Houston we have got a problem
I tried the firmware I patched with both the initialization and translate function disabled and it does continue into the normal scope screen. Used the wrong version needed for my scope because the screen is shifted down and to the right, but that is no biggie.
I can see that the translations are not performed because the traces are not where they supposed to be.
This means that there is either another problem messing things up or the patched firmware did not load correctly, and thinking of it, the normal firmware upgrade procedure can't work since the check bytes won't be ok anymore. Forgot all about those.
So I would like to suggest another way to go forward in testing what works on your system. It involves writing a special startup program to the SD card and then load the firmware to test via USB.
I hope you have a linux system. Attached is a file "fnirsi_1013d_startup_with_fel.bin.txt". This needs to be loaded onto a SD card with "sudo dd if=fnirsi_1013d_startup_with_fel.bin of=/dev/sdc bs=1024 seek=8". Make sure to check which block device your SD card is connected to. Use "lsblk" to list the devices. Don't forget to unmount ("sudo umount /dev/sdc1") the partition otherwise "dd" won't work properly.
Stick this card in the scope and it will start with FEL operational. Connect the scope via USB to the linux machine and check with "lsusb" if the following device is present: "ID 1f3a:efe8 Onda (unverified) V972 tablet in flashing mode"
Now it is possible to load the firmware directly to DRAM. Use the following command to load and execute it: "sudo ./sunxi-fel -p write 0x7FFFFFE0 1014D_no_special_ic_no_translate.bin exe 0x80000000"
Remove the .txt extensions from the files. These are needed for uploading to the forum. Make sure the "sunxi-fel" file is executable and in the same directory as the "1014D_no_special_ic_no_translate.bin" file.
Hopefully the scope does the same as mine.
In the mean time I will continue with patching the firmware to have it do the needed translations.
