Author Topic: New Brymen BM2257 Multimeter  (Read 34152 times)
Offline mwb1100
Re: New Brymen BM2257 Multimeter
« Reply #175 on: January 29, 2025, 11:41:14 pm »
It would be, except...
But what's more popular than a YT where things blow up?
(though fuses popping might not be so exciting)
Online EEVblogTopic starter
« Reply #176 on: January 29, 2025, 11:44:43 pm »
Sadly you don't get to see anything with sand filled HRC fuses
Offline mwb1100
« Reply #177 on: January 29, 2025, 11:56:17 pm »
of course...   :palm:
Offline geralds
« Reply #178 on: January 30, 2025, 12:01:45 am »
@eevblog, @mwb1100, @bdunham7 (not sure whether "@" + user works like in Outlook?)
Many thanks for your super fast replies, which are very helpful indeed! What a forum!
I will then look again at the AN870, despite my tendancy for the BM2257 as it seems more robust and thus should hopefully last substantially longer. Plus a set of ProbeMaster and Hirschmann leads/probes.
Re Fluke 115/225 set, there seems to be a promotion in Europe for around EUR 250. But noted about (lack of) Auto-Hold function, LoZ and usefulness about probes/test leads for electronics, so it seems the BM2257 has more useful features/functions for my requirements. And the promotion/set does not seem to be available for the 116/117.
I have no intention to do any mains works (nor microwave ovens!) - I know my limits and prefer to leave that work to the professionals.
I will keep you posted once I have finally decided (may take a few weeks).
Thanks again, your response time and helpfulness is really impressive!
The following users thanked this post: EEVblog
« Reply #179 on: January 30, 2025, 12:05:35 am »
Pop quiz: How many mA does it take to blow a 400mA fuse?
In theory, 401mA after quite some time.
At 400mA the fuse should not break after an infinite time.
In practice, any random value if you bought a fake off ebay, or if genuine follow the parametric charts and add your own window, add salt to flavour.
Good topic for a video.
Quality vs no name vs Normal vs Slow blow vs Fast blow.
It would be, except it's basically a statistical thing, so you have to run a lot of them.
Apply KISS principles as to many new entrants a fuse is just a fuse.
« Reply #180 on: January 30, 2025, 12:14:25 am »
I forgot I had done this video!
The following users thanked this post: mwb1100
Offline bdunham7
« Reply #181 on: January 30, 2025, 01:22:01 am »
I just finished the first round with the fuses you sent me.  You're right, it's not that exciting.   :=\
Offline jj5
  • Still learning about electronics...
    • In The Lab With Jay Jay
« Reply #182 on: January 30, 2025, 09:13:10 am »
Maybe change the package to:
    2 x HV110 11A 30kA 1000V HRC (10x38mm)
    2 x HV620 400mA 10kA* 1000V HRC (6x32mm)
    3 x HV620 630mA 10kA* 1000V HRC (6x32mm)
I think that's a great idea. This set would suit me as I have a BM2257 and am planning to get 121GW and maybe some others. Not sure how much it would suit others though!
Offline jj5
« Reply #183 on: January 30, 2025, 10:11:17 am »
p.s. I would also be happy to buy one 11A+400mA set plus one 11A+630mA set.
Offline Fungus
« Reply #184 on: January 30, 2025, 01:42:03 pm »
Against this backdrop / intended use, would the BM2257 be fit for purpose?
Easily.
The following users thanked this post: geralds
Offline CustomEngineerer
« Reply #185 on: February 05, 2025, 11:48:34 pm »
From the bm235-loz-mode thread:
FYI, the new BM2257 will autorange down to 6V range in LowZ mode, so you get the full 1mV resolution all the way down to 0V.
Completely changed from the BM235
Wondering if anyone has anyone tested this? The user manual suggests LoZ only works down to 1.5V. Testing on mine it seems to work down to about 0.930V. If I'm not reading to much into the above quote it seems Dave is suggesting it goes all the way down to 0V? Or maybe he just meant that you get the full 1mV resolution until it cuts out, which it does. Not a big deal either way, but was curious if I was missing something.
This is what the BM2257 user manual has to say about it.
When a signal above the voltage threshold of 1.5V DC or AC up to the rated 600V is present, the meter displays the voltage value in the appropriate type DC or AC, whichever is larger in peak magnitude.
« Reply #186 on: February 06, 2025, 01:36:21 am »
I stand corrected. Just measured one and only got down to 0.93V.
In practice, that's plenty low.
The following users thanked this post: CustomEngineerer
« Reply #187 on: February 06, 2025, 05:14:01 pm »
Agreed, thanks for verifying. Hope a few others do as well just to see if the 0.93V is consistent.
Offline Furna
  • I still don't know
« Reply #188 on: February 06, 2025, 06:05:24 pm »
I just received mine today ...
