Finally, some discussion on the 2257! I first saw this in May or so, on one of the Brymen websites. It eventually appeared on TME for preorder and for sale but until now I've seen no discussion, no comments from users or reviewers. I was starting to think I might have to bite the bullet and do that part myself. Alas, I'm out of funds for such things at the moment.
Riddle me this: why are all compact multimeters more or less low-end? The 121GW seems to be the only exception. The Fluke 110 series is very limited in functionality, perhaps most notably missing AutoHold which I think is a killer feature in many of the same situations where a compact meter is the one to have. The Keysight 1230 series do have AutoHold (with 10 measurements of memory, nice) but are still limited to three input jacks and the general sentiment seem to be that they are disappointing quality-wise. So... the Brymen 2250 series seems to me as if it has very limited competition.
Brymen's response:
After checking, I found they are not bugs. They are their original design definitions.
When the AutoHold conditions are confirmed, the annuciator - "A-H" will flash to confirm that the reading is stable. The beep sound is just the auxiliary. That is the reason why its design disables beep simultaneously in the AutoHold function when beep is disabled. EEVblog BM786 has same AutoHold design definition for this.
It is great that we get answers, this is a large reason that I hold Brymen as my preferred meter-making company!
To keep on updating the display until surely no reading, only then showing the hold value - that makes sense to me and is another of the reasons I felt good about buying my BM789. A rare occasion for sure, but if the meter is reading something when I don't expect it to I'm grateful that it would show me.
But to disable the AutoHold beep when disabling button beeps, this does not make sense to me.
The real value of the Hold feature is (to me) when you do not have eyes on the display while making the measurement. But it requires you to have a hand on the meter instead which may be equally impossible. AutoHold then makes it possible, on top of making easy what Hold makes cumbersome. Without AutoHold the solution is to have a second person reading the multimeter while the first person executes the difficult-to-reach probing. This probably never happens on a bench, but it is frustratingly common when working on a vehicle or similar.
If I was able to see an indicator on the display I could just as easily read the value without using Hold at all. Right? Unless my short-term memory is having an unusually bad day I don't think I see the point of Hold without a beep, Auto or not.
IME, YMMV, but definitely not a humble opinion in this case.
