My point in posting was to just have people get a look at it and see what they think (Like Eddie does in the above video, minus scoping it). It seems some people are more interested in simply shutting me down, instead of offering any constructive feedback. Like one poster said, what's with all of the attitude? Geeze.*
Nobody is shutting you down. It is just that the power supply you have there has been brought up several times already with various brands & model numbers. It isn't new. Whether a switching PSU is usefull or not depends on your use. If you are going to use it for developing circuitry (and it is very likely you need to make measurements) then a switching PSU is a horrible choice. The electric noise will show up on all your measurements. OTOH, if you need a beefy power supply to power a circuit just to have it powered on (like during burn-in testing) then a switching PSU is fine for use as an adjustable wall-wart / lump in chord PSU.
I have a similar model PSU like you have but I no longer use it due to the noise of the fan. I bought a bunch of fanless Gophert and Rek power supplies (https://www.eevblog.com/forum/testgear/rek-kps6003-and-gophert-nps-1602-60v-3a-psu-hack-review/msg3336994/ which can deliver 60V @3A. Other voltages / currents are also available but I deal with 48V DC equipment regulary so 60V is more convenient for me.
This one's fan only comes on during a heavy load. Why can't you just swap out the fan with a different less noisy fan, and or run it without the cover on it, or a modified mesh cover that lets it breath better?
Absolutely would need a no noise source for developing circuitry. I do understand. People were making personal attacks instead of product comments, and that's what I mean by shutting me down.
I'm only using it to power things for testing, to see if they come on, how much amps they use, things like LED srtrips, fan controllers, things that are already powered by switching power supplies.
It would be nice to see it's actual noise and voltage performance on a scope, like Eddie above did on that Kaiweets model (Ripple test a cap application at video 28:06):
He simply used a cheap 1uF poly capacitor to really reduce the noise. I wonder why the manufacturer didn't just install something like that in the first place?
