Author Topic: New ANENG Q1 9999 Counts ?  (Read 71733 times)
Online joeqsmith
Re: New ANENG Q1 9999 Counts ?
« Reply #25 on: June 03, 2018, 07:36:18 pm »
:-DD :-DD :-DD Now THAT is funny!!!!
You don't think it will meet its CAT rating?  :popcorn:
I notice they've gone down a CAT level, it's now CAT II/III instead of CAT III/IV.
 :-DD You were quicker.
Online joeqsmith
« Reply #26 on: June 03, 2018, 07:37:56 pm »
Put a few drops of pump gasoline on that lens and let me know what happens.   It it just another pretty meter?
Offline Fungus
« Reply #27 on: June 03, 2018, 07:54:50 pm »
Maybe they'll have the last laugh.  8)
Actually, I know they will. Whatever's inside it, no matter how power hungry the screen is, I'm sure they're going to sell millions with a design like that. I'm almost tempted to be the first to have one at Arduino club.
Offline GreyWoolfe
  • NW0LF
« Reply #28 on: June 03, 2018, 10:09:28 pm »
And now that the Q1 is out, the 8009, that I paid $19.99 for is now $34.99.  A whole dollar more than the Q1.  I guess they want you to buy the Q1 now.  I am surprised that they didn't do the same pricing on the 8008. :-DMM
« Last Edit: June 04, 2018, 12:40:30 pm by GreyWoolfe »
Offline Mr. Scram
  • Display aficionado
« Reply #29 on: June 03, 2018, 10:15:24 pm »
I want to see the quality of LCD. This is quite a photoshop job they did there. Other Aneng meters have unusable viewing angles.
What makes you say that? The Aneng meters are far from perfect, but the viewing angles and contrast are on par or better with meters from the big boys.
The following users thanked this post: stj
Offline sleemanj
  • Professional tightwad.
« Reply #30 on: June 04, 2018, 01:45:45 am »
The display sure doe look nice, but not if it's at massive battery life destruction.
Not sure about the pushy buttons, but then again, is a preference for dial just really being traditionalist for no reason.
I live in hope that they use proper sized and obtainable fuses, but I won't hold my breath.
Offline Fungus
« Reply #31 on: June 04, 2018, 05:27:28 am »
It's bigger than the AN8008 et. al., they already use ordinary size fuses in their bigger meters (eg. the 860B+).
Offline EEVblog
« Reply #32 on: June 04, 2018, 05:30:39 am »
I've ordered one, we'll see what's it like.
I don't particularly like the inverse screen, might be better in the flesh.
The following users thanked this post: nidlaX
Offline Fungus
« Reply #33 on: June 04, 2018, 08:08:44 am »
Judging by the unevenness of the backlight in the first video, it looks like they're using two LEDs, one on either side of the screen.
If so, current consumption will be about 40mA. With a 2000mA battery that's 50 hours, not good but not awful. For most users of this class of meter it's going to last for many months.
It's nothing like the soul-destroying power consumption of those Agilent OLED meters (which also can't be used while they recharge  :palm: ).
« Last Edit: June 04, 2018, 08:14:29 am by Fungus »
Offline daveshah
  • Country: at
    • Projects
« Reply #34 on: June 04, 2018, 08:13:38 am »
Yes, at least it uses AA batteries (confirmed here: https://www.aliexpress.com/item/OUTEST-ZT-X-digital-multimeter-ac-dc-Ammeter-voltmeter-Ohm-Portable-meter-9999-counts-Backlight-true/32880281145.html), so it shouldn't be too bad and you can stick nice high capacity ones in if you want.
Offline maginnovision
« Reply #35 on: June 04, 2018, 08:15:40 am »
Judging by the unevenness of the backlight in the first video, it looks like they're using two LEDs, one on either side.
I think that's assuming no other issues. My AN870 eats batteries whether it is off or on and to use it I typically have to replace them. It's in my "Maybe I should just throw it out?" pile. Two LED's is a good guess, it's what they've been doing this far.
Offline Fungus
« Reply #36 on: June 04, 2018, 08:20:55 am »
Yes, at least it uses AA batteries (confirmed here)
Also shown in the second video (he installs them on camera).
You can clearly see there's two LEDs in the publicity shot from that page:
(You'd think they'd have photoshopped that image...  :o )
The display probably looks good in a dim basement, maybe not so much in a brightly lit office.  :popcorn:
Edit: It looks distinctly "Meh" in this other image from the same page:
« Last Edit: June 04, 2018, 08:32:47 am by Fungus »
Offline HKJ
    • Tests
« Reply #37 on: June 04, 2018, 08:28:52 am »
I wonder how you estimate the current consumption, a meter with one led can easily be below 10mA.
