Author Topic: New Der EE LCR+DMM  (Read 17428 times)
Offline PedroDaGr8
  • A sociable geek chemist
New Der EE LCR+DMM
« on: March 13, 2015, 07:50:11 pm »
Der EE just released a new meter DE,-5003/5004. It's a solid mid range DMM with decent safety specs but also has a built in real LCR (selectable frequencies up to 10kHz, can read ESR, phase angle, 0.5V test voltage, etc). Neither part are ground breaking specs wise but it's nice to see an all-in-one that isn't entirely a freaking toy. The LCR specs should be good enough for most hobbyists, not for pros though. I wonder what you guys think about it.
 http://www.deree.com.tw/prod141001162828.htm
My biggest wonder will be price. Will it be cheaper than buying a solid meter and a DE-5000(which as we all know is damn good) separately.
« Last Edit: March 13, 2015, 07:53:50 pm by PedroDaGr8 »
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Offline DAIRVINE
Re: New Der EE LCR+DMM
« Reply #1 on: March 13, 2015, 07:56:26 pm »
If this is really cat 111 to 600V for LCR that is really good. It would be helpful to have an LCR that could withstand accidents with charged capacitors.
Offline PedroDaGr8
« Reply #2 on: March 13, 2015, 07:58:53 pm »
Just saw on another forum, the slated price is $150 or less. Which actually seems like a smart price point based on the features and specs. It's about a $120 meter with about a $50 LCR. So together it's pretty reasonable. A good price point I think for hobbyists with a bit of savings.
Offline TimFox
« Reply #3 on: March 13, 2015, 08:08:40 pm »
Who distributes these units?  The DER website does not have prices.
Offline Lightages
  • Canadian po
« Reply #4 on: March 13, 2015, 08:35:01 pm »
If it sells for less than $120, then it will quickly become the most recommended meter for those looking for something close to $100 as their first meter for electronics.
Offline wiss
« Reply #5 on: March 13, 2015, 08:53:52 pm »
Hummm, I want one! :)
Offline jimon
« Reply #6 on: March 13, 2015, 09:36:38 pm »
Just got DE-5000 a week ago, go figure :palm:
Offline PedroDaGr8
« Reply #7 on: March 13, 2015, 09:42:16 pm »
Relax, the DE-5000 is a much better LCR. This one though is a capable one for hobbyists, just not nearly as nice as the DE-5000.
Offline Wytnucls
« Reply #8 on: March 14, 2015, 01:02:07 am »
It's not that new. It has been on my spreadsheet list for quite a while.
Supposedly 6,000 count, but it shows 5 digits on the display (4 1/2 really).
« Last Edit: March 14, 2015, 01:37:45 am by Wytnucls »
Offline dadler
« Reply #9 on: March 15, 2015, 10:06:08 pm »
DE-5000 goes to 100kHz
Offline pcbroute
  • Country: ru
« Reply #10 on: October 20, 2016, 07:01:11 pm »
Hi all. Got DE-5004 a few months ago...
i think is really good.
some photos.
The following users thanked this post: chickenHeadKnob
Offline pcbroute
  • Country: ru
« Reply #11 on: October 20, 2016, 07:04:06 pm »
with another LCR...
Offline Lightages
  • Canadian po
« Reply #12 on: October 20, 2016, 09:27:17 pm »
Thanks for the images. This looks like a well built and it might actually meet its CAT ratings. Like I said before, this looks like the perfect meter for electronics.
Offline omgfire
  • Country: ru
« Reply #13 on: October 21, 2016, 06:03:30 am »
ES51930?
pcbroute, do you think you could shoot other pcb side, switch and instruction manual?