I can go down to 0.928V
The image has been captured when it was at 0.929V but I can guarantee 0.928V
Sorry for the low quality photo.
Super happy!
Actually for the low amp fuse I went for EKSA 632.415 630mA
Sorry Dave I didn't buy the fuse from you; at the time of the order you only had the 600mA
The sky above the port was the color of television, tuned to a dead channel.
Offline bdunham7
« Reply #189 on: February 06, 2025, 06:25:40 pm »
It would be interesting to know what design quirk makes it work that way as I don't see an obvious reason for it on DCV.  Is the input impedance still low below 0.93V?
« Reply #190 on: February 06, 2025, 10:46:03 pm »
I've ordered 630mA fuses from ASTM but have not heard anything back yet. Resent the email to new people and still nothing. Not sure what's going on...
Offline floobydust
« Reply #191 on: February 06, 2025, 11:22:43 pm »
What are we talking about?  I got lost here.
That there is a deadzone of +/-0.93V before a reading is displayed, or for the LowZ load to engage? The Brymen manual does not say what happens below "1.5V".
You found the transistor clamp are in-series with the LowZ PTC load (on a different Brymen model) so nothing much is happening at below say 6V for the input impedance to decrease on them. (There may be a MOV-like action with these HV PTC's, as a faint theory of mine, as they have similar construction.)
As far as the fuses go, I see very little difference from 500-630mA when the relevant BM2257 range is 600mA.
Those fuses don't even consider blowing until currents are 2-4x times above that, and the i2t times are not so different.
Offline bdunham7
« Reply #192 on: February 06, 2025, 11:41:40 pm »
Well, both and how they might be related.  The BM2257 auto-ranges down and I'm really curious to know why it would not read below 0.93V just because there is a PTC across the inputs.  I'm presuming it is because the input layout just isn't that simple.  The input impedance issue is just another angle that might give a clue as to the input setup.  It just seems a bit...weird.
Fluke's straightforward approach means it will read down to the last digit in DC Lo-Z, although it only has a 1000V range.  And the input impedance is about 3.2k no matter how little the input voltage is.
« Last Edit: February 06, 2025, 11:44:02 pm by bdunham7 »
Offline Furna
« Reply #193 on: February 07, 2025, 03:20:54 pm »
Ohm's law says at 2V impedance is around 2KΩ (see picture).
For lower voltages I get unreliable A values.
« Reply #194 on: February 07, 2025, 09:20:34 pm »
Yeah, I'm surprised.
I can understand the BM235 with the input arrangement it uses, but this is a bit puzzling. Sounds dual diode droppy...
Offline floobydust
« Reply #195 on: February 07, 2025, 11:30:23 pm »
If there is a deadzone for the LowZ to engage - then I'd need to know about it and probably say ick.
It sounds like input impedance is 10MEGΩ when input voltage is less than 2-3 diode drops, and above that the PTC is present and 2.1kΩ when LowZ is selected. It does simplify the rotary switch design and that is why I think Brymen is doing it.
To test/prove it you could inject a sine-wave with series sense resistor observed on a scope, to see if this is the case.
This will cause a problem when troubleshooting low voltage such as automotive. You'll get say a 1.5V ghost reading outside of the pristine laboratory, in the mud and dirt.
Do the armchair experts here know what this means?  ;)
Offline bdunham7
« Reply #196 on: February 08, 2025, 12:17:15 am »
I don't think there's that sort of direct correlation between the input impedance and the minimum reading.  Does the BM235 stop reading below about 7V or does it just go high-impedance?  Those really are somewhat independent issues although the design may work in some sort of relation between the two.  Dave just needs to break out a screwdriver and have a look....
« Last Edit: February 08, 2025, 12:33:40 am by bdunham7 »
« Reply #197 on: February 08, 2025, 12:43:58 am »
In progress...
Offline Furna
« Reply #198 on: February 08, 2025, 09:59:57 am »
One of the armchair experts here, doesn't have (yet) an AWG ... it's on the buy list althought not on the top.
Offline floobydust
« Reply #199 on: February 08, 2025, 07:24:58 pm »
 :popcorn:  It would be great if we knew the two PTC part numbers, somebody cut off the heatshrink tubing over them to see that.
I also note Fluke ditched using clamp transistors for a while now in their newer models and instead is using diode arrays but they are not symmetrical. Clamp is +6Vf and -2Vf on the (PTC) Ohm's source channel and Dave might see something odd like that if Brymen is indeed running the LowZ PTC in series with a clamp.
I could draw the BM2257 schematic if I had one or loosely based on board pics but that would cause trouble.
Hey this is new silicon? Brymen got the (Hycon) LCD driver and DMM IC into one 100-pin package it seems.