« Last Edit: June 04, 2018, 08:52:24 am by HKJ »
Offline HKJ
    • Tests
« Reply #38 on: June 04, 2018, 08:32:23 am »
You obvious have a faulty meter or use faulty batteries. The meter do not use current when the range switch is on off and uses less than 2mA in on (Backlight adds about 7mA).
Offline Fungus
« Reply #39 on: June 04, 2018, 08:38:38 am »
I wonder how you estimate the current consumption, a meter with one led can easily be blow 10mA.
Sure, but that's for reading in the dark.
This looks like the display depends on the LEDs for contrast so I'd assume they want them to be as bright as possible. They certainly look bright in the second video.
(besides, there's nothing wrong with "worst case" analysis)
« Last Edit: June 04, 2018, 08:41:48 am by Fungus »
Offline Mr. Scram
« Reply #40 on: June 04, 2018, 08:55:34 am »
I see it has a bar graph. That could actually be interesting.
Offline stj
« Reply #41 on: June 04, 2018, 10:18:28 am »
the real questions,
what chip does it use,
and does the led circuit use a boost convertor or a resistor?
because the older meters light a lot dimmer on rechargeable batteries.
Offline Fungus
« Reply #42 on: June 04, 2018, 12:38:15 pm »
I'm guessing it has to be a boost converter.
The fancy screen depends on those white LEDs and battery life will be awful if it can't keep going down to 2V.
Offline Doctorandus_P
« Reply #43 on: June 04, 2018, 01:12:47 pm »
I also spotted this meter as "Richmeter RM409B"
https://fr.aliexpress.com/store/product/RM409B-True-RMS-Digital-Multimeter-Button-9999-Counts-With-Analog-Bar-Graph-AC-DC-Voltage-Ammeter/909123_32878214801.html?spm=2114.12010612.0.0.792b41f1t0Su4P
Here another view of this meter:
https://cloud.video.taobao.com/play/u/17300505178/p/1/e/6/t/10301/50143362094.mp4
Display looks good, but I won't buy a DMM which sucks the batteries empty faster than a vampire could.
I'm kind of intrigued by the UI from rotary switch to push buttons.
I never liked the big rotary switches on DMM's.
But I also don't like to push a button a gazillion times to select between funktions.
My ideal UI would be a push button for each funktion, like a lot of the benchtop DMM's do.
I am curious about an in depth review of this thing though.
I really would like to know which chip is in it and how they do the switching between the different functions.
Offline Fungus
« Reply #44 on: June 04, 2018, 01:45:39 pm »
You already need to push buttons to select functions on many multimeters, eg. a lot of them put Ohms, continuity and diode on the same position on the dial and you have press a button to select the one you want.
Overall I don't think this meter is more button pushes than before. It looks like it actually might be less overall.
(and how many button pushes equals one use of the dial? Dialing is often a two-handed operation)
« Last Edit: June 04, 2018, 01:56:55 pm by Fungus »
« Reply #45 on: June 04, 2018, 04:53:18 pm »
The batteries are fine considering every single thing I put them in works normally. As to a bad meter, that's more or less the point. I bought 2. One was pretty much DOA and the second eats batteries. Considering the one I sent back apparently disappeared in the mail on its way and I still like to see what they manage but I'll probably stick to real quality meters.
Offline crazyguy
« Reply #46 on: June 04, 2018, 05:24:06 pm »
When you see a cheap multimeter with NCV function, almost you can assume it is based on Taiwan Hycon chipset, with bar-graph function, most likely it is Hycon two chipset DMM solution.
Offline sleemanj
« Reply #47 on: June 04, 2018, 09:56:19 pm »
I'd put money on it being a DTM0660L or variant there of (eg DM1106EN)
« Last Edit: June 04, 2018, 09:58:31 pm by sleemanj »
Offline all_repair
« Reply #48 on: June 04, 2018, 10:28:53 pm »
My experience buying from drop shipper (bangood included) is no good.  My guess is they are selling QC failed items.
ZT-303 is another interesting meter.
Offline crazyguy
« Reply #49 on: June 05, 2018, 01:34:23 am »
DTM0660L is Hycon HY12P66 chipset
take a look HYELEC MS8236 DMM (similar to Q1), it is using DTA0660L (HY12P6x series) + HY11P14
https://mysku.ru/blog/china-stores/42852.html