Offline WackyGerman
« Reply #14 on: October 21, 2016, 07:35:54 am »
On the first glance it really looks nice and tidy . But I don t like the design at all . Why did they put the 10 A at the middle right and the small one at the bottom and not the other way round ??? So the COM trace on the board for the 10 A range is very long and the shunt is straight over the control circuits of the multimeter . Then I don t like the cheap trimmer pots on the board . It seems that they trimmed the multimeter into the specifications . The fuses are the right choice so  :-+ for the fuses . The design is not that good so  :-- :-- for the design . the idea to combine a multimeter with a lcr meter is a good idea  :-+ . But unfortunaltely this meter is too much built down to the price
Offline omgfire
  • Country: ru
« Reply #15 on: October 21, 2016, 08:54:16 am »
It seems that they trimmed the multimeter into the specifications . But unfortunaltely this meter is too much built down to the price
Gossen MetraHit 30M has trimmers. Is it also "too much built down to the price"?
« Last Edit: October 21, 2016, 08:59:58 am by omgfire »
Offline pcbroute
  • Country: ru
« Reply #16 on: October 24, 2016, 09:50:47 am »
ES51930?
ES51930 looks very similar.
Sorry, i don't shoot other side, may be a later if i broken it)
Here is a user manual, i scan it and make PDF file.
DEREE-DE5004.pdf
The following users thanked this post: kripton2035, omgfire
Offline kripton2035
« Reply #17 on: October 24, 2016, 11:48:36 am »
thinking of buying one sooner or later... already have a deree de5000 but this small meter is cute...
Offline omgfire
  • Country: ru
« Reply #18 on: October 24, 2016, 12:21:18 pm »
Peakmeter PM8246 looks inferior, but with same concept. I wonder how much cheaper it would be.
Offline kripton2035
« Reply #19 on: October 24, 2016, 01:11:15 pm »
the input of the de5004 seems protected to 600v ?
on the pcb there are some big resistors, fuses, mov and the input is the same for volt and lcr.
on the peak8246 on the contrary there is a separate input for the lcr, there is not far to say that this input is not protected at all ...???
Offline kripton2035
« Reply #20 on: November 15, 2016, 07:46:02 pm »
just received a deree de5004 today, first impression is : really not as good as the deree de 5000 !!!!
can be used as an esr meter, will have to check that better but it seems ok for that use.
definitely not an lcr meter.
Offline rjardina
« Reply #21 on: January 05, 2017, 11:26:30 pm »
ES51930?
DEREE-DE5004.pdf
Offline rjardina
« Reply #22 on: January 05, 2017, 11:45:37 pm »
I'm probably one of the last people that needs to review this meter, due to my lack of knowledge of using a LCR meter or even really knowing how to use one. That is why I bought this one and the 5000 to learn some more. The Auto on the LCR frequency part is very erratic and never get the same results.
Offline 1937
  • Country: ru
« Reply #23 on: March 02, 2017, 05:47:47 pm »
For those guys who are interested what is under the display. There is TI MSP430F4371. The same bracket as in some LCR tweezers like AKIP-6107.
Has anyone tried to activate an IR optical link with the PC? The 75 leg of MSP430F4371 gives no signs of life. :horse:
Not found a complete datasheet with schematic for ES51930.
May be someone knows, what is purpose of the missing components on DE-5004 board? :-/O
Think that the resistors RC13, RC14 and op. amp. U3 are responsible for contactless electric field measurement.
It would be cool if DER EE implemented all functions.
« Last Edit: March 03, 2017, 12:58:55 pm by 1937 »
Offline shteii01
« Reply #24 on: March 03, 2017, 01:52:20 am »
If I recall correctly, DMM version does not do pF.  That is why I got DE-5000 LCR Meter.
Offline kripton2035
« Reply #25 on: March 03, 2017, 10:28:15 am »
[/size]
DE5003-5004 goes down to 0.1pF(±2%+20) and 10nH(±3%+20)
DE5000 goes down to 0.01pF(±1.2%+5) and 1nH(±2.5%+5)
so the probes you use will make a big difference in the measurment accuracy !
