.
Offline wandows
  • Country: br
« Reply #205 on: March 05, 2022, 01:29:41 pm »
It was a big oversight not to mention it, I'm sorry!
Now it's complicated the situation
It was a big lack of attention, unfortunately!!!
Online Fungus
« Reply #206 on: March 05, 2022, 03:07:53 pm »
It's something we've all been through.  :)
https://www.eevblog.com/forum/chat/durahell-batteries/
Offline trobbins
« Reply #207 on: March 05, 2022, 10:30:01 pm »
I have had two 8009's for nearly 4 years and I use them both a lot on the bench.  There is a lot of convenience about a small battery operated DMM, especially when multiple realtime measurements are needed on a device and where some measurements are floating at hazardous levels.  Mine remain accurate against 5-6 digit meters so far.  The only growing inconvenience has been the zero level for resistance, where the dial switch resistance can be substantial and require a resetting of the dial to make a good zero level - that is not a show stopper for me as I am frugal with my test instruments and so just confirm the zero level if the application needs to know that zero is zero.  I bought the two units when 8009's were cheap, with a full awareness of likely longevity issues, so have no regrets at all with their present operating condition.  The only change to default operation is the use of different test leads and clips.
It would be interesting to know if anyone has been using the Q1 approaching that amount of time and has noticed degradation or inconvenience related to the relay's operation, or front panel switches, as those are likely the main difference between models and longevity.
Offline floobydust
« Reply #208 on: March 06, 2022, 12:29:30 am »
My AN8008 is working fine after I used PPE contact cleaner (DeOxit) on the rotary switch. Before it was awful, high (zero) ohms readings, power cutting in and out. It's the crappy copper wipers oxidizing. I'd used oil, grease, teflon lube etc. but nothing lasted. Now it's around 0.15 ohms leads shorted in ohms-mode and consistent, reliable.
The little 8-bit MCU it's written in assembly language and minimal OTP or mask ROM memory, so I wouldn't expect the feature really needed- NULL or ZERO.
For the Q1, as always gold is expensive but necessary on signal relays. Hongfa HFD2/003-M-L2-D relay, "D" option is Ag+gold plated contacts, latching 3V coil.
So I'd expect gold on both sides and a bit of sealing, should beat a cheap rotary switch?
What I don't like about latching relays in multimeters is any bump knocks them to the other latching position, which can be a mess.
Offline blueninja
  • Country: in
« Reply #209 on: October 17, 2022, 04:14:58 pm »
Can anyone post a firmware dump of this Multimeter? I believe I have messed mine up.
Offline floobydust
« Reply #210 on: October 17, 2022, 06:35:56 pm »
There is no firmware to "mess up" so are you trying to copy the product? That would greatly upset our multimeter overlords.
Online ataradov
    • Personal site
« Reply #211 on: October 17, 2022, 06:39:15 pm »
There is an I2C EEPROM IC on the board, but I'm not sure it stores the firmware. It is only 1 KB in size, and mostly likely stores calibration values that would be unique to each meter anyway.
Alex
Offline blueninja
  • Country: in
« Reply #212 on: October 18, 2022, 11:24:49 am »
It’s not firmware, but it has calibration values and device settings. Without them it won’t operate. Can you post a copy so I could fix mine?
Offline indman
  • Country: by
« Reply #213 on: October 18, 2022, 04:28:59 pm »
blueninja Good luck repairing! :)
« Last Edit: October 18, 2022, 04:32:30 pm by indman »
The following users thanked this post: blueninja
Offline ialbert
  • Country: ph
« Reply #214 on: November 11, 2022, 10:56:12 am »
I owned q1. Years ago. It did work ok. But one day most of the value it dives are bad.
It needs calibration. :(
Offline all_repair
« Reply #215 on: November 11, 2022, 11:06:19 am »
change battery first
Offline wandows
  • Country: br
« Reply #216 on: October 05, 2023, 03:18:00 am »
Hey guys!
Unfortunately I have a problem with my aneng Q1.
When measuring the current consumption, I mistakenly placed the test leads in place for a maximum of 200mA, but the consumption exceeded 200mA, and as a result the multimeter only turns on and beeps but does not display any information on the display.
Another interesting detail is that when I put the multimeter on the DIODE scale, it beeps continuously.
I also verified that R18 broke and Q5 was open, but even after replacement the problem persists.
Do any of my friends have any suggestions to help me solve this problem?
Thank you very much in advance!
« Last Edit: October 05, 2023, 06:40:09 pm by wandows »
Online Fungus
« Reply #217 on: October 05, 2023, 08:23:08 pm »
What did you connect it to? There should be a fuse inside these to protect against this.
It sounds like it's very broken, maybe the chip is blown and it can't be repaired.
At this price I'd just replace it.
Offline Atlan
  • Country: sk
« Reply #218 on: March 07, 2024, 04:14:38 pm »
On AliExpress, I discovered stabilizers 3V0
€1.73 | 2x 3.3-6V to 3V DC-DC Step-Down Power Supply Buck LDO Module Voltage regulator Board for 18650 li-ion AAA Dry cell batteries
https://a.aliexpress.com/_EJHonrb
 (max 300mA) with a low voltage drop and a consumption of 0.008mA. When a given multimeter sees a little more current. I installed the battery (glued with double-sided tape) and charging circuit. The connector is glued with instant glue. More on the pictures. The question is whether the glue from the charging circuit holder won't melt :D
P.S:The battery had to be turned the other way around so that the wires went directly to the charging module.
« Last Edit: April 05, 2024, 07:50:19 am by Atlan »
FNIRSI 1013D Always provide a picture or video with the problem where the parameters of the oscilloscope are visible, and a picture of the diagnostic screen with the values.
Offline Atlan
  • Country: sk
« Reply #219 on: March 07, 2024, 04:15:58 pm »
next
Offline Atlan
  • Country: sk
« Reply #220 on: March 07, 2024, 04:17:06 pm »
next
Offline Atlan
  • Country: sk
« Reply #221 on: April 05, 2024, 07:16:03 am »
Set autopower OFF to 15 min
