Author Topic: New DC clamp mestek CM82C vs old uni-t ut210e  (Read 1060 times)
Offline 001
  • Country: aq
« on: August 01, 2019, 11:08:31 am »
Hi!
I`m looking to buy uni-t ut210e now
But I see mestek CM82C https://www.gearbest.com/multimeters---fitting/pp_009402176983.html
 6000 counts in stock and no pink enclosure  ;)
Is it good or bad?
I can`t see range button  :-//
Offline 001
  • Country: aq
Re: New DC clamp mestek CM82C vs old uni-t ut210e
« Reply #1 on: August 01, 2019, 12:19:38 pm »
And what about misterious Bside ACM91?  :-//
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #2 on: August 02, 2019, 01:20:25 am »
I don't know about this particular clamp, but Mestek's small DM91A was quite reasonable - although with a terribly slow continuity.
Offline thm_w
« Reply #3 on: August 02, 2019, 09:43:22 pm »
CM82C
Test Parameters
DC current: 6A / 60A / 100A 0.001A / 0.01A / 0.1A ± ( 3.0% + 5 counts )
DC current ( uA ): 0 - 200uA 0.1uA ± ( 0.8% + 5 counts )
AC current: 6A / 60A / 100A 0.001A / 0.01A / 0.1A ± ( 2.5% + 5 counts )
DC voltage: 6V / 60V / 600V 0.001V / 0.01V / 0.1V ± ( 1.0% + 3 counts )
AC voltage: 6V / 60V / 600V 0.001V / 0.01V / 0.1V ± ( 1.0% + 3 counts )
Resistance: 600 / 6k / 60k / 600k / 6M ohm 0.1 / 0.001K / 0.01K / 0.1K / 0.001M ohm ± ( 1.0% + 3 counts ) 60Mohm 0.01Mohm ± ( 1.2% + 20 counts )
Capacitance: 600uF / 6000uF 0.1uF / 1uF ± ( 4.0% + 3 counts )
Frequency: 60Hz / 1000Hz 0.1Hz / 1Hz ± ( 1.0% + 5 counts )
Frequency ( by jaws ): 60Hz / 1000Hz 0.1Hz / 1Hz ± ( 1.0% + 5 counts )
Low impedance LOZ: Max 600V Resolution 0.1V
Buzzer: If the resistance is less than 30Ω, the continuity beeper sounds
Temperature: -20°C - 500°C 1°C / 2°F ( 2.0% + 2 counts )
Jaw capacity: 20mm
Power: 1.5V ( AAA ) x 2 ( not included )
Conform to the IEC-61010-1, IEC-61010-2-030, IEC-61010-2-032, IEC-61010-2-033 standards
Over-voltage protection class CAT III 300V, CAT II 600V, pollution degree II
UT210E
SPECIFICATION
Alternate Current 2A/20A/100A ±(2.5%+5)
Direct Current 2A/20A/100A ±(2.5%+3)
Alternate Voltage 2V/20V/200V/600V ±(1%+3)
Direct Voltage ±(0.7%+3)
Resistance 200Ω/2kΩ/20kΩ/200kΩ/2MΩ/20MΩ ±(1%+2)
Capacity 2nF/20nF/200nF/2μF/20μF/200μF/2mF/20mF ±(4%+5)
So the low current range is slightly worse accuracy (+0.5%), but has much wider range (0-6A). AC current and voltage have the same stated accuracy.
Not sure what you mean by range button, UT210E doesn't have it right? But this thing does not have manual ranges, so auto range which is good right.
Its cheaper on Aliexpress as well: https://www.aliexpress.com/item/32962090990.html
Are ACM91 and CM82C the same thing?
Review of ACM91: https://lygte-info.dk/review/DMMBSide%20ACM91%20UK.html
ACM91: https://www.aliexpress.com/item/1970498378.html
Can get it in black, blue, or off-white: https://www.aliexpress.com/item/1349685186.html
« Last Edit: August 02, 2019, 09:46:23 pm by thm_w »
Offline 001
  • Country: aq
« Reply #4 on: August 03, 2019, 01:56:06 pm »
NO! Check dual display vs single etc  ;)