« Last Edit: March 03, 2017, 10:31:55 am by kripton2035 »
Offline 1937
  • Country: ru
« Reply #26 on: March 03, 2017, 07:03:20 pm »
If you want to do right LCR measurements by this meter, use this thing.
I have compared readings from this device without wirings and readings from LCR meter based on ES51919 with kelvin probes and got very good results.
Offline shteii01
« Reply #27 on: March 03, 2017, 10:47:27 pm »
That Nagant looks familiar.  Are you Gunboards.com member?
Offline AndersAnd
« Reply #28 on: June 10, 2021, 05:35:19 am »
Actually DER EE DE-5003 and DE-5004 only goes down to 3.0pF with a resolution of 0.1pF (±2.0%+20) and down to 0.3µH with an resolution of 0.1µH (±3.0%+20) according to specifications: https://www.deree.com.tw/de-5004-digital-multimeter-lcr.html#specification_tab
« Last Edit: June 10, 2021, 05:45:12 am by AndersAnd »
Offline AndersAnd
« Reply #29 on: June 10, 2021, 05:47:10 am »
Does anybody know where to buy DER EE DE-5004? I can't find it for sale online at eBay or elsewhere.
Has it been discontinued?
Offline kripton2035
« Reply #30 on: June 10, 2021, 06:11:56 am »
Offline AndersAnd
« Reply #31 on: June 22, 2021, 11:53:21 am »
may be you can ask directly the manufacturer
https://www.deree.com.tw/index.php?kw=5004&lang=en&modelid=1&c=content&a=search
Thanks, but I have tried to contact them both via their online contact form and via email, but they don't reply.
The only reply I got was an auto reply right after I filled out the online forum, which said "Dear...., We will respond to your inquiry as soon as possible".
But since then I have heard nothing and it has been two weeks now. So I also tried to send them an email to deree@deree.com.tw, but they do not reply to that either, not even an auto reply.
Completely useless customer support.
« Last Edit: June 22, 2021, 11:55:47 am by AndersAnd »
« Reply #32 on: June 22, 2021, 12:20:34 pm »
Try these:
https://www.jredfox.com/index.php?main_page=product_info&products_id=902009
https://www.taiwantrade.com/product/de-5004-digital-multimeter-lcr-1347664.html
(NAWTS)
It does seem to be out of stock at a few vendors, the DER EE site doesn't mention if it's discontinued   :-//
Addiction count: Agilent-AVO-BlackStar-Brymen-Chauvin Arnoux-Fluke-Hameg-HP-Keithley-IsoTech-Mastech-Megger-Metrix-Micronta-Racal-Siglent-Solartron-Tektronix-Thurlby-Time Electronics-TTi-UniT
The following users thanked this post: AndersAnd
Offline AndersAnd
« Reply #33 on: July 19, 2021, 10:38:04 pm »
Try these:
Thanks, but this web shop raises a lot of red flags and seems like a scam website. I have never heard of them before and it's hard to find any info about them if your google their site name.
And the only contact info on their website is this questionable e-mail address sunny_service@trade7686.com with not relation whatsoever to the website name jredfox and the e-mail address in only inserted as an image which you can't click on to send an e-mail.
If you google ths e-mail adress all the first his are to websites talking about fraudlent websites. And these fraulent websites mentiond afe other "webshops" than jdredfox.
And there's no, phone number or physical address. The company address should always be included on legit web shops.
It doesn't even say in which country this company belong.
The tiny black and white VISA, PayPal, MasterCard and Maestro logos at the bottom also seems highly questionable.
For example they don't use the official VISA point of sale graphics required by VISA on POS sites: https://usa.visa.com/run-your-business/accept-visa-payments/posguidelines.html
Maybe the reason this is the only website with this product listed is because it's a scam website with no real products pf any kind in stock.
« Last Edit: July 19, 2021, 10:43:19 pm by AndersAnd »
